Indoor & Stationary Cycling Forum From spin to Zwift to Peloton, this forum is dedicated to any and all indoor training on stationary bikes
Cooling best practices
Old 05-16-20, 12:46 PM
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 896 Post(s)
Liked 613 Times in 409 Posts
Looking for optimizations people have to stay cool riding indoors.
I have a blower fan. I have tried both normal race jerseys for wicking sweat for evaporative cooling and no jersey.
I want to try some more stuff. Just doing intervals I still heat up a lot. I feel like something like 2 or 3x20min might be near impossible with heatup.
I have considered buying a cooling vest like construction workers wear. Or putting ice packs in a thin cloth in my jersey pockets. Also have considered routing a hose tube setup from the blower outlet to zip up to my jersey front.
Whatcha got?
burnthesheep is offline
Old 05-16-20, 07:13 PM
SlvrDragon50
Quoted: 44 Post(s)
Liked 13 Times in 9 Posts
Maybe a misting fan? What kind of blower fan do you have? I'm using a box fan which is working pretty well for me. I sweat an absolute ton, and my apartment is probably around 78*F, but the fan works well.
SlvrDragon50 is offline
Old 05-16-20, 11:54 PM
clasher
clasher's Avatar
Quoted: 185 Post(s)
Liked 41 Times in 34 Posts
You could try a dehumidifier or even an a portable a-c? My setup is in my loft so it gets hot in the summer so I will try a window a-c but will likely just end up riding outside.
clasher is offline
Old 05-17-20, 08:23 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3118 Post(s)
Liked 472 Times in 350 Posts
No worries.. Rapha has you covered
https://www.rapha.cc/gb/en/shop/indo...roduct/IDT01XX
https://www.rapha.cc/us/en_US/shop/s...roduct/IDC01XX
On a more serious note.. I typically just wear a sleeveless or short-sleeve mesh baselayer.
Sy Reene is offline
Old 05-18-20, 04:05 AM
jpescatore
Bikes: Trek Domane SL6 Disc, Jamis Renegade
Quoted: 241 Post(s)
Liked 116 Times in 92 Posts
My indoor trainer set up is in the basement, so it is naturally cooler than the house temperatures upstairs. A $20 tlltable 16" floor fan has more than enough air movement to keep me cool - I still sweat up my clothes, but not pooling sweat on the floor at all. And I sweat pretty heavily.
Is your fan big enough/close enough? On some of these YouTube videos I see people using 6" fans 10 feet away - that wouldn't do it for me.
Someone else mentioned a dehumidifier: 2 years ago I had my hot water heater in the basement replaced with an energy saving unit that actually incorporates a heat pump for one of the heating elements. That ends up essentially "air conditioning" the basement, both lowering the temperature but more importantly lowering the humidity. After that went in, I found I could lower the fan speed from high to medium, I think mostly because of the noticeably drier air in the basement. A duhumidifier might be worth a try.
jpescatore is offline
