Campy shifters and shimano RD
Bikes: 2014 Cannondale Synapse Carbon 4 Rival; 2014 Cannondale Trail 7 29; 1972 Schwinn Suburban, 1996 Proflex 756, 1987(?) Peugeot, Dahon Speed P8; 1979 Raleigh Competition GS; 1995 Stumpjumper M2 FS, 1978 Raleigh Sports, Schwinn Prologue
Quoted: 213 Post(s)
Okay friends,
I'm restomodding (sort of) a Schwinn Prologue. It came with mostly DA 7400 but with Suntour hubs. A friend just gave me some campy hubs laced to Mavic rims.
Quick question: the DA 7400 RD wouldn't happen to work with 8 speed campy indexed shifting would it?
Bikes: Schwinns: Paramount (Waterford), Peloton (1986 and 1999), 1987 Super Sport. Offbrand bikes: Bianchi Intenso, Diamondback Interval TG (Ironman), Peugeot Triathlon, Masi CX
Quoted: 35 Post(s)
Liked 7 Times
8 Speed Campy is an orphan.
5.0mm cog spacing (same as Shimano 7 speed)
More here:
Shimano cog spacing, derailleur, and shifter compatibility
More here:
Bikes: s-1
Quoted: 221 Post(s)
unfortunately no, it won't work, unless you run it on friction, then it *might* if you can find a chain that plays nicely with the different parts. now that I think of it, make sure the campy chain has the same pitch.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Campy 8 speed will shift your RD at 6.66mm cog spacing. That's not even close to anything.
You'll need Campy 11 to shift old DA (74xx) in either 7 or 8 speed mode.
Hubbub cable routing gives you 5.5mm spacing, good for an old standard spaced 6 speed.
It's all here: SHIMERGO
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Bikes: s-1
Quoted: 221 Post(s)
I know the campy chains are narrower 5.5mm vs 5.6mm for shimano, I just wasn't 100% sure they have the same pitch (spacing between the pins), but it appears they do.
this article has great info: https://cyclingtips.com/2014/10/mixi...d-what-doesnt/
Quoted: 213 Post(s)
Thanks. So in other words...just buy a darn Campy 8 speed RD as well. I was hoping I wouldn't have to, but that's ok.
Quoted: 213 Post(s)
Bikes: s-1
Quoted: 221 Post(s)
you could just run it on friction, and then the shimano RD should work. you won't be able to use the indexing, but with 8 speeds that's not a huge issue. I would try it before you sink money into it, but at least the RDs are fairly inexpensive compared to the rest of the system. get a KMC 8 speed chain for like $15 and don't worry about it, they are cross compatible, and will shift perfectly on friction.
the saddle is crap (those vaders are like $10 on ebay) but the hoods and brakes look updated, and the pro 4 tires are good rubber. just looks like it needs pedals, cables, bar tape, and a saddle of your choice (and the chain of course).
Quoted: 443 Post(s)
Liked 27 Times
All are 1/2".
Quoted: 213 Post(s)
I have a set of 9 speed DA bar ends I thought about putting on and running as friction, but I kind of do want ergos. 8 speed Campy RDs aren't cheap though
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Now those 9s DA bar ends will run the 74xx series RDs in 8s mode, but Shimano 8s spacing is 4.8mm and Campy is 5.0mm. If you set it perfect on cog 4/5, then the max you're out is about 0.6mm-0.8mm on either end of the cogset. It's not Ergo, but it "may" solve your immediate cost issue.
Quoted: 213 Post(s)
Quoted: 7348 Post(s)
Liked 2,465 Times
Pitch is distance between the links (pivots) and is always 1/2" as Grand Bois says. By pitch, you must have meant width.
TallRider
Bicycle Mechanics
11
09-22-18 08:56 AM
idoru2005
Bicycle Mechanics
7
06-07-10 02:47 PM
