What's the pre-load torque for a Chris King 1-1/8" threadless headset?
Old 05-23-20, 09:16 AM
masi61
masi61's Avatar
Quoted: 619 Post(s)
Liked 90 Times in 67 Posts
I like the front end of my bike to be as taut as possible. I seem to notice that the front end of my bike develops a slight bit of slop in the handling about once a year. So I loosen my stem bolts and verify that the fork plug is snug enough and then re-do the preload on my cap bolt (without a torque wrench) and finally make sure my stem bolts are tightened correctly.
The tautness is there now, but I fear I may have overdone it with the pre-loading of the sealed bearings on the Chris King headset. I thought I felt a slight bit of notchyness but the handling on the road is good and no hands riding is good. Does anyone know if these Chris King bearings will be damaged if I go (slightly) overboard snugging up the fork plug cap screw?
masi61 is offline
Old 05-23-20, 09:53 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2496 Post(s)
Liked 566 Times in 437 Posts
https://cdn.shopify.com/s/files/1/29...63412763896395 Scroll down to final assembly and adjustment. BTW this took about 45 seconds to find. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 05-23-20, 10:48 AM
masi61
masi61's Avatar
Quoted: 619 Post(s)
Thanks for the link. I suspect I put more than 6 to 15 inch pounds of torque on the cap screw. I like the way the front end is handling though.
masi61 is offline
Old 05-23-20, 11:12 AM
bitpuddle
Bikes: Cinelli Nemo Tig / Battaglin Power Plus / Giant TCR SL
Quoted: 17 Post(s)
Liked 9 Times in 7 Posts
Just enough to hold the headset together. As soon as you can apply the front brake and rock the bike back and forth without movement in the headset, you’ve tightened enough. Barely more than finger-tight.
If your headset loosens, you might have issues with the frame prep (head tube not faced/parallel, unevenly reamed, too of steerer not cut at 90 degrees, etc).
bitpuddle is offline
Old 05-23-20, 11:35 AM
stevoo
Stevoo
Bikes: Road and mountain tandems, single bikes too.
Quoted: 30 Post(s)
Deleted
stevoo is offline
Old 05-23-20, 02:34 PM
Crankycrank
Quoted: 287 Post(s)
Liked 93 Times in 76 Posts
+1. I never use torque readings for headsets. Easy way to check for sure is to put everything together, lift bike with the front end pointing down, turn front wheel and let it return to center on it's own. You want it to be just tight enough so the the fork just starts to move freely without any binding. No more, no less. Removing the handlebar so that the cables don't interfere with movement is necessary though. As bitpuddle mentioned if you're having problems with a CK headset loosening you may need to check everything noted.
Crankycrank is offline
Old 05-23-20, 02:40 PM
Andrew R Stewart
As an old timer who cut his teeth on soft Campy headsets I learned to set things by rocking feel, after building up the bike. Usually for my own stuff I will fall on the lesser side of the fence as I'll revisit after a few rides. Now that Phil has brought out headsets my CK fling is pretty much over. I did like the CK feel when new but disliked the overhaul process. The tiny balls and lack of much space for grease didn't make me happy. But I will say the CK bearings do last a good while. Andy
AndrewRStewart
Likes For Andrew R Stewart:
Old 05-23-20, 10:46 PM
davidad
Quoted: 441 Post(s)
Liked 65 Times in 59 Posts
The bearings require preload.
davidad is offline
Old 05-23-20, 11:28 PM
Russ Roth
Quoted: 319 Post(s)
Liked 221 Times in 167 Posts
The issue of the headset coming loose isn't the headset, its the stem. The topcap only helps to set the preload but can't hold everything together, especially since it has nothing solid to connect to; a star nut or plug isn't really that strong. Instead its the stem that holds the works together and you need to make sure you're getting that properly tight, typically 5nm is the torque on the stem bolts but after tightening the second bolt you need to recheck the first bolt you tightened and after double check the second bolt. I've had to do as many as 3 checks as one bolt can lose some tension once the other bolt is tightened. Can also use fibergrip if a carbon steerer to help prevent slipping as well.
Russ Roth is offline
Likes For Russ Roth:
Old 05-24-20, 06:28 AM
Litespud
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor S/S, Nashbar 3sp commuter
Quoted: 355 Post(s)
Liked 316 Times in 179 Posts
if I’m reassembling my front end (King threadless h/s, carbon fork) I get everything in place then give the stem a few GENTLE taps with a rubber mallet right at the steerer end, to ensure that everything is “bedded in” before I screw down the top cap. Once the stem bolts are torqued and both checked, the front end holds adjustment indefinitely. IIRC, the top cap torque is on the order of 2-3 Nm, but I usually do this by feel. I do torque the stem bolts, though
Litespud is offline
Likes For Litespud:
