External ”Hollowtech” bearings or square tapered cartridges?
Hi everyone!
As the title says, but I’m thinking about the durability factor.
A crankset/bottom bracket similar to my actual ones (currently SunRace FCM918 with Shimano UN-BB26, looking for a Shimano FC-T4060 with Shimano BB-SM52) is about 2.5x more expensive here in Brazil. Is it at least as durable as it costs?
SE Wis
Quoted: 2750 Post(s)
Liked 3,406 Times
Well, I've replaced a cheap cartridge (Chin Heur) after a few K miles with a UN55 that probably has 5K miles on it and running fine. I probably have 10K on an 105 BB5600 HTII bottom bracket that is running fine.
Either one should give years/miles of trouble free service unless you're riding in very extreme conditions.
I would forget the UN 26 and step up to a UN 55 for a few more $$
Likes For dedhed:
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Hi everyone!
Likes For AnkleWork:
Quoted: 4214 Post(s)
Liked 3,891 Times
For the numbers of external to shell bearings (Hollowtech) sold and their relative mid to better grades (as they are on more expensive bikes typically) I will say that we replace a lot. For the most part these are not really rebuildable and are regarded as disposable by the industry.
The tapered square BBs seem to be of better sealing in general and don't wear as rapidly. Especially since they are so much more common at the lower cost levels one might think their longevity should be less then external units. But our experience doesn't prove this assumption out.
I'm sure others will have their opinions, perhaps they can offer some ideas as to how many they see a year so we know the foundation their opinions are based on. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
SE Wis
Liked 3,406 Times
Likes For dedhed:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
After faffing around with a White Industries square taper BB (a good, but rather expensive one) for a couple of years, I went back to the $18 Shimano Ultegra BB, and it felt the way it does when I stop hitting myself in the head with a hammer.
@Andrew R Stewart: sample size = 1.0
Edit: I just remembered my Crampy square taper BB survived about 35 years of malignant neglect.
Likes For Cyclist0108:
Non omnino gravis
Likes For DrIsotope:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Not sure what your problem is, but everyone else understood it just fine.
Likes For ThermionicScott:
Quoted: 3257 Post(s)
Liked 2,099 Times
I’ve multiple thousands of miles on Ultegra and 105 level HollowTech b-brackets. They are easy to install, the spacing is dead on with the matched derailer so the shifting is easier to setup and are generally a ton easier to install and/or service than a square taper.
Likes For Steve B.:
Quoted: 805 Post(s)
Liked 2,990 Times
Likes For '02 nrs:
aged to perfection
Quoted: 840 Post(s)
Liked 1,271 Times
I'm with Andrew the external bearings, while they brace the BB spindle better, seem to have a shorter life.
It may be because they are not as well protected, particularly from front wheel splash in wet conditions.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Likes For mpetry912:
Quoted: 2026 Post(s)
Liked 1,096 Times
My experience with Shimano HTII external bottom brackets has been very good. I have two BB6700 (Ultegra level) bottom brackets mounting FC-5703 (105 level) triple cranks with over 25,000 miles each and still in excellent operating condition. These bikes aren't ridden in rain or snow if I can help it but they have gotten wet and splashed a number of times with no apparent problems.
Sample size = 2 but success = 100%
Likes For HillRider:
Quoted: 1438 Post(s)
Liked 1,092 Times
To make a fair comparison you would have to include the weight of the spindle, which the BBR60 does not have but which is part of the BB-UN26.
Likes For dsbrantjr:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Likes For Marcus_Ti:
Non omnino gravis
Even an economy crankset today will be at or under 800g, which with a ~80g BB is still lighter than a higher-end square taper crankset from 20 years ago.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Hambini says a poorly aligned BB shell will cause premature bearing wear. Does a square taper cartridge unit isolate from those imperfections?
Likes For tyrion:
Liked 3,891 Times
To a degree yes. However the shell faces are also about getting the BB (whatever type) securely tightened. A shell with cockeyed faces won't allow the BB RH (usually the RH) side to fully snug up and thus might loosen during use more readily. The other possibility with really off faces is that if the BB cartridge is fully torqued down before the LH locating ring (what most will call a cup even though it's a cylinder) the LH end can drift off center and make installing that LH ring rather hard. This is one reason why I'll not tighten the RH side completely before the LH side is installed. Andy
AndrewRStewart
AndrewRStewart
The reason I’m replacing it is because it’s got some play and misalignment. As I’m still overweight, with 114kg (down from 157kg, all 43kg lost on this BB), I’d thought about upgrading to Hollowtech, if the durability factor worth it.
I don’t ride extreme, but I guess my weight still makes it kinda “extreme-y”, so to speak...
BikeForums’s users have my respect on this regard, as I always got useful answers. That’s probably due to a broader audience, and to reach everyone the common ground is English, so be it.
Please, don’t read that in a rough tone, that’s not my intention. I just couldn’t think of a better way to write it.
Likes For dwsmartins:
