Go Back  Bike Forums > Bike Forums > Framebuilders
Beginner questions on brazing equiptment - Part 4, Lenses
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 09-07-18, 02:42 PM
bikingman
Quoted: 12 Post(s)
Lenses
  1. What shade lens do you use for brazing steel frame?
  2. What color lens works best for you?
Look forward to reading this discussion and feel free to answer questions if you need any clarification.
Dan
bikingman is offline
Old 09-07-18, 04:22 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,392 Times in 1,927 Posts
I use a #3 or #4 green lens for brass and blue Didymium glassblower's glasses for silver.
JohnDThompson is offline
Old 09-07-18, 06:44 PM
bikingman
Quoted: 12 Post(s)
Thanks again John, and sorry for being a novice - but when you say brass and silver, you're referring to the filler rods?
Old 09-07-18, 07:15 PM
TiHabanero
Quoted: 1740 Post(s)
Liked 1,369 Times in 718 Posts
I have been in the hunt for new glasses as the #5 lens is just too dark. This last frame I didn't use any eye protection at all and it was so nice to see things clearly! The blue lens referred to has a "number" for darkness? Does it give a less dark view than the standard #5 dark lens?
TiHabanero is offline
Old 09-08-18, 04:10 AM
dsaul
Quoted: 713 Post(s)
Liked 796 Times in 473 Posts
#5 is way too dark for brazing. I used to use a B3 series glassblowing lens from Wale Apparatus https://www.waleapparatus.com/category/wale-wear when I was fillet brazing. They are a bit pricey, but it makes it easier to see the difference between molten flux and molten brass.
I switched to TIG welding, but I still braze in bridges and braze ons. I usually just use a pair of dark sunglasses for those tasks.
dsaul is offline
Old 09-08-18, 07:36 AM
unterhausen
Randomhead
Liked 3,684 Times in 2,508 Posts
#5 is too dark for anything. I use it for gas welding, but even then seeing is tricky. I use a combo #3/ace for everything. Unfortunately, I think that combo isn't available since the last batch failed. I might just order some ACE glasses for silver, the shaded glasses are too dark for my tastes, and I would rather be able to see better for silver. My understanding is that didymium by itself isn't adequate for brass.
unterhausen is offline
Old 09-08-18, 10:49 AM
bikingman
Quoted: 12 Post(s)
Good to see those differences on the workpiece, nice plug - thanks
Old 09-09-18, 09:48 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,835 Times in 2,293 Posts
I'm using currently Phillips 202s glass blowing eye ware currently, partially because they make them in magnifiers and also because they mimic the dydimium glasses I got in 1979 and got use to. I like their ability to change the flux flare and see through it better. Andy
AndrewRStewart
Andrew R Stewart is offline
secrettrek3
General Cycling Discussion
37
10-30-14 07:19 PM
dkyser
Road Cycling
56
09-26-14 10:22 PM
hamster
Road Cycling
20
02-08-13 12:58 AM
hyhuu
Road Cycling
15
02-22-12 11:40 AM
chasingcars191
Road Cycling
7
12-12-09 08:49 PM
