Vintage Lugged Frame to Allroad/Gravel Grinder
Quoted: 20 Post(s)
It was the 1990 750 that shared a frame with the 520 of the same year. The 720 shares geo but not the tubing, I believe. Rides like a freight train and fears no gravel.
It was mentioned once so far, so ill reiterate- early 90s Trek hybrid.
there were lugged models for a few years, some were made with quality DB true temper tubing, and at least one model had the geometry of a 520.
anyways, they are lugged, 700c, fit 40mm tires, and dont look kludged together when drop bars are added.
The early 80s sport touring bike conversion is great, but tire size is usually still pretty limited. I like 40mm for the gravel that i ride. Comfortable and stable.
my brother in law did a conversion on a trek 750 multitrack. Awesome frameset to work with.
Sempiternal Newb
Bikes: '92 Trek 750, '85 Univega Gran Turismo, '95 Stumpjumper,
Quoted: 232 Post(s)
Liked 15 Times
Can also confirm that they ride like a freight train and fear nothing. The bottom bracket is high on these, making it feel like you're riding a monster truck. Also capable of carrying super heavy loads with no sweat:
The 520 is currently getting rebuilt as a singletrack slayer/bikepacking rig, and the 750 is getting rebuilt as a randonneuse-style sport tourer.
This '84 Trek 510 is supposed to be my gravel-grinding rig but I have yet to really ride it on any gravel. Currently running 32 GravelKings but it will fit 35s on 700c rims with stock Dia-Compe brakes.
Quoted: 741 Post(s)
Liked 818 Times
'73 Super Course with 28c Pasela, could go wider, Campy large flange hubs, Mavic MA40 rims, Weinmann centerpulls with Koolstop dual compound pads. I have a Sugino AT triple, 32/40/50, with a Shimano Megarange 6 speed 34t in back, shifted by Suntour VGT Luxe, and Suntour bar ends. Cyclone II handles the triple front. I also have a compact Sugino double that I might try since we both survived this year's Eroica. Nice bike, first build for me from a found bare frame. Done two part gravel/pavement rides, fun on both surfaces.
Quoted: 214 Post(s)
Liked 1,528 Times
Remarkable timing on this thread from my perspective in that on Monday I picked up a 1992 Trek 750 multitrack in the white color that was a bit rough.
I decided to strip it down to bare metal and run it that way for a time.
I have between 7 to 8 months or so on another frame I have done this strip down to bare metal.
It is rust free with maintenance of wiping it down about every 6 weeks with a WD-40 equivalent.
Perhaps a pain for some folks to do this but I like the look and don't mind the maintenance to keep the rust at bay.
I keep it in the garage and do not ride it in the rain.
Tuesday I stripped the paint off the 750 and on Wednesday built it up with parts I had on hand.
I am enjoying a ride on it this morning in its new state.
Those cheap Kenda tires on it measure 34mm and I am thinking I can get at least a 44 or 45 mm wide tire in there.
I am looking at prospective new tires for it very soon.
Interestingly for two years Trek offered a 790 Multitrack in 1990 & 1992 according to the Vintage Trek site as a step above the 750.
I saw that the specs showed the 790 and 750 frames with the same tube and fork
with just different parts.
When I stripped the bottom of the bottom bracket shell I found this frame was stamped 790 along with a 23 for the frame size.
It is currently set up as a 1 x 7 but I will be changing to a double crank soon.
I went ahead and installed the front derailleur in anticipation of this soon coming change.
Now I need to find some gravel to grind on this thing.
Quoted: 214 Post(s)
Liked 1,528 Times
tiredhands,
Love the bar tape on your 510.
Is your 1992 750 the white color?
That is what mine started out.
I made an attempt to lighten your pictures but I'm not sure how much good I did.
Sempiternal Newb
Quoted: 232 Post(s)
Liked 15 Times
45's seem to fit according to this guy's PedalRoom page. Looks like my dream of running Rock and Roads on a vintage frame will come true sooner than I thought!
The 750 looks great!! I can fit 42s on my Seral just fine. Maybe even 45s would fit but it would be very close.
Bikes: 1975 Motobecane Grand Record, 1976 Motobecane Grand Record, 1971 Raleigh Super Course, 1983 Univega Gran Turismo, 1983 Univega Alpina Ultima, 1960s Raphael Geminani, 1994 Trek 820 Bafang ebike
Quoted: 18 Post(s)
Liked 41 Times
Late 83 Univega Gran Turismo
42mm 700c Soma Vittesse EX on CR18 rims measure 37.5 mm wide. Plenty of room and stock cantis adjusted easily for 700c rims. Will build a little wider rim wheel set and have enough room for fenders
Quoted: 18 Post(s)
Liked 41 Times
650b conversion, bike co-op centerpull 40mm fatty rumpkins lotsa clearance. If you can get past the swiss bottom bracket cups, I found an eBay sugino with spindle for a triple, they are wonderful on the dirt and gravel.
Quoted: 18 Post(s)
Liked 41 Times
The post inspired me. Why not ride the old Motor-Beacon! 5miles , 499 ft of alt gain got my heart started
Quoted: 823 Post(s)
Liked 1,396 Times
I went the other way regarding gearing - this is my '73 Raleigh Competition Mk. II set up with 35mm Continental Cyclocross Speed tires and stock Weinmann center pulls. The drivetrain is 44/42T chainrings with a Surly Dingle fixed 17/19T cog on one side and a White Industries Dos Eno 20/22T freewheel on the other side. I get a 70-in fixed-gear for pavement, a 60-in fixed for gravel, and the option of a 60-in coastie or (should I feel brave) a 52-in gear for gentler single track. It works nicely for me!
PeterCT
12
09-26-18 09:10 AM
Seanmichael
20
12-08-16 10:57 AM
