Crank keeps coming loose
30mi/day commuter
Quoted: 5 Post(s)
My left drive side crank on a garage sale bike I just got keeps coming loose. I re-tightened the nut as hard as I could but it came loose.
I tried replacing the crank with another used crank I had and it has the same problem.
Both cranks are well used. So what should I be looking for/taking pictures of? Crank socket? bottom bracket thing?
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
The crank arm is ruined - the socket has flared. It will have to be replaced. There is no other options short of JB Weld.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Bud
Elitist Troglodyte
What is the protocol for using it on a square taper crank??
- Will Rogers
- Will Rogers
Elitist Troglodyte
Oh, you can do it and it will hold the arm on fine (if allowed to cure). But you'll never get it off.
- Will Rogers
- Will Rogers
Elitist Troglodyte
We're not talking about "wear" here, anyway. The arm was ruined because it was not put on properly (tightened enough) in the first place. Riding it when it loosened up distorted the hole. Once the hole is distorted it will always work itself loose no matter how much you tighten it.
- Will Rogers
- Will Rogers
Oldtimer
Bikes: 1972 Raleigh LTD, 1985 Cannondale SR300 (2), 1986 ROSS Eurotour, 1991 Giant Sedona MTB, 1992 Trek Antelope MTB
https://backroom.hardsdisk.net/giantsedona.html
It's gone through its second hard winter now with no loosening whatsoever. I'm just not sure if I want to bother ever servicing the bottom bracket.
Will it now need a second shim as the spindle works in? Your guess is as good as mine.
