Drilling out a rusted screw
More of a metal working question I'd imagine but I installed a rear rack many years ago using carbon steel fasteners thinking I'd swap them for stainless in a timely fashion Needless to say I forgot all about them and they rusted in the threads of my aluminum Jamis Coda. One drilled out very easily essentially disintegrating without even using the easy out. On the other I've gone thru five drill bits and only managed to get a single 1/16" off center hole in the broken off flush threaded section of the screw. Really trying to not damage the thread in the frame so what are best practices for drilling out a machine screw ( now just a threaded stud ) from an aluminum bike frame?
Edit: My image loading skills were deficient
"Ezy-Outs" ( I think that's the original tool spelling ) aren't easy to use. Especially for small diameter threaded fasteners. I avoid them completely nowadays.
I found that trying to drill a central hole in the broken off fastener using an ordinary right hand twist drill of let's say around 1/16 inch diameter, involved lots of drill bit flexing and often breakage. Then assuming you get your hole, you next have the challenge of judging when to stop exerting force before the Ezy-Out snaps...
I have less drama using more modern extraction tools, with shorter and stiffer drill and extraction tools. I use tools of this style now ( in link ). Both drill and extractor are on opposite ends of the same tool. And the drilling is done by left handed drills, which alone sometimes winds out the broken fastener.
Alden Grabit Select Series 7 piece Broken-Bolt Extractor Set - 7017P - Penn Tool Co., Inc
The other thing I would say, is do not buy cheap tools in this instance ! If they break inside the hole, you have new problems.
I assume you are centre punching the broken off fastener before drilling.
Edit : Also apply heat to the aluminium before using the screw extractor.
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 167 Post(s)
Liked 150 Times
What size are the carbon steel machine screws?
Rather than relying on EzOuts, you may want to look into using properly-sized left-hand drill bits. They're available in metric sizes too if necessary.
With judicious use of Kroil (or some other available penetrant) ahead of time, you may find that a lefty bit itself provides enough torque during drilling that the screw loosens & backs out on its own.
Whatever penetrant you choose, leave it to soak in for at least twelve hours after application. Twenty-four is even better.
Be careful not to attempt using too large a bit however as you'll thin the screw's wall thickness when drilling, making further extraction efforts difficult as the thinned wall tends to stretch from the torque on an EzOut-type extractor. Try to choose a bit roughly 50 - 60% the core diameter of the fastener to be removed.
Quoted: 535 Post(s)
Liked 475 Times
Quoted: 5885 Post(s)
Liked 2,728 Times
"Best practiice", which is expensive unless you have a friend with a machine shop is removal by EDM. This is how I used to remove broken taps (usually micro-adjust) for frame builders.
Here, I'd start by patient soaking with a proven "rusted screw" remover product like Kroil" or similar. Then use a series of drills to enlarge the hole so you can use a larger EZ out. Since this is a through hole, I'd file or Dremel flush, to make removal by pushing forward possible, hoping the drill does that before going through. In any case, since you started a hole off center, proceed with caution because any drill used to enlarge it will follow the hole, causing a high likelihood of breaking through on one side and cutting into the frame.
Lastly, depending on the size of the eye and amount of surrounding metal, consider that you may have more breathing room, and can use a thread insert if the finished job rather than saving the original threads, which in any case, may already be compromised by rust.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Bikes: Bicycles? Yup.
Quoted: 491 Post(s)
Liked 1,634 Times
Left hand drill bits is my go-to for smaller bolts. Freed this stuck SOB leaving the caliper threads intact.
I like cats.
IDK if this is necessarily helpful but I live in NW DC and have a manual mini mill and center drill bits. If there's a way to easily fixture the frame in the mill vise you could drill a precise hole, after milling out the off angle hole a bit. A drill press might be better. I also have a SMAW/GTAW welder and am intrigued by the one suggestion of welding a nut to the sheared bolt. The powder coat around the boss would almost certainly fry but it might be just a few millimeters under the edges of the nut. You're welcome to come over and give any of that a shot!
Likes For ericoseveins:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
You should normally only use carbide drill bits for such a task.
Liked 2,728 Times
Why?
Quality. HSS is more than adequate to the task. Besides, it would be hard to get adequate speed for carbide to offer a benefit.
