Bike Friday Trailer hitch
Old 09-24-17, 10:47 AM
gdlerner
Bikes: Pocket Llama
Quoted: 28 Post(s)
Hi fellows
I own a BF trailer never use it before I was thinking I will take it to my next adventure .
I wanted to tried it today and I can fit the hitch to my bike I own a Pocket Llama with rohloff external box gears and the hitch collapse with the external box see the pictures.
I wanted to change the hitch for the carry freedom lollypop and it s not working also because I need to drill a new hole on the lollypop ,because the holes in the trailer are from the side.
I was thinking maybe use this
Trailer Accessory - Trailers
get another hose for the trailer and in the hose put the elastomer llolipop
Carry Freedom Lollypop elastomer
What do you think or maybe another better idea?
Thank you
File Type: jpg
File Type: jpg
gdlerner is offline
Old 09-24-17, 10:56 AM
CliffordK
CliffordK's Avatar
Quoted: 12045 Post(s)
Liked 1,253 Times in 973 Posts
What about using the Bike Friday hitch adapter.
https://store.bikefriday.com/product...qsrbprfeis0062
It should fit just ahead of where all the hub stuff is. I'm surprised it didn't come with your bike.
You might be able to get a local welder to make something similar if purchasing/shipping is too big of a hassle.
CliffordK is offline
Old 09-24-17, 11:32 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,289 Times in 806 Posts
Alternatives, A) spacer and a 145 tandem hub QR skewer,
B) Thule-Chariot ball and socket hitch.. Interesting to note the company you link to uses the chariot hitch on the carry-freedom city trailer..
https://shop.planet-used.com/shop/en/...railer-51.html its a perfect match there , (My Brompton tows It)
but the red lolly and pin on the Y frame..
C) Burly hitch
I have a Co Op era Burly Alternative hitch.. (I got 9 years ago) the hitch and QR are integrated into one item.
I have it on my Rohloff Koga world tour.. https://www.backcountry.com/images/it...LY0016/ALL.jpg
My BiFri Rohloff Llama has the brazed on fitting for the air hose connector , ( its a threaded sleeve brazed on the upper stay)
NB ( readers)you could have specified it be fitted on the order specs the frame and bike was built to..
( My bike, a refused BTO someone else ordered)
fietsbob is offline
Likes For fietsbob:
Old 09-24-17, 12:28 PM
gdlerner
Bikes: Pocket Llama
Quoted: 28 Post(s)
My bike didnīt come with the hitch adapter on the frame like other BF they forgot it and for this small peace 39 pluss shipping to Germany.... I will find somebody to build something will be much cheaper
gdlerner is offline
Old 09-24-17, 12:35 PM
CliffordK
CliffordK's Avatar
One of my bike friday bikes came with the 1/4" NPT pipe welded to the frame.
One came with that little adapter. I can take any photos you like, although you should be able to work on the dimensions from the tubing size on the bike.
I did use the adapter on my old Colnago, but it seemed to have worked itself loose on the tapered rear stay tubing. I believe the BF tubing doesn't have a taper, so that shouldn't be an issue.
Old 09-24-17, 01:33 PM
CliffordK
CliffordK's Avatar
If you bought everything new from Bike Friday, Bike, Rohloff, & trailer kit as a single package purchase, and you're missing a part (or were sent incompatible parts), then I'd send them an e-mail and ask about the adapter.
It is quite possible they would just drop it in the mail for free.
The worst they can say is NO.
Old 09-24-17, 01:39 PM
gdlerner
Bikes: Pocket Llama
Quoted: 28 Post(s)
I already did but the trailer I bought it online used like new
Maybe I can just make an extension of the arm with a hose and put there the lollipot I will see
gdlerner is offline
Old 09-24-17, 02:10 PM
berlinonaut
Quoted: 313 Post(s)
Liked 10 Times in 8 Posts
You can mount the Rohloff shiftbox the other way round (cables facing upwards) - I had to do this on one of my bikes. Looks like this could free enough space. A bit more of a change (but with success guarantee) would be to get rid of the external shiftbox completely and to switch the Rohloff to internal shifting.
berlinonaut is offline
Old 09-24-17, 02:24 PM
gdlerner
Bikes: Pocket Llama
Quoted: 28 Post(s)
I use to have internal shifting, one year ago I changed all my bikes to external much better and easy to fit on the road
gdlerner is offline
Old 09-24-17, 02:55 PM
gdlerner
Bikes: Pocket Llama
Quoted: 28 Post(s)
Or maybe I tried to adapt this hitch
https://www.amazon.com/Sunlite-Trail...+trailer+hitch
gdlerner is offline
Old 09-24-17, 05:03 PM
fietsbob
Bikes: 8
SO? replace the 2 shift cables so the external shift box faces up* it will take a little more cable to reach the new location..
* Its Been Done.. read the Manual . its on page 32 'cable routing, external gear mech'..
fietsbob is offline
Old 09-24-17, 08:25 PM
2_i
Bikes: Trek 730, Bike Friday NWT, Brompton M6R*2, Trek 830, Trek 720, Dahon HAT060, Dahon HT060,...
