Are QR Disk Hubs dead?
Quoted: 321 Post(s)
Liked 263 Times
So I'm building a new frame on which I ideally wanted disk brakes with QR axles. Yes I know about wheel ejection but I know how to do up a QR and I consider life to be complicated enough without bring thru-axles into it. But it seems such hubs are very rare these days, especially in 130mm spacing.
Is this true or am I just lousy at searching for bike parts? Am I better to grasp the bull, take the bullet by the horns, bite the nettle and just go with thru-axles?
Liked 9 Times
130 disc never took off as 135 and then 142, boost etc became normal on all disc bikes. 130 disc places the flanges too close together so it makes the wheel as a whole weaker. Literally the only issues I see with thru-axles as a busy as fook bicycle mechanic is them not being greased. They are much more idiot proof than QR generally.
Quoted: 6972 Post(s)
Liked 10,969 Times
I don't know much about this, but I suspect your best bet is to find T/A hubs that are convertible to QR with different end caps.
Better yet, go with T/As. If you don't like carrying a hex, get these.
Likes For Koyote:
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
Yes, you can still find convertible disc hubs but the QR and narrow width are going to be increasingly marginalized. If you are starting from a clean slate, thru axle is the best choice. IMO, the primary advantage with TA and discs is that you get consistent fit when you remove/replace the front wheel. When you are dealing with a mm or two differentiating a chirping brake from a quiet ride, the QR introduces an unwelcome variable.
Likes For shelbyfv:
Quoted: 714 Post(s)
Liked 800 Times
130 disc hubs were a rare thing even when 130 was the road standard. I doubt anyone is putting any effort into making them now. If you insist on sticking with QR, I would suggest building a frame with 135mm spacing.
Edit: Novatec is still making them https://bdopcycling.com/product/d352sb-11/
Likes For dsaul:
Quoted: 321 Post(s)
Liked 263 Times
Thanks for the answers everyone! That clears things up a lot. I did see a few 135 QR disk hubs so I'll think about whether to go with those or with "road" stuff and thru-axles. I'm assuming MTB disk calipers are compatible with road hubs? I don't see why not but nothing surprises me these days when it comes to bike part compatibility.
It's a kind of a hybrid/touring bike with a flat bar and MTB hydraulic disks. 68mm BB shell will be the best for keeping the "Q" value low, which is desirable for this rider. I know chainline doesn't matter so much but I usually pair 68 with 130 and 73 with 135.
Quoted: 2026 Post(s)
Liked 1,096 Times
Likes For HillRider:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I would not worry about going 135mm rear with with 68 bb width. There are lots of stock frames that come that way. My Soma Fog Cutter is an example.
I’m fine with QR discs, but TA is really a better system, and no more complex.
Likes For Kapusta:
Quoted: 1944 Post(s)
Liked 2,164 Times
It sounds like you are building this frame for someone else. If that is the case, I can understand wanting to use QR instead of TA; especially if it would be your first TA build.
John
John
Quoted: 321 Post(s)
Liked 263 Times
It is for someone else but it's my second TA build. And the last 3 frames did not require any last-minute dropout-filing for alignment (which you obviously can't do with TAs) so I think I've got the hang of the process.
As a professional bike mechanic I friggin hate QRs with disc breaks. They are way less consistent in axle positioning and create disc rub. Also they are less stiff and create rub. They are also easier for riders to mess up. I hates them. Keeping QR/disc bikes running rub free is a major time suck for me on our rental fleet in particular. It does help very much to switch all the QRs to enclosed cams.
Still pretty easy to find though. In 130mm disc was very short lived/much maligned, what is out now is mostly 135mm. A pox upon the Specialized SCS standard in particular--only two friggin hubs work (a 24h Specialized, and a rare Hope model), and only used for a year or two.A lot of recent road drivetrain stuff has been redesigned for a slightly wider chainline because discs/gravel. Really the 135mm spacing on an older road drivetrain was only a practical problem when the chainstays were really short.
A lot of current generation Surlys are designed with interchangeable dropout systems that'll run some combination of (or all of ) 135QR/142TA/148TA for those people who really want to drop $700 for a new frameset then throw decade old parts on.
