French BB Velo Sq Taper + SunRace 9spd Crankset
Old 03-28-20, 11:02 AM
loubikes
loubikes's Avatar
Bikes: Bianchi Volpe 2001, Bianchi Brava, Bianchi Mondiale
Quoted: 29 Post(s)
I'm upgrading a Motobecane's drive-train and I don't know too much about bike mechanics beyond the basics (yes, glutton for punishment and financial woes).
I'm cold-setting and upgrading to 9 speed.
Here's my question:
Do you foresee any problems or missed-considerations in my decision to use these two components? The crankset requires a spindle length of 103, which is the length I will purchase from Velo Orange.Thanks!
loubikes is offline
Old 03-28-20, 01:13 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
You might want to check with SunRace to ensure that the crankset taper is JIS to match the bottom bracket; it probably is but I did not see that specified and I am a belt-and-suspenders kind of guy..SunRace
dsbrantjr is offline
Likes For dsbrantjr:
Old 03-28-20, 01:23 PM
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,471 Times in 2,079 Posts
Also the bottom bracket might be swiss threaded, not French, in which case the BB you are buying will not work. In a French BB, both sides are right hand threaded; in Swiss, the fixed cup is left hand threaded.
https://bikeretrogrouch.blogspot.com...m-bracket.html
Many Motobecanes do have swiss threaded BBs. They are also harder to find but not impossible. IRD sells cups for swiss threaded BBs and that may be the least expensive option.
https://www.interlocracing.com/shop/...bottom+bracket
You will want to post this question along with pics of the bike in the C&V forum. They may be able to help you sort out whether your BB is French or Swiss.
bikemig is offline
Likes For bikemig:
Old 03-28-20, 01:38 PM
loubikes
loubikes's Avatar
Quoted: 29 Post(s)
Great, I'll definitely do that, thanks!
loubikes is offline
Old 03-28-20, 01:42 PM
loubikes
loubikes's Avatar
Quoted: 29 Post(s)
Thanks bikemig, I actually have the BB off now ... EXCEPT for the fixed cup. I have now broken two 1/2 bolts trying to remove it using Sheldon Brown's suggested method for BB removal. Really wondering if it's Swiss but I can feel the threads from the other side and I'm 99.9% certain they are right-hand threads. I'm only second guessing what seems obvious because it's just not budging. I soaked it in PB blaster for a week and then broke the 2nd 1/2 bolt.
Going to take it to a bike shop to see if they can remove it I guess.
loubikes is offline
Old 03-29-20, 08:39 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3587 Post(s)
Liked 3,400 Times in 1,934 Posts
Are there any markings on the fixed cup face? If you're lucky, they will explicitly give the thread spec: "35 x 1" for French; "35 x 1 P1 S1" for Swiss. But older components may have more arcane markings:
Source: Sutherland's 4th Edition
JohnDThompson is offline
