Half cartridge BB service
Old 06-26-20, 05:07 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 2050 Post(s)
Liked 643 Times in 443 Posts
I pulled this out of my kid's Hotrock, which I am rebuilding with slightly better parts. I am planning to replace it but sort of slacked off on the project and want to get him on the road. I can clearly clean and lube the adjustable side but is there anything I can do about the fixed side, other than drip some oil on it and try to work it in? I can't find any clip to remove to separate the assembly. The fit seems to be a little loose so I guess there arenít any rubber seals and it will square up when adjusted
It's 118 mm spindle for 68/73mm English BB (it had an idler that's getting replaced with a spacer), so at least replacement is no big deal
Darth Lefty is offline
Old 06-26-20, 05:08 PM
Darth Lefty
Disco Infiltrator
Photo thereof
Genesis 49:16-17
Old 06-26-20, 05:40 PM
alcjphil
alcjphil's Avatar
Quoted: 995 Post(s)
Liked 329 Times in 220 Posts
Are you sure that you can't pull the drive side BB cup off? Give it a try. You would then be able to lubricate the drive side bearings
alcjphil is offline
Old 06-26-20, 05:44 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2526 Post(s)
Liked 599 Times in 456 Posts
One should be able to set the frame on it's RH side and flod the shell/cup/bearing with solvent, air blast out the remaining and finger squeeze in grease. Awkward for sure but not at all hard to do. But removing the RH cup is the WAY. There are methods to secure cheap plate wrenches wrenches on the cup with the axle and it's nut/bolt. Then one can leverage or hammer away and not be too worried about wrench slip. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 06-26-20, 06:34 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 1318 Post(s)
Liked 736 Times in 504 Posts
I suspect you tap the spindle on the drive side while holding the cup the DS comes apart as well.
dedhed is offline
Old 06-26-20, 07:40 PM
Darth Lefty
Disco Infiltrator
Thanks everyone. I'll give it a shot
Genesis 49:16-17
Old 06-26-20, 07:45 PM
HillRider
Quoted: 1456 Post(s)
Liked 270 Times in 219 Posts
Do you have a bench vise? If so, open it up enough to allow the rim of the DS cup to rest on the jaw edges. Then use a soft mallet to pound on the end of the spindle and the cup should pop off.
HillRider is offline
Old 06-27-20, 07:00 AM
tomtomtom123
Quoted: 316 Post(s)
Liked 100 Times in 71 Posts
A new Shimano BB is around $12 here.
tomtomtom123 is offline
Old 06-27-20, 07:04 AM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 18930 Post(s)
Liked 2,376 Times in 1,745 Posts
...this. I was running into these at the bike co-op a lot before I left. After a couple of tries I just started replacing them with something else.
3alarmer is offline
Old 06-27-20, 05:42 PM
Darth Lefty
Disco Infiltrator
Indeed it did just tap out the other side. Thanks everyone who contributed ideas
Genesis 49:16-17