Carbide MIGHT make sense if this were a heat treated CrMo cap screw, but we know bit isn't since the OP already drilled it.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 840 Post(s)
Liked 337 Times
With a carbide bit, you do not need to analyze what is before you, and your chances of the hole ending up where you want it are much higher.
Quoted: 535 Post(s)
Liked 475 Times
It's a standard auto mechanic technique, possibly less effective on the 5 mm threads a bike mechanic has to remove. If you don't get good fusion pretty much as soon as you strike an arc you're just getting it hot, so be sure you're aiming at a good clean bit of bolt, and with adequate current. Welding a washer first helps with smaller bolts, because you're not obstructed by a nut so you can see your arc, and work on some sort of bead, rather than just point and hope.
Likes For grumpus:
Clark W. Griswold
Quoted: 4437 Post(s)
Liked 4,089 Times
Just FYI the Jamis Coda is a steel bike and has been a steel bike I think throughout history. The Allegro is the aluminum hybrid they make similar to the Coda.
Quoted: 535 Post(s)
Liked 475 Times
In that case it's probably fairly easy to weld up a ragged hole and drill and tap a new one. Worst case scenario, if surgical removal fails and oversizing to 6 mm is not appropriate.
I like cats.
Quoted: 167 Post(s)
Liked 150 Times
5mm's a small target for welding on a spud, particularly if the broken screw's been drilled into already. If it's stuck in an aluminum threaded fitting, way easy to overheat & melt the aluminum threads, maybe more. Only positive aspect is that aluminum conducts heat so fast a careful attempt just might work.
Quoted: 993 Post(s)
Liked 1,659 Times
Its just a shame how these things can humble us...
Quoted: 167 Post(s)
Liked 150 Times
True enough, but meeting a good challenge head-on is a worthwhile endeavor if you have the experience to make a good show of it.
OP hadn't posted a pic with his opening post.
I just looked again, there's a pic now & I see two holes, one off-center in busted fastener w/ t'other splitting the thread @ ~ 11 o'clock. That second hole into the threads may complicate things a bit.
Likes For spclark:
Bikes: old ones
Quoted: 26468 Post(s)
Liked 10,425 Times
...not sure if anyone has mentioned it yet, but a good point on a center punch, used to mark your start point for drilling with an indent, is usually enough to keep the drill bit from wandering around as you start. If you're careful.
With what you've got there now, I'd be tempted to just drill one of those holes all the way through. The enlarge it a little to the size you need, and rethread it. I presume you're just going to mount another rack.
Likes For 3alarmer:
Clark W. Griswold
Liked 4,089 Times
It happens our intern swore his aluminum Specialized was steel because it is a DH bike and DH bikes are heavy and people have this assumption that steel must be the heaviest when it is not always the case. The Coda has generally been a great bike!
Quoted: 855 Post(s)
Liked 1,088 Times
That top hole that was partially drilled into the threads may actually help some penetrating fluid penetrate further and faster. I would go ahead and carefully finish drilling out the other hole and as mentioned, use some good PF such as Kroil Oil, PB Blaster or if you have some automatic transmission fluid and acetone laying around, mix them 50/50 for one of the best penetrants available. Drip it into the hole and on the end of the broken bolt, let sit for at least 24 hours and without using gorilla strength and an easy out bit keep trying to extract the bolt once or twice a day for at least a week before giving up.
Quoted: 1149 Post(s)
Liked 1,774 Times
I think you screwed the pooch with the off center holes.
Do you have any needle end pliers, maybe the tip ends of some wire cutters may have enough to grab in the two holes.
Quoted: 535 Post(s)
Liked 475 Times
I'd assumed we were talking about bosses on the dropout - seat stays puts a different complexion on it, and the ultimate solution is to unbraze the eyelet and fit a new one, pretty easy if it's actually silver soldered, rather than risking damage to the stay. But before going there I'd attack it with a small carbide burr in a dremel, which would have been a good idea in the first place to create a dimple that a drill could follow.
Quoted: 6292 Post(s)
Liked 4,885 Times
...not sure if anyone has mentioned it yet, but a good point on a center punch,used to mark your start point for drilling with an indent, is usually enough to keep the drill bit from wandering around as you start. If you're careful. placed at 90° to the circumference of the screw and a good hammer blow, the screw will unscrew.
This surprisingly works on very tiny screws. I've done it and seen it done many times. But for tiny screws with the head broken off, you need a very good quality punch with a tiny but sharply squared off edge or point for pushing that screw.
