Thinking of doing the unthinkable - getting rid of a 1 month old CAAD 10
Quoted: 14 Post(s)
I have ridden this CAAD 10 on the trainer for a few hours and on the road for about 80 miles and have noticed an issue. Curious if anyone else has this problem.
My thigh hits the cable and cable stop on the top tube. (I might have noticed this if I had taken a long test ride or something, but the opportunity wasn't there.) I've never had this issue on any other bike. It looks as though the cable stop (if that is the correct phrase) is further out to the side than on other bikes I have had. Has anyone else noticed this? I find it very annoying. I noticed it because my thigh seemed to be making impact with the top tube at the top of the pedal stroke, and upon further review, it is hitting the cable stop and occasionally the cable itself. I just can't past it.
Has anyone else encountered this issue?
When I bought the bike the salesman told me that if I didn't like it I could just bring it back and he would give me a refund. I am going down that route now. If they don't, I will probably be putting it up for sale here, on E-bay or on CL.
Bikes: 2011 Cannondale CAAD10
Sounds like a fit issue. Change the saddle, saddle height, crank arm length, etc. That should never be an issue.
Quoted: 14 Post(s)
Quoted: 14 Post(s)
pan y agua
Quoted: 1457 Post(s)
Liked 734 Times
That sounds very odd. I would try playing around with your fit. You don't want to F up a good fit, but I'm thinking something sounds a bit off.
One thought is increase your Q factor (the width between your feet) This is as easy as sliding your cleats inward on your shoes. This should make youe knees track wider.
Another thought is to look at the fore aft position of your saddle. Perhaps you need to be further back? Also look and see if you seat height is correct.
You could get lost and die.
You could hit a tree and die.
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
Take it to the dealer and compare it's position to other CAAD10 frames. Maybe you have one that has that boss out of position?
Quoted: 14 Post(s)
I think your Q factor solution might work, but why would I be interested in increasing the Q factor when the goal is generally to reduce it? Moreover, it's not like I need this bike. I bought it for a spare and there is no real reason to F with a good thing in order to get past this.
All in all I really like the bike, but this bugs me.
Maybe I should post a question about this on the Cult thread to see if anyone else has the issue...
Quoted: 14 Post(s)
Bikes: CAAD10 Rival
Quoted: 12 Post(s)
Assuming this isn't about April 1, I don't see an issue with the bike. I also have the CAAD10. If you look straight down at the top tube, you can't see the wire. This means that if you are touching the wire during pedaling, you must be rubbing off or hitting the top tube. Wire or no wire, that doesn't make sense. Try adjusting your cleats. There are also rubber O-rings on the wire to keep it away from the frame. It could be that you're touching these, in which case I would move them away from where your leg is closest to the frame.
PS: You could also test ride a couple of other CAAD10s (same size and adjustments) to make sure that you don't have a weld problem with your bike.
Quoted: 14 Post(s)
I'm starting to think this may be an issue with just this one frame.
Not as fast as I was
If it's a 58, send it to me.
But seriously, what you're describing sounds like a fit issue. My knees dive in slightly when my shoes are not set up properly. With 2 shims and eSoles are added, my knees track up and down properly. I'd suggest looking for a good bike fit specialist in your area and make sure they do your feet as well.
Send the CAAD to me.
Quoted: 14 Post(s)
It's a 56, but for the right price, I'll send it to anyone who wants it.
pan y agua
Liked 734 Times
And Q factor can be too narrow. They were developing a narrow bike for Lance Armstrong, that was going to be "the s**t that kills." But it turned out with the narrower Q factor he produced less power and that was the end of that project.
Quoted: 14 Post(s)
I don't know of any goal to reduce Q factor. The goal should be to get a fit that works for you. If your setup is causing your knee to track into the Top tube, something's not working.
Bikes: '10 C'Dale CAAD9 4, '09 S-Works Tricross, Gary Fisher Tassahara
How about some pictures so we can see the offending stop and its position from the above the top tube?
Beer >> Sanity
Bikes: 2014 Evo DA2, 2010 Caad9-4, 2011 Synapse-4, 2013 CaadX-disc
Can you post any pics of the issue? No one should be unhappy with a bf approved caad.
Quoted: 77 Post(s)
Liked 19 Times
You need to go on a diet???
Put a very thin spacer between pedal and crankarm . . .
These Guys Eat Oreos
Bikes: Yes
Quoted: 13 Post(s)
Just FYI, I had this exact same problem when I test rode a Caad10. I figured it was just because I didn't have shoes/clipless pedals on. My knees have always barely touched the top tube on my old bike, so it wouldn't surprise me if they did on the Caad as well. Glad I didn't get that bike, that would have been annoying!
meow
Bikes: 2016 Parlee Altum, 2013 Cannondale Super Six Evo Hi Mod Di2 only, 2011 Cannondale Super Six, Dura Ace 7800, 2007 Cannondale System Six Dura Ace 7800, 1992 Bridgestone RB-1, MB-2, MB-3, MB-5
Trade it in for a used 2006 Trek Madone
Bikes: CAAD10 Rival
Quoted: 12 Post(s)
When you look down the top tube, do you see the cable stop sticking out? Mine may have been put on wrong because I can see the cable stop and a decent bit of the cable itself. I had been hitting the o-ring, but moved that out of the way. As for the top tube, my legs get pretty close to it while I pedal.
Test riding other CAAD10s could be the easiest way to find out if there are any problems with the bike.
Bikes: Kona Jake (2006)
If it's the Rival model and you're gonna be in DC anytime soon, I'll trade you my 2010 CAAD9 for it. The top tube is a good bit narrower.
Hmmm. did Cannondale have a bad batch of bikes, or is this some sort of April fools joke? Very similar thread on the clyde forum yesterday. I still can't see how someone could have this problem, unless they have a really odd setup or some sort of knee problem.
https://www.bikeforums.net/showthread...-inside-of-leg.
