1x Setup for a road bike
Quoted: 778 Post(s)
Liked 1,790 Times
Looking for anyone that lives in a flat area that is running a 1X setup on their road bike. What are\were your experience, how long have you been running it\run it, and are you happy with it, if not, why.
I have a bike I would like to update the drive train on, and before putting a 2x system on it, I started thinking about going with a SRAM AXS Force 1x setup. I have no climbing outside of a bridge here and there and rarely ever touch the small chainring. If you are using something like this, what chainring size and cassette size are you running. I am looking at a 44 or 46 chainring with a 10-33 cassette.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
I occasionally swap out the chinrings on my all-road/commuter whipto a 1x. Normally , I run a 50-34 chainset, but when I go to 1x I use a 46t. I am running a n11-34 cassette. It’s fine for the low hills around me. Honestly 44t might be a better gear. You won’t be smashing KOMs, but you also will have a simpler set up.
Quoted: 778 Post(s)
Liked 1,790 Times
Thanks. Yea I am not too worried about the KOM or Strava segments, could care less about any of that. I just like riding my bikes, and try to keep my almost 60 year old body in somewhat decent shape due to the ice cream problem I have.
Likes For jaxgtr:
Quoted: 2333 Post(s)
Liked 2,097 Times
I live in a hilly area and run 1x SRAM red 12 speed. 48T with either an 11-34, 11-36 or 11-39 in the back 12 speed. I'm thinking of going to 46T and 10-33
Likes For GhostRider62:
Quoted: 3293 Post(s)
Liked 2,124 Times
Ummm.... this has been beaten to death. Did you do a search?, many, many responses as to likes, dislikes, etc.....
Quoted: 778 Post(s)
Liked 1,790 Times
Yea I did , and I did not see anything specific to my question. BF searching is weak at best unless you hit the exact term. A lot of what I have seen in the past is for people that have hilly or mountainous terrain, where I am pancake flat. So apologize for those that are offended by my thread.
Likes For jaxgtr:
A 46 chain ring and even a 10-28 should work fine. I rode up an 11-12% grade today in a 46/32, but I climbed 14,278 feet this week over 188 miles. I need a 46/30 crank and 10-36, so I can pedal seated on most of these steep climbs.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 766 Post(s)
Liked 4,067 Times
I’ve got a 48/10-50 1x 12-speed setup on my road e-bike. My area is fairly flat, probably average 20-25 feet of ascent per mile. I occasionally ride with zero added power. It fine. Fine enough that I’ve been thinking of going to the same set up on my Roubaix. I’m not in the small ring terribly often except on a few punchy hills in the area. And with the 1x, I actually have a greater gearing range.
Liked 2,124 Times
Quoted: 778 Post(s)
Liked 1,790 Times
NP, And I agree that search can be useless sometimes. My take on 1x is its great for mt. biking where there might be a lot of quick occurring ups and downs with a lot of shifting. I have 2 mt. bikes with 1X and find I shift a lot more often than on my road or gravel bikes. I'm not a fan of 1X on the road as I prefer much tighter gearing than whats typical on a 11-46 or 11-50 mt. cassette. My road bikes are 14-28 (34/50 crank) or 12-25 (30/46 crank). I get away with this as I'm on Long Island where its mostly flat. Even our local north shore hills are doable with the gearing I have. I do use my gravel wheels for upstate, its an 11-34. I really do like those one tooth gears though, really nice for rollers and when its windy (we get a lot of wind).
Bikes: GR300, Grail, Live Wire, 5010
Quoted: 189 Post(s)
Liked 241 Times
I’ve been running a 1x on my “road bike” for 2+ years now and I don’t see myself ever buying a 2x again. I live and ride near the WNC mountains and do a lot of climbing, but living in a flat area would make it even easier. I use a 42T and a 10-50 cassette.
Canyon Grail
Canyon Grail
Likes For sarhog:
Quoted: 1463 Post(s)
Liked 1,488 Times
I run a 44T with an 11-32 for road riding. It's fine around here on flat roads and small rollers, I have no problem keeping up with the group road rides that I do. This gearing would suck for big climbs, but I never see those.
This is on a CX bike with road tires (I have two wheelsets) - I'm not going to race crits or win any bunch sprints with this setup, but for the group and solo riding I do it's fine.
I prefer to run a 40T for CX racing, so I do some 'ring swapping depending on the time of year. 40T is fine for solo road, but a bit too small for group rides. I can still manage, but it's not ideal. 46T would be perfect for road riding, but this size is likely too big to swap with a 40T without adjusting chain length.
Likes For msu2001la:
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2137 Post(s)
Liked 1,649 Times
Quoted: 778 Post(s)
Liked 1,790 Times
I typically float between 80 and 90 on avg, running a 50 up front and in the 15 to 19 cogs in the back, sometimes if I have a solid wind at my back, I venture into the 90's. This is why I was thinking with either staying with a 46, or possibly, the 44 up front and the 10-33 in back would be fine, as the tallest thing around here is 105ft bridge. There is one bridge that is 8% on one side and 7% on the other, and a very short climb, but I do not ride that one too often, but should not be an issue getting over it with a 46/33, will just be a little tougher than if I had the small ring with the 25,28,33 cogs.
Liked 2,097 Times
Think more like a 40 or 42T
Your cruising speed should have you using the 13, 14, 15 a lot. Not the 17 and 19
Liked 1,488 Times
It's worth comparing the exact gear ratios on different size cassettes to see where those jumps occur. All of SRAM's 12sp cassettes have single gear jumps on the small half. The 10-28 adds in that 16T cog, giving you 8 gears that are single tooth jumps.
If I had SRAM AXS, I'd have zero hesitation about running a 44T 1x setup with a 10-28 cassette for road riding. With my current setup (11sp with 44T front and 11-32 rear) I don't think I've ever used the 44x32 on the road.
Quoted: 778 Post(s)
Liked 1,790 Times
If I compare the Domane which has the 46/33 and 10-33, I find myself in the 13-15, and 17 for the most part. Mostly 15\17 right now as I am getting used to the new setup when I look at the same speed and cadence. The Emonda is still running the Shimano 11 speed which is what I am looking at possibly changing out. Everything is based on the wind and if I was prudent in my route selection. Sometime the winds decide to screw me over though.
Liked 1,488 Times
For me, a 46/10 is too big for anything other than out-of-the-saddle sprinting or massive tailwind group-ride situations. At a casual 90rpm, 44/10 is still good for over 31mph. A 42/10 at 95rpm would do the same. 42x28 is just barely bigger than a 46x33.
Quoted: 778 Post(s)
Liked 1,790 Times
I started looking at bikecalc and based on that I agree that a 42 44 might be the better option with the 10-28. My speed if I am by myself is generally 18-21 on a cadence between 80-85 and I am comfortable with that pace for 3 to 4 hour rides. So slight variations for weather variables should make those a good match. Even if I went with a 10-33, I would still be in a good range with a 42 tooth front.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Quoted: 989 Post(s)
Liked 1,657 Times
I would start with a back up wheel set. New or used. The times I have had a problem with my bikes that did not allow a ride it were usually related to the wheels and wheel set. Having a decent back up set it a gem...
Liked 2,097 Times
For The Fun of It
Liked 1,649 Times
If there's a chance you might use the bike in the mountains or in hilly terrain, I'd consider a wider gap cassette in the back and a smaller ring in the front. With a 40 in the front and an 11-42 out back, your 90 cadence would give you 25.6 MPH. You'd hit 34 MPH before you spun out. My riding style is like yours and I have ridden this combination. It never left me wanting. It did serve me well the several times I took it into the mountains. That's something the 46 and 10-33 would not have done.
Long winded way of saying that if all you will ever ride is flat land, you can't really go with a bad combo. If you might hit the hills, consider a wider range in the back and smaller in the front.
Liked 2,097 Times
A 40T with 10-28 SRAM 12 speed would be very good for your cruising speeds with your cadence. You'd have the 10-12 used only for tailwinds. The 40x28 would be more than sufficient for that bridge over the intercoastal. The small steps from 15, 16, 17 would be good in a freshening breeze.
Quoted: 778 Post(s)
Liked 1,790 Times
Bike Calc is a great place to play with gear combinations. At your 90 cadence your 44x10 would give you 31 MPH. How often would you pull that on the flat land that you ride? You'd be going over 40MPH before you ever spun out (120 rpm) with that kind of gearing. If all you will ever ride is flat terrain, you'll have gear combinations on the high and low end that you'll never need for your 90 cadence.
Likes For jaxgtr:
