Max tire width 1987 trek 400t
Looking for advice on max tire width that could be used with 87 trek 400t. Looking for something a little wider to use on pavement and gravel.
Thank You
Thank You
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,704 Times
I have an 86 400, mine will take 700x32 without fenders. Or 27 x1 1/8"
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Veteran, Pacifist
Quoted: 3907 Post(s)
Liked 4,853 Times
What's good?
Schwalbe Marathons = flat protection.
FMB PR = suppleness
FMB PR = suppleness
Liked 1,704 Times
If you like the cushy tires- there's the Rene Herse tires. But they're kinda pricey.
Quoted: 754 Post(s)
Liked 737 Times
I've got 28mm Pannaracer Gravel Kings under fenders on a 1989 Centurion Sport DLX. They seemed pretty well balanced on the supple vs. weight, durability and cost scale. I'm not a small person these tires are a very nice ride. I'm sure 32's would be even nicer.
I will check those out! Thanks for the tip
Thanks for the tip. I have champagne taste but beer budget so the pricey ones are probably not an option
