Can this / should this cone come off for painting?
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Thats a crown race. Yes, it has to come off. Head to a bike shop or co op and have them pull it for you. And try not to paint where you reinstall it, as you will have to remove the paint in that area. Quick job with the right tool.
I use a bearing separator for this job. Crude tool that works OK, but not as good as a better tool, like we have at the co op.
Be sure to remove the headset cups on the frame as well, as well as bottom bracket cups.
Likes For wrk101:
Bikes: 2011 Handsome/ Twin Six Speedy Devil, 2006 Soma Groove, 1991 Haro Impulse Comp, 1987 KHS Montana Pro, 1986 Ross Mount Hood, 1986 Mongoose ATB, 1985 Shogun Prairie Breaker I, 1973 World Voyageur, 1941 Schwinn DX "Klunker"
Quoted: 83 Post(s)
Liked 96 Times
I would just mask it off and paint away. If you paid someone to drive it off, you would just have to pay someone to drive it back on. In the long run no difference. Mask, paint.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
Depends on the paint job. If going for a pro job, yeah, you may need to pull the race off the fork crown. If it's a home rattle can job, masking it may suffice. If powder coating, it (usually) must be removed.
I purchased an inexpensive puller tool like this $24 one:
crown race tool on amazon
It works best when getting it in place and working the race off by hitting the tool with a rubber mallet.
To reinstall, I use a 9" long section of 1" pvc pipe and the mallet (or floor).
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Bikes: 1977 Trek
Quoted: 34 Post(s)
Liked 22 Times
Thanks y'all. That answers my question: it's not threaded, it's the same as the headset cups. Wanted to know before I mangled it trying the wrong way.Think I'll take it in to our machine shop at work and see if there's something that can help me get it off. If nothing looks like it'd work, I might just mask it. Or I could stop by a bike shop.
Getting it back on should be okay. We have many sizes of pipe scraps that should work. That's how I got the headset cups off.
Quoted: 3808 Post(s)
Liked 6,681 Times
For steel crown races, I clamp the fork upside down in my vise and tap it off with a hammer and punch. Light taps all around do the job.
Likes For nlerner:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I've done this many times, though nowadays I would use a purpose-made slide hammer. Very light taps working around the circumference will quickly remove it. The crown race seat is only a few mm high so as soon as you get past that, the race will fall off the steerer tube.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
But if you take it of you need a crown race milling too to clean the paint off
Sugar "Kane" Kowalczyk
Quoted: 3810 Post(s)
Liked 3,335 Times
If you do take the fork to the shop, take it there after painting to have the surface faced before a new headset crown race is installed. This wasn't always done on production bikes. (I don't know what kind of bike this is)