Quoted: 461 Post(s)
Liked 91 Times in 72 Posts
What about Burley Hitch Adapter? Then you could stay with the BF hitch. Its disadvantage is an increase in the transverse size, but principally for BF there is so much dismantling anyway that you can take off the adapter for packing.
2_i is offline
Old 09-25-17, 10:10 AM
fietsbob
Bikes: 8
its a nut with an extension He shows a QR Skewer, not the threaded TS axle..
fietsbob is offline
Old 09-25-17, 10:49 AM
invisiblehand
Part-time epistemologist
invisiblehand's Avatar
Bikes: Jamis Nova, Bike Friday NWT, STRIDA, Austro Daimler Vent Noir, Haluzak Horizon, Salsa La Raza, Hollands Tourer, Bike Friday tikit
Quoted: 120 Post(s)
This sounds like the best bet to me.
A narrative on bicycle driving.
invisiblehand is offline
Old 09-25-17, 10:54 AM
fietsbob
Bikes: 8
The fitting is just an industrial air hose quick disconnect..
Brazed onto the frame is a tubular threaded ring, that should be easy for a metalworking fabricator to make..
the QR can be used to hold it down ...
fietsbob is offline
Old 09-25-17, 11:30 AM
zebede
Hello
zebede's Avatar
Bikes: n+1
Quoted: 98 Post(s)
Liked 14 Times in 13 Posts
If I understand correctly, Pic number two shows the hitch mount, and you took the picture to show the conflicts.
Why don't you just put the hitch plate in a vise and put a bend in it so that the hose connector is farther away from the shift box, while keeping the plate flat around the axle QR area.
Alternatively, could the trailer tongue be reversed on the trailer so as it connects to the drive side of the bike , and therefore mount the hitch plate on that side?
zebede is offline
Old 09-25-17, 11:26 PM
2_i
Quoted: 461 Post(s)
The adapter comes in different versions, including QR skewer, though a longer skewer might be needed.
2_i is offline
Old 09-25-17, 11:53 PM
CliffordK
CliffordK's Avatar
If it is steel, you should be able to come up to a full 90°, and still have a little room, although perhaps it doesn't need to be bent that much.
You could probably bend it either hot or cold.
Old 09-26-17, 12:27 PM
gdlerner
Bikes: Pocket Llama
Quoted: 28 Post(s)
I just contacted BF and the are always so helpful they make a special hitch for people with external Rohloff so I ordered one.
Thanks for all the suggestions
gdlerner is offline
Old 05-01-20, 06:56 AM
gdlerner
Bikes: Pocket Llama
Quoted: 28 Post(s)
Hi guy
can some one please tell me where do I need to measure the hitch to upgrade to weber coupling (they have different size )the small tube 1 or the big part 2with the nuts
Thanks
gdlerner is offline
Old 05-01-20, 07:58 AM
2_i
Quoted: 461 Post(s)
Hi guy
The photo is really tiny/low resolution. Are you sure that part 2 is original? To me it looks like some extension that someone made to keep the trailer a bit farther away from the bike, presumably one that is full size. I do not have such a short tube addition and it is not there in any BF trailer images that I can see on the web. For the folder I do not think that you need the short tube at all. I.e. you can take it off and measure at 1.
Once you get some experience with the Weber coupling, can you please describe it? While I have used Radical Design coupling with the BF trailer, I thought about going the Weber route as it looks very versatile.
2_i is offline
Old 05-01-20, 08:51 AM
gdlerner
Bikes: Pocket Llama
Quoted: 28 Post(s)
I have no idea if this part is original I bought my trailer on ebay some years ago was sold as a reconditionar heavy duty.
Wich hicht are you using? Do you have a link? I wa thinking buying this parts
https://www.weber-products.de/de/sho...product-id=414
https://www.weber-products.de/de/sho...product-id=317
gdlerner is offline
Old 05-01-20, 10:46 AM
2_i
Quoted: 461 Post(s)
https://www.radicaldesign.com/hitch-ball
https://www.radicaldesign.com/hitch-trailer-side
I also needed a piece of a steel reinforced pneumatic hose + hose clamp and bolts to finish this off. Mounting the Weber coupling could be more straightforward from the trailer side.
These are exactly the parts that I wanted to try out for the start. One longer term issue is of the pressure on mounting on the axle - my current best kickstand on the folder is there too and there is not enough axle length to mount both without serious risks.
2_i is offline
Old 05-01-20, 12:32 PM
Jipe
Quoted: 200 Post(s)
Liked 39 Times in 34 Posts
I have a Brompton with a Rohloff with external gear box and I can use the standard Radical Design hitch ball with my Cyclone IV Chubby trailer without any problem,
Jipe is offline
Old 05-01-20, 01:03 PM
2_i
Quoted: 461 Post(s)
The one below is the standard for Brompton, when nothing interferes. The arm grabs the chainstay and prevents rotation. By putting the ball backwards you can reduce lateral size.
2_i is offline
Copyright Đ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
