newbie: rear derailleur and gearing!
Hello!
I just got my first cx bike and recently went to a local cx clinic to learn how to mount, dismount, etc.
Anyway...my bike currently has a road compact 50/34 up front. And a 12-27 cassette in the rear. Is this ok? To be honest, I wished I had a larger cog during the cx clinics 40 minute post instructional race! Also...I have a SRAM XX rear derailleur. Should I swap that out for a SRAM road derailleur? Or keep the mountain derailleur on it?
Thanks!
Thanks!
Quoted: 336 Post(s)
Liked 309 Times
What you have is fine.
A larger cog in the back would only get used, and you don't want that in a race. If you need lower gearing for the steep stuff, you should probably be running anyway.
A mountain RD will probably be more durable that an RD, so any difference in performance or weight wouldn't be noticeable.
That gearing is fine. At some point you might want chainrings that are more closely spaced. The hot combo these days is 36/46. 50/34 is such a big jump that it's not terribly usable in a race.
Thanks!
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I've always found that (for me) even 46-36 isn't useful, mostly because I never need the 46. I've gone with a 1x10 setup. I've been using a 36 in front, but I feel like it allows me to be too slow (CX races have a way of moving you into your lowest gear) so I'm swapping in a 38. My biggest concern about 50-34 would be that I'd spend too much time in the 34-27 gear.
My Bikes
My Bikes
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
Only bad thing about a MTB rd is it's longer so it can snag on stuff, but it's paid for, so ride it.
Givmedew
Road Cycling
5
07-11-16 11:37 AM
Steve90068
Bicycle Mechanics
42
01-28-11 09:02 PM
jmeans53
Bicycle Mechanics
9
08-22-10 08:19 PM
