Can't locate clicking sound
Hi
I'm getting a bit desperate here, so I've made a little video with a clicking sound, that I can't locate. Any ideas?
Google Drive link: drive.google.com/file/d/1TPAubK-JEl9d4_TaLwr2lhrJOQr2tV5C/view?usp=sharing
It happens on all rides in all weather conditions. It happens only when pedaling, both when pedaling fast and slow. It sounds like it's coming from the crank area. The click isn't systematic with a consequent rhythm.
Bike:
CANYON Roadlite AL SL 8.0 2019
Ultegra gear set
KM: 1.800
I've tried.
Thanks in advance.
Bike:
Ultegra gear set
KM: 1.800
I've tried.
- Changing pedals
- Removing nearly all bolts and added grease
- Changed the chain
- Added grease to the spokes at the rims
- Added grease to the chainring bolts
- Added grease to the front and rear dropout
- Added grease to the crank arm, where it meets plastic.
- Tightened all bolts, especially near front derailleur
Thanks in advance.
Troublemaker
Bikes: Yes. The more the better.
Quoted: 46 Post(s)
Liked 44 Times
Several times I have had clicking that I thought was coming from the crank/pedal area of one of my bikes and it turned out to be saddle/seatpost noise.
Likes For Berg417448:
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Hi
Bike:
Ultegra gear set
KM: 1.800
I've tried.
Thanks in advance.
Bike:
Ultegra gear set
KM: 1.800
I've tried.
- Changing pedals
- Changed the chain
Thanks in advance.
Try one legged pedaling (the other foot completely off the pedal) to see if it's one side only vs the other, and then could be pedal related.
Are you using clipless pedals and have you greased the pedals and the cleats?
Hi
Bike:
Ultegra gear set
KM: 1.800
I've tried.
Thanks in advance.
Bike:
Ultegra gear set
KM: 1.800
I've tried.
- Changing pedals
- Changed the chain
Thanks in advance.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
Change out your bottom bracket..I'd guess your sound will disappear. Mine did.
Likes For fishboat:
Quoted: 7653 Post(s)
Liked 3,483 Times
Turns out it was a squeaky saddle---the mount where the rails pass through the clamp apparently squeaks a little. I don't know how to stop it .... but it is a lot less frequent a a lot less loud, and since I know what it is, it hardly bothers me.
Likes For Maelochs:
Advocatus Diaboli
Liked 1,533 Times
Or with summer here.. ice cubes clinking in your water bottle.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Yeah, make to sure to check saddle, seatpost and BB. I’ve had all those make weird noises. Once I had a click only on high torque pedaling. Turned out it was the joint of the drive side crank arm to the spider and is the reason I only use one piece crank arms now.
Good luck’
Otto
Good luck’
Otto
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
You may have said it and I didn't note, but try a bit of oil at each spoke intersection. I had this issue with a set of wheels that ended up needing sent back to the factory.
Lol, I know you bike doesn't have them, but my fenders played a mind**** on me for quite a while with gravel bouncing off.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Questions
Try wearing you tennies, no cleats required. Hey it’s a cheap test.
Does it click if your not in the saddle?
Does it click if you pedal backwards?
Does it click in all gears? Both rings?
Does it click if stationary, brakes applied, pressure on pedals?
Barry
Barry
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
BTW - if the click is chain related, bike in a straight line, constant speed, and count time between clicks.
Although the clicks won’t relate to crank position, they will come at regular intervals.
Barry
Barry
Bikes: 2000 Litespeed Appalachian, 1998 Litespeed BlueRidge.. 1977? Schwinn LeTour 12.2 'Rain Daze'
Quoted: 64 Post(s)
Liked 17 Times
THIS above ... or sticking link.. & possible rear de binding and making chain rub onto next cog. I'll vote chain/rear de related. One link starting to spread... ?
Had one other day.. retired 77 yr old that thinks bike maintenance is for naught. Light clicking.... chain slight rub onto next cog... he fails to bring chain over for regular cleans and length inspects. We live in sand country BTW............ you know that drill.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Also, mud and gunk and other debris clogging up the plates next to derailleur pulleys ( or on the pulleys) can make little noises whenever you pull chain and it may be periodic but at the pulley rate, not the crank rate.
Otto
Otto
Since the sound is not constant, I would think it is coming from the bottom bracket bearings. Change your bottom bracket, as someone else mentioned.
Advocatus Diaboli
Liked 1,533 Times
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Ok today I had another noise source that I don’t think I’ve had before: the large chainring on my road bike (first gen Dura-Ace) has a small metal post that was rubbing against the drive side crank arm at the bottom of the drive side pedal stroke only while standing on hills.
Made a bit of a scraping metal on metal sound just at the bottom part of the pedal stroke when the forces and bending are the highest. I could also get a bit of a creak by pushing inward and down on the pedals by hand.
On the bike, I thought front derailleur was low and touching the chainring or frame flex was letting the inner ring nudge the frame (or maybe the BB was about to fail). Didn’t think that post could be the culprit but the noises quit the moment I put some lube on the end of the post.
Otto
Otto
Clark W. Griswold
Quoted: 4362 Post(s)
Liked 4,006 Times
Is it cranks hitting a cable end? That is a common one. As are loose quick releases
Advocatus Diaboli
Liked 1,533 Times
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times
Check the chain. May be worn out. I had recently had an annoying click. I thought it was the seat or seat tube. Standing it went away. My chain was way overdue. Replaced to and the cassette. Click gone ........................................for now.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
It has always been a saddle or a stem for me. If it happens when I am out of the saddle, it's likely the stem. If it happens with my hands off the bars, it is likely where the post connects to the rails. Both easy fixes.
Quoted: 1743 Post(s)
Liked 1,281 Times
Facebook Post
Sr Member on Sr bikes
Years ago I had a friend something like this happened to. After several trips to his LBS...where it wouldn't happen on the workstand...and replacement of a few components, it was discovered that the 'clicking' was caused by the heel of his shoe hitting the excess front derailleur cable that was bent outward and it was clicking back against the seat tube.
Dan
Dan
