Is it safe?
Is it safe?
I just joined to ask this question, so hello everyone and thanks in advance for hopefully providing some guidance.
I recently had a mishaps with my top-of-the-car bike rack (it's the style where the front wheel is removed) where I significantly bent the dropout, I believe it's called (if not it's the little u-shaped piece at the end of each fork blade that the front wheel's axle sits in). I was able to *pretty much* get it back to normal with a pair of pliers and a lot of elbow grease, but it's not exact and as a result the wheel is slightly off center (I'd post a photo but it looks like you need 10 posts before you can do that). The wheel feels quite secure, but the misalignment is substantial enough where I had to remove the front brakes since they were permanently rubbing against the wheel.
My question is whether -- putting aside the fact that the bike now only one set of brakes -- this bike is safe to ride? I have a road bike that I use for more substantial rides -- I only use this one for commuting to the train station and running errands around town and such. My preference is to keep using it, but I'll pick up a used bike if I'm at risk of my front tire coming off while I'm ripping down a hill.
Thanks for any thoughts.
Bikes: yes, i have one
Quoted: 1144 Post(s)
Liked 1,186 Times
Sounds like you only ride this bike a couple of miles from home for short errands. Somewhere I heard that most accidents occur a couple of miles from home. Something to consider.
You could always get get a new fork.
climber has-been
Quoted: 3439 Post(s)
Liked 3,579 Times
Replace the fork. It is bent.
Even commuter bikes should be in workable condition.
Likes For terrymorse:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Here I thought we'd be discussing Marathon Man.
Quoted: 2952 Post(s)
Liked 3,106 Times
Likes For caloso:
Bikes: my precious steel boys
Quoted: 438 Post(s)
Liked 603 Times
Having no front brakes is more like having 1/8th the proper amount of brakes on your bike than 1/2. Replace fork etc.
Quoted: 1825 Post(s)
Liked 1,700 Times
Figure out how to repair your fork. Front brakes are much more important than rear brakes unless you never ride much faster than a walking pace
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Besides the brake issue, you're also running an interesting experiment every time you hit a bump with a wobbly wheel. That will likely not end well.
New fork or stop riding the bike. You really could get hurt bad.
