Raleigh Professional seat post size
Bikes: 2008 Seven Axiom Steel, 1984 Colnago Nuovo Mexico, 2008 Cervelo P2C, 2000 Trek Multitrack 7200
Quoted: 17 Post(s)
Again, thinking about rebuilding the 1975 Raleigh Professional frame I acquired last summer. I need a seat post so I can attach the frame to my bike stand. I used a pair of Verneir calipers to measure the inside diameter of the seat tube and it appears to be 26.5 to 26.6 mm. What size seat post do I need? Anyone know the identity of the seat post that originally came with the bike?
TSAPP
TSAPP
car dodger
Should be 27.2mm
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
Bikes: i don't have a bike. a few frames, forks and some parts. that's all
Quoted: 54 Post(s)
Liked 52 Times
according to mr.brown's old raleigh page:
https://sheldonbrown.com/retroraleighs/professional.html
it says originally campy record. (table at the bottom of the page)
however, his seatpost size database page doesn't list professional.
(hey, btw. pls don't get me wrong. i'm studying myself here too)
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Quoted: 17 Post(s)
Before I measured the inside diameter of the seat tube, I tried inserting the seat post from my (non-vintage) road bike. It's a 27.2 mm Ritchey and it definitely does not fit. Perhaps I could REALLY grease it up and force it into the seat tube, but I don't think that's the way it should work. Is there some "rule of thumb" for selecting the seat post size, i.e., 1 mm (or whatever) less than the inside diameter of the seat tube? I don't think the seat post ears are pinched.
TSapp
TSapp
Bikes: '53/'54 Bianchi CDM, '62ish Altenburger Cinelli Mod B, '69 Rene Herse Competition, '72 Motobecane Grand Record, '73-74 Colnago Super,, '73-74 Cinelli SC, '78ish counterfeit Confente, '82 Medici Gran Turismo, '67ish Mondia Speciale, Eddy Merckx Pro
Quoted: 90 Post(s)
Liked 257 Times
531 was sometimes 27.0, though I don't know if Pros ever came this way? My Competition is 27.0...
Photos please!
Photos please!
Quoted: 34 Post(s)
Liked 8 Times
TSapp
TSapp
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
My '78 is definitely 27.2
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Quoted: 17 Post(s)
I'll get a photo up this evening.
TSapp
TSapp
Quoted: 4722 Post(s)
Liked 3,036 Times
+1 regarding the lug ears. The other (more remote) possibility is that it may be a Reynolds 753 frame. They would use a 26.6mm post. It would also be easy to verify, as they used the 28mm outer diameter, metric seat tube versus the imperial tube with a 28.6mm outer diameter.
Quoted: 17 Post(s)
It's Reynold's 532 and not 753. Picture coming soon.
TSapp
TSapp
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
I'm kind of hoping you have a metric-tubed 531 Raleigh Pro. That would an excellent thing to add to this forum. Of course many pictures would be required.
Edit: dang, just pinched ears
Quoted: 17 Post(s)
Here are the photos. Thinking ahead, if the ears are pinched, what then, i.e., how does one "unpinch" the ears?
TSapp
TSapp
Quoted: 380 Post(s)
Liked 106 Times
Put a screw drive into the slot and widen the slot is the way to widen a pinched frame. There is no such thing as Reynolds 532 that I have ever seen. Roger
Quoted: 17 Post(s)
I stand corrected. It's Reynolds 531. (Must put my fingers on a diet soon.)
TSapp
TSapp
Quoted: 17 Post(s)
I haven't heard an opinion yet. Are the ears pinched?
TSapp
TSapp
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Question for you. What's the serial number on the frame? I am asking simply to attempt to rule in/out some possible explanations. The ears do not look badly pinched, however if the top of the seat tube is ovalized a little bit, it might be at some point other than at the ears. Another thought (pure speculation) - the frame might possibly have been built with the butted end at the top, rather than the bottom.
Liked 4,395 Times
That's not an SBDU frame - it's a run-of-the-mill Raleigh Professional Mk.IV. Hence, it is 27.2 - unless it is a strange/botched build from the factory, which is unlikely.
At any rate, those ears are pinched - even the seattube hole itself has been ovalized. You will find that you'll have to very carefully spread the ears more than necessary in order to widen the flattened areas enough so that the 27.2 can fit again - then, while the post is in place, fasten the overspread ears. The tube will re-conform to the post.
-Kurt
-Kurt
Liked 3,036 Times
As to the ears being pinched, it's very hard to tell in the provided pictures. Shadows, focal distances and parallax can often create an illusion of things that don't exist.
There's a lot of shadow in the picture taken fromm the top, but the slot does appear to be parallel. If the post was 0.6mm undersize, the slot would be should be about 2mm narrower at the top. For your typical slot, that would be about a 50-66% reduction and should be clearly evident if you compare the bottom to the top.
However, the opening also appears to be very oval. In the pic, the front to back dimension appears to be about 10% bigger. If the post matches the width, and the opening is oval, there should be a discernible gap in the front and/or back of the post and the difference in the minor and lajor axes should be easily measurable.
Finally, measure the outside diameter of the seat tube and see if you can detect any stampings under the paint, near the top or bottom of the seat tube. It would not be the first time that somebody has grabbed the wrong tube, put it in upside down or applied the wrong decal.
Quoted: 443 Post(s)
Liked 27 Times
It's very obviously pinched. No doubt about it. Just don't put a screwdrive partway down the tube and pry from side to side. I once punched through a 531 tube that way.
Quoted: 17 Post(s)
The seat tube, at least at the top, is somewhat "ovalized" as I look down it. Lots of good advice here (as usual). Thanks to all who contributed their thoughts.
TSAPP
TSAPP
mikeronson
Classic & Vintage
16
07-08-15 11:12 AM
kaneandrew
Classic & Vintage
2
03-26-11 10:44 AM
