BB 118.5 vs 118
BB 118.5 vs 118
Old 01-15-24, 09:54 AM
rcommbikes
Bikes: Dahon folder, Santana tandem, Trek triathlon, Haro MTB, Bike Friday
Quoted: 35 Post(s)
Liked 17 Times in 7 Posts
BB 118.5 vs 118
Greetings! I’m restoring a tandem with Ultegra Octalink BBs . The ones I pulled out are marked 118.5 BB6500 68 1,37x24. There are lots of 68 118 Bottom brackets, available. Doe the extra 0.5 mm make any difference? I’m inclined to say no but would like your opinions.
Thanks
Fred, for R Community Bikes. www.rcommunitybikes.org
2,500 (yes 2,500) bikes given EACH YEAR to the needy 2011- 2018. All volunteer.
rcommbikes is offline
Old 01-15-24, 10:00 AM
curbtender
curbtender's Avatar
Quoted: 1613 Post(s)
Liked 2,598 Times in 1,227 Posts
You have a sample of the 118 you are looking at? May be a different spline configuration.
curbtender is offline
Old 01-15-24, 10:10 AM
Iride01
Iride01's Avatar
Quoted: 6199 Post(s)
Liked 4,816 Times in 3,323 Posts
They claim to have one here in 118.5mm. They want a arm and leg for it! But for old stuff on old bikes it is what it is.
https://www.universalcycles.com/shop...hoCeNkQAvD_BwE
Iride01 is offline
Old 01-15-24, 10:17 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6222 Post(s)
Liked 4,222 Times in 2,368 Posts
Thanks
For context, 0.5mm is a bit thicker than a business card and a bit thinner than a credit card. On the bottom bracket length, it’s not going to make much of a difference. It’ll move the stoker pedals about that thickness closer to the frame (divided by 2).
Stuart Black
cyccommute is offline
Old 01-15-24, 10:25 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
$45 is not bad for something that lasts a long time, and could go the way of the UN55 any day.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 01-15-24, 12:18 PM
KCT1986
Quoted: 346 Post(s)
Liked 320 Times in 234 Posts
Thanks
The Ultegra cranksets uses the older spline design, commonly called Octalink V1, that has different dimensions than the 'V2', (usually found on MTB) cranks. The 118mm is likely a V2.
See the differences below. Note the model number, the 'C' or 'ES' are V2 and will damage a V1 crank's splines.
They are not interchangeable so you need to seek out a V1 in the 118.5 length. Didn't seem that anyone else ever made third party substitutes.
KCT1986 is offline
Likes For KCT1986:
Old 01-15-24, 01:37 PM
rcommbikes
Quoted: 35 Post(s)
Thanks, I learn something new every day. So 7703 and 5500 are interchangeable with the 6500?
Old 01-15-24, 01:50 PM
Iride01
Iride01's Avatar
It's just the difference in the DuraAce, Ultegra and 105 name and part numbers and whatever is special for the more costlier groups. Which today for other components in the groups usually means it is made from materials that will give a lighter weight. However they are compatible physically. Not certain what they'd do different in a BB other than just hold the manufacturing tolerances better.
Iride01 is offline
Old 01-15-24, 02:35 PM
KCT1986
Quoted: 346 Post(s)
Yes, just get the correct length and BB threading. There may be some quality/material/polishing differences between the models but details are not available. The 109.5mm 7700 DA was a different design with adjustable races and a double bearing system, but don't know of this was carried over to the 7703.
KCT1986 is offline
Old 01-15-24, 04:34 PM
curbtender
curbtender's Avatar
The 5500 is pretty much all that you can buy new anymore. It's a good replacement.
Likes For curbtender:
