Please help ASAP, front derailleur locked up
Old 10-21-19, 11:13 AM
Liquidspacehead
Quoted: 20 Post(s)
Liked 4 Times in 4 Posts
My front derailleur has stopped moving all together. The shifter also doesn't seem to be reading the gear correctly I will be attaching pictures. Any help is appreciated
Liquidspacehead is offline
Old 10-21-19, 11:30 AM
pdlamb
Quoted: 1073 Post(s)
Liked 114 Times in 83 Posts
Top picture looks like there's some rust on the derailer. Take a finger or two and pull the front derailer cable outwards from the downtube. If the derailer moves, the problem's in the shifter or cable housing. If it doesn't, prepare the penetrating oil "bath"!
pdlamb is offline
Old 10-21-19, 11:35 AM
Liquidspacehead
Quoted: 20 Post(s)
Nothing moved. What now? I have a video as well but it wont let me post it... anyway what could the problem be? Something seems locked. The shifting doesn't seem to anything at all to the derailleur
Old 10-21-19, 11:41 AM
*Scuba
Made in Taiwan
Bikes: Camerotti ti roadbike, Old Sears Free Spirit Tange Hi-Ten Single Speed built from a 12 speed, 1997 Cannondale CAD3 r500 with Shimano 6400 groupset
Quoted: 26 Post(s)
Have you tried the following? When the front mech does not shift properly, I work down the list to see what is the cause.
1) Push on the front derailleur itself, the easiest point is the pivot arm where the cable is pinched. Can the derailleur move back and forth.
- If the derailleur cannot move, something is seized or broken
- If the derailleur moves, but does not snap back into the lowest gear default setting, spring might be gummed up
2) Try pulling on any exposed front shift cable, can you get the front derailleur to move back and forth and change gear whilst you rotate the pedal?
- If you can get the front mech to move and shift gears, problem is not the derailleur or cable/housing but the shifter itself
- If the front mech cannot move, even when you pull very hard on exposed shift cable, the cable itself is most likely seized within the housing due to corrosion
3) Push and click through your shifter, is the tactile feeling positive? I only do this step after I have gone through step one and two.
- If the pawls are not catching properly, shifter might be gummed up and need a solvent flush and relubricate
- If you feel the pawls catching and releasing normally, most likely a cable/housing issue. For example a worn cable and housing or cable tension is too low.
All dogs want to be lap dogs doesn't matter the size
-Animal loving friend
*Scuba is offline
Old 10-21-19, 12:34 PM
jimc101
Quoted: 345 Post(s)
Liked 13 Times in 13 Posts
Not seeing any significant rust on the FD, and Shimano FD's are pretty rust-resistant.
What happens when you undo the cable? the FD should return to the lowest position, and you should be able to manipulate it with your hands at this point.
When the cable is undone, you can also see if there is any resistance/lack of movement if you use the shifters.
One other thing, it looks like you spend a lot of time in the middle ring, sort of hard to tell from the angle of the photo, but the chainring looks a little pointy and you may want to consider replacing it (the middle ring) at some point.
jimc101 is offline
Old 10-21-19, 01:16 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1896 Post(s)
Liked 229 Times in 164 Posts
Disconnect the cable from the derailleur and operate the shifter. Does the cable move smoothly and easily when disconnected? If not, you may need to lubricate the shifter, replace the cable and/or housing. While the cable is still disconnected, use your hand to move the derailleur cage in and out. Does it move easily (taking spring tension into account) and smoothly? If not, the derailleur needs lubrication. Lubricate freely until the unit moves easily and smoothly. Reconnect the cable, check adjustment, and it should be ok.
JohnDThompson is offline
Old 10-21-19, 03:02 PM
freeranger
freeranger's Avatar
Bikes: 06 Lemond Reno, 96 GT Timberline mtn.bike
Quoted: 72 Post(s)
Liked 65 Times in 53 Posts
A long shot, but it happened to me once--have you checked to see if a small stone might have gotten thrown into the der. and is stopping it from moving? Also--looks like both high and low limiting screws are turned in the same amount--hardly ever see that-might be ok on yours, but looks odd to me.
freeranger is offline
Old 10-21-19, 07:53 PM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1289 Post(s)
Liked 103 Times in 88 Posts
Are you turning the crank while trying to move the derailleur by hand? Unless the chain and crank are moving the derailleur can't shift it and will appear "locked up". Incidentally, your pictures tell me next to nothing by themselves.
HillRider is offline
Old 10-21-19, 09:31 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1999 Post(s)
Liked 169 Times in 133 Posts
One thing I see in the photos is a well worn middle ring. The tooth profile at about 11:00 is getting pretty scallaped/sharp tipped.
As some have mentioned it's easy to separate each component of the system and test each. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 10-21-19, 10:27 PM
Slightspeed
Slightspeed's Avatar
Quoted: 606 Post(s)
Liked 323 Times in 189 Posts
I had a broken Tiagra FD, and it turned out to be the black, coiled tension spring that snaps the derailleur cage back and forth. The fix was to upgrade to an Ultegra FD. I don't have the pieces any more, or I would post a picture.
Heres an article I found regarding a broken spring on Tiagra:
https://www.******.com/r/bikewrench/comments/5tok4o/fix_broken_spring_front_derailleur/
Slightspeed is offline
Old 10-22-19, 09:06 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1441 Post(s)
Liked 142 Times in 93 Posts
Cable not routed correctly. Read the instructions.
trailangel is offline
Likes For trailangel:
Old 10-22-19, 10:04 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 523 Post(s)
Liked 145 Times in 110 Posts
I suspect that the cable is incorrectly routed, as @trailangel said. This will make the derailleur movement very stiff at the shift lever, but not necessarily lock it. Many front derailleurs have a washer with a tab under the cable pinch bolt, and the cable is supposed to go over the tab, which may be non-intuitive when you are setting it up.
To the OP: did you do any work on the bike before it stopped working? Like adjustments to the derailleur? It is a possibility that the two limit screws are turned in too far. Their job is to stop the derailleur from moving past the inner and outer chainrings, and if they are turned in to far they can stop the derailleur moving almost completely.
Wilfred Laurier is offline
Old 10-22-19, 10:21 AM
Liquidspacehead
Quoted: 20 Post(s)
I recently changed the gear cable and I dont believe I shifted the shifter correctly before reinstalling the cable. I am leaving town for a festival but for now I took my derailleur off and removed the cable to essentially run a ghetto 1x to get me to and from work just for the last day I am in town. And then I will keep you guys posted on the end result. Also a small piece of metal fell out of my shifter once i removed the cable (that was REALLY in there idk why my cable was so jammed) but now it seems to shift flawlessly. So we will see when I return! Thank you all
Old 10-22-19, 05:08 PM
trailangel
trailangel's Avatar
ASAP help response was given... you need to cancel any plans going forward and fix this ASAP to satisfy the forum.