Likes For cpach:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Quoted: 800 Post(s)
Liked 512 Times
I replaced my QR with a Robert Axle Project thru axle this year. Yes, it is a bit more work to get the wheel on and off, but for me it was worth the investment.
hounslow Are you sayin thru-axles should have a bit of grease on them?
Quoted: 321 Post(s)
Liked 263 Times
For no engineering reasons manufacturers make road and MTB stuff incompatible on various levels. There are way around it in some cases. But for a flat bar bike it is best to stay with MTB side of stuff. That also is cheaper and you have more options and much better quality. MTB equipment is built to be shaken around and get wet.
To answer my original question it seems like QR road disk is not only dead, it hardly ever existed in the first place.
Yes that's the conclusion I've come to. Touring bikes are often a weird mix of road and MTB parts but I think I'll just go MTB with everything. Probably 68/135 unless the crankset is expecting 73 anyway (and has spacers if you're 68). And then I could go QR, although many in this thread have made a good case for TA.
Nowadays both use TA and disc brakes. Some exceptions exist, but they get fewer. The only reason to use an old standard is if you already have valuable parts. But for new, buy the new.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
QR 130mm disc, on the other hand, hardly ever existed in the first place.
Most recent bike models/frames have changed over to thru-axles. However, I bought a Soma Saga disc brake touring bike with QR dropouts less than two years ago.
@cpach is right: QR with disc brakes is an inferior technology, but with good internal-cam skewers or DT Swiss skewers, they can behave reasonably.
Likes For Cyclist0108:
Quoted: 514 Post(s)
Liked 450 Times
QBP still sells disc brake wheels with QR to dealers. Trek is still making disc brake hybrids that use a traditional QR in back with a modified QR in front. I believe all their low-end Marlin hardtails still use QR.
Let me put it this way. If I were making a high quality frame I wouldn't be putting cheap or outdated wheels on it.
Quoted: 140 Post(s)
Liked 163 Times
+1 to that. As a shop owner who carried two different brands of bikes roughly ten years ago that equipped bikes with 130mm qr disc wheels, and later had customers wanting to upgrade the wheels on these bikes, obviously tied to the same standard....yeah. 130mm rear spacing on a disc brake equpped bike: a true dinosaur at this point.
Those cheap (cheap for Trek to build, not cheap for the consumer) LBS bikes are just 1% above Walmart bike... please don't get design ideas from those BSOs with a fancy name.
Advanced Slacker
Liked 2,537 Times
Oh for cryin out loud.... there is nothing low end or “walmart+” about a qr disc wheel or frame.
Chris King, I9, Hope, and DT Swiss (240) all make qr disc hubs.
Part of going custom is not having your choice dictated by bike manufacturers and posers.
Anyone who mistakes a custom road frame with a Chris King wheel-set for a low end bike because the rear hub was QR rather than TA is a freaking moron, IMO. And anyone taking their opinion seriously in building a bike is in the same league.
Also, I don’t think 135mm QR disc is going anywhere. My guess is that it will outlast whatever current version of TA is most popular. The industry will keep refining and changing the TA “standard”, and whatever TA you buy now will get phased out eventually. But QR will quietly endure as a more “standard” standard.
I think it will be like square taper BBs. How many BB standards have come and gone over the past 20 years? Yet ST continues quietly humming along in the background.
Likes For Kapusta:
Occam's Rotor
Liked 2,331 Times
Chris King stopped making them, but plenty of other high-end hubs have that option (I just ordered one).
My very expensive custom bike came with a QR rear dropout and a QR Enve CX fork in 2014. (The following year, he switched over to thru-axle, but I am not going to toss a custom frame because of the dropout). At some point I might upgrade the fork to thru-axle, but only if I want something like a Lauf or Spork, not because of the dropout. (I did find it absolutely crucial to get good internal cam skewers -- Dura Ace -- to prevent the issue @cpach describes.)
I did make certain to order wheels with hubs (White Industry in my case) that allow both QR and thru-axle conversion, to future-proof the wheels.
I am not a frame builder, but if I were, I would build with modular dropouts.
Advanced Slacker
Liked 2,537 Times
I do see that CK stopped making them. Interesting, I saw them available not too long ago. I had just done a google search and saw them for sale, but it looks like most places are out of them. I do see that CK lists an axle to do a conversion.
