Are You A Spinner Or A Grinder Up Hills?
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
Do you stay seated and spin when climbing or you more of a stand and grind kind of rider?
I've always had great leg strength and I've always been more of a grinder. On my ride routes, mostly flats, rolling hills with a few steeper climbs, I feel better standing and grinding a big gear over sitting and spinning. This is using vintage mountain or road bikes and old school toe clips, cinched tight, pushing and pulling each stroke.
If a longer climb I will shift to a smaller gear as needed but normally try to grind it out and recover after getting over the peak.
Likes For Desert Ryder:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,644 Times
Reformed grinder and now a spinner, except on short punchy climbs, where I am out of the saddle. And/or on long climbs, I stand occasionally to break up the spinning.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Thread Killer
Quoted: 3148 Post(s)
Liked 1,713 Times
Standing/seated and grinding/spinning are not interchangeable. Grinding or spinning is just about pedaling speed, and it’s possible tp pedal at different speeds when either sitting or standing.
That said, as a heavyweight cyclist, I’m almost always seated for climbs, and because I run out of gearing very quickly on slopes, I’d have to say I’m also a grinder, although if I have the power to keep cadence up, I do, so I’m a grinder out of necessity rather than desire.
Climbs send me into the red zone on both HR and power very easily and without any competitive return in speed , so I need to manage output carefully, and being seated and pedaling slower both can help in that tegard.
Likes For chaadster:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times
Having ridden up the back side of Gates Pass in a 52/15, sitting down, I was a magnificent grinder in my youth.
Now I'm a would-be spinner, and a wheezer, too.
Likes For Fredo76:
Likes For Mtracer:
Having enough gear options AND not having strong enough legs, I'm a total spinner.
Also there are less risks of injury when spinning than forcing too much on the pedals ("too much" depends on each person).
Likes For samonzeweb:
Quoted: 3241 Post(s)
Liked 2,512 Times
Likes For seypat:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 569 Post(s)
Liked 772 Times
Grinder.
Ex power lifter, so I have the leg strength. All of my pedal power comes in at lower heart rates and lower cadence levels - I have a lower max heart rate than many, spinning at high power for long durations cause me to blow up.
Likes For Jughed:
Quoted: 1364 Post(s)
Liked 1,678 Times
At 62, I spin more than I used to, but I still enjoy getting out of the saddle and hustling a bike up a steep hill...just not as often.
Likes For BobbyG:
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
my lower spine prefers I stand as much as possible and spin. Grinding out climbs seated hurts my herniated L2, L3, though racing cyclocross since 2015 has given me more seated capabilities.
Likes For RB1-luvr:
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 219 Post(s)
Liked 847 Times
Mostly a spinner, unless the gradient is too steep to spin. I do alternate between sitting and standing, but I'd hardly call my standing grinding...My standing cadence is typically 75-80 rpm, which is fast for standing IMO. Sitting is 90-100rpm. I rely on my current cardio fitness to keep the heart rate down on such efforts.
Is seating at 50-60 rpm still considered spinning? Relative, I guess. Seated normally, but I do stand occasionally to stretch or when it really gets hard.
After suffering from knee pains for a couple of years, I became a spinner.
That doesn't mean I don't grind sometimes, mainly when I don't have a lower gear available or when I'm standing.
I only really stand to relieve my bottom after long hours, when I want to go really fast on a short climb, sprint to catch up a friend, or accelerate swiftly.
Likes For Amt0571:
Liked 2,512 Times
It seems like there is a general rule about weight/height ratio which determines whether you should sit/spin or stand/grind. Something like over 2lbs/inch you should sit and spin.
Quoted: 822 Post(s)
Liked 1,961 Times
Primarily slow spin in the 80 rpm range but will frequently stand for about 20-40 pedals to work different muscles and give my behind a break.
Much depends on the steepness of the grade and length.
If in the 10%+ range, I will mostly sit and spin out of fear of blowing up before peaking.
My road bikes are 34:34 and 30;27 low gear ranges and my rigid MTB that I ride on road is a 24:34 so I have very low gearing to spin.
Thread Killer
Liked 1,713 Times
Quoted: 506 Post(s)
Liked 639 Times
Or more generally, under 140 lb (10 stone, 65 kg) standing works pretty well. Over 170 lb. (12 stone, 77 kg) you spend too much energy keeping that body weight going up and down. Beyond the numbers, personal preference dominates.
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,912 Times
Depends on which bike I'm on. My old bikes have slightly better than "period correct" gears for 1980s racing bikes, like 52/42 x 13-26, so with them it's 'sit and grind", whereas my Canyon has 52/36 x 11-34, so with it I sit and spin. I also take it up longer hills than the old bikes. Since I weigh just a bit over 200 lbs, I don't do much out of the saddle climbing, though I'm working on that.
Likes For genejockey:
Quoted: 967 Post(s)
Liked 1,631 Times
Seat? Who needs a seat?
That was the old days... Ha
Now days my balance is so bad I have to stay in the seat just to stay up. For me its a sitting spinning climb into the hill, transitioning into a slow mash, transitioning into an unsteady dismount...
AND THEN THE WALK OF SHAME!
Likes For zandoval:
