Chain doesn't wrap around lower pulley when it's on the lowest gear on the
Quoted: 531 Post(s)
Liked 475 Times
Sure there is - sometimes it's too much effort to downshift the front and upshift the back, if you're not going to cross-chain for long just use the forbidden ratio. It's likely going to wear your transmission faster, drag more and maybe make noise, so don't make a habit of it, but occasionally there's no great harm.
Likes For grumpus:
Quoted: 3570 Post(s)
Liked 2,990 Times
But of course, you're correct--momentarily doing something wrong isn't going to ruin things--but will result in the effects the OP has brought up. If he doesn't want those effects, most of us know what the solution to that problem is.
Habitual User
Quoted: 5039 Post(s)
Liked 8,270 Times
Liked 2,990 Times
And you don't even need to operate both levers; one will do.
Likes For smd4:
Quoted: 531 Post(s)
Liked 475 Times
Is that derailleur rated for the size of sprocket you have there? It looks too close, but also wound back pretty far. Maybe it's just because the chain is at the limit, could do with a couple more links if that won't make it too long for small-small. Or just don't use big-big, or indeed small-small. But it's nice to have all the gears, just in case you go there. Sometimes the front doesn't shift cleanly under load and you need to push hard to keep going ...
Habitual User
Liked 8,270 Times
There are times when I drop to the small ring and a small cog simultaneously. It gets me roughly the same result as the next lower gear with the same chainring.
Liked 2,990 Times
Something is definitely out of alignment. I'd guess this is a problem with RD hanger, but you said that you have already aligned it. Are there any signs of damage on the RD itself, especially around attachment point? What about the jockey wheel cage?
And no, there's no such thing as "cross-chaning" (and hasn't been since 1990s). Every time someone tries to tell you to "stop cross-chaning" they are simply trying to troll you. Your drivetrain is designed with one purpose in mind: to permit you to use big-big combination - the most important objective of all bicycle drivetrain design in the world for the last 30 years. If you can't use big-big with a modern drivetrain, your drivetrain is broken. If you are avoiding use big-big with a modern drivetrain, you are doing it wrong.
It appears that you are using a RD with a fairly large capacity, i.e. with a long jockey wheel cage. So, given your chain length and chainstay length, in the big-big configuration the lower jockey gets pulled far forward (fairly close to the chainring). This results in the lower jockey "feeling" the effects of chain skew, which might be what's causing the problem. I'd guess that if you installed a [slightly] longer chain, the lower jockey would end up being a bit further away from the chainring and the problem would go away. Or, alternatively, if you used an RD with a shorter cage. Having said that, I'd still note that your chain length looks fine to me.
Liked 2,990 Times
Quoted: 531 Post(s)
Liked 475 Times
I'm not sure his problem is caused by cross-chaining, or at least I think there's something else going on too.
Liked 2,990 Times
Maybe. As a former mechanic, it’s hard to diagnose problems through a device/computer/monitor. We tend to go with the most logical solution with what little information is available.
Quoted: 531 Post(s)
Liked 475 Times
Further back than that: the Sedisport bushingless chain with chamfered side plates was introduced in 1978. Since then riveted pins have been added to the mix to make narrower bendier chains that don't fall apart, but which require special joining links. Those are the major evolutionary steps that saw chain go from 2x5 transmission to 1x12. The narrow-wide chainring may also merit a mention.
Quoted: 4847 Post(s)
Liked 3,979 Times
In one of my better races, state champs, I arrived at the finishing stretch in a field of about 25, very few of whom I could beat in a sprint. My bike was over-geared and I rode much of the race on the small ring but I double shifted to the big-big as we came on onto that stretch about 2 miles from the finish. Mile to go I quietly shifted to mid cog and went from the glass strewn right side of the road and pulled it off. (No, not the win. The break was long gone.) Riding the big-big meant that I didn't have to do anything attention getting when I wanted no one to even notice I was there. I was even with the first rider and going much faster when finally someone said "he's going!"
Quoted: 531 Post(s)
Liked 475 Times
A text forum is not the best place when diagnosis can require looking at something from a very specific angle, or feeling how loose or smooth something is ... what could take ten minutes IRL can last days here and still not get fixed. Why do we even bother?
Liked 2,990 Times
And - a few posters here will get very bent out of shape and go to extremes to point out that you broke some universal rules should they learn you went big-big, especially if it was by choice. I try not to but I don't loose sleep over it and I do make sure it can happen at any time on my bikes and no damage ensues outside minor excessive wear.
Quoted: 1088 Post(s)
Liked 703 Times
Is that like when you're riding in dense fog and can't see the road ahead of you, and all of a sudden you encounter a hill that you didn't know was there? I don't think I'd ride if visibility prevented me from seeing the road ahead. Forget being in the right gear for the upcoming hill - I'd be afraid of running into something.
Quoted: 245 Post(s)
Liked 468 Times
To me it looks like it's just the load on the chain on that gear combo...pulling the chain away from the idler pulley. I think the reason it seems to track properly when pedaling backwards is because the load or pressure against the chain is from the bottom of the chain ring, not the top as it is when pedaling normally. I think the chain length is borderline a link to short which is the cause of the mis tracking. It's not a problem because it is unlikely you are in this gear often or for very long...such a degree of cross chaining isn't good for the drivetrain but most only do it for brief periods. Sometimes you just have to do it...
Try adding one link and see what happens.
You're not really hurting anything an in such cases most people in the same circumstance...chain length, gearing...while riding don't notice it because you are riding and not many put the bike in this gear while it's on a stand except to check chain length.
Liked 2,990 Times
Likes For smd4:
Quoted: 6279 Post(s)
Liked 4,865 Times
Fog isn't involved. Knowing and not knowing that the rise is there isn't involved either. It's just not wanting to do most of the climb in the smaller ring and larger cog and willing to shift into the bigger cog briefly then go back to the smaller cogs after hitting that brief rise. If I'd arrived at that hill in the smaller ring, then I'd stay in the smaller ring. But obviously since we are talking about the large ring, I was coming into the hill with some speed and it'd make little sense to slow down before hand losing all that inertia and shift to the small ring for the climb.
While some try to make this out as what gives less friction, that we know is marginal gains. For those riding their bikes and not competing against and losing to others, it really doesn't matter if they are using a less than perfect combo.
Liked 2,990 Times
The more I read posts here, the more I think people just don't understand how to properly use their gears.
Likes For smd4:
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,539 Times
You abso-freaking-lutely should be able to go big-big on a dedicated 2x system like the OP has. And while it might not be something you want to stay in for long periods (thats open to debate) there is no reason you should need to avoid it for short periods,
I would check if the cage or the hangar is bent. Also, check the length of the chain.
Liked 2,990 Times
So do it, but just not for too long. I'm guessing you don't want to do it for too long because it's detrimental in some way. If that's the case, why do it at all??
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 185 Post(s)
Liked 171 Times
No, it's like when you're riding up a constant grade for a long time and have your near max effort dialed in and then you reach a section that is suddenly just enough more grade for just a brief time to make you want a lower gear.
Sir Mark, Knight of Sufferlandria
Liked 4,865 Times
While I agree with the reasons to avoid that combination, those aren't valid reason to tell someone to never ever use that combination. Nor is it helpful for the OP's issue.
It's about as useful as when some say their bike makes noise when they pedal backwards and I tell them not to pedal backwards.
Quoted: 185 Post(s)
Liked 171 Times
None of this is about being in the most efficient gear combination. It's just about those that want to say never ever X chain in the big/big.
If the OP only has the issue in big + big then the easiest solution is don't do that. Problem solved.
