Race Rigs - Show us your equipment!
#127
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
Had you gone to LSU, you'd have a LOT of stuff that matched that Centurion. And no, I'm not an LSU alum, I just like the colors. I almost put green bar tape on it for Mardi Gras.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#128
West Coast Weenie
Bikes: 2013 Caletti, Trek 7500 fx
Hum... I don't know where you'd put the beads, it'd have to have beads for mardi gras, right?
#131
Old & Getting Older Racer
Bikes: Bicycle Transportation: 2022 Hyundai Kona Electric, 2019 Kia Niro Plug-In Hybrid
Quoted: 41 Post(s)
Liked 8 Times
Yours looks excellent.
Roger M, Coeur D'Acier? Very nice! I have a soft spot for Serottas.
Thanks.
Cleave
"Real men still wear pink."
Visit my blog at https://cleavesblant.wordpress.com/
Lightning Velo Cycling Club: https://www.lightningvelo.org/
Learn about our Green Dream Home at https://www.lawville.org/
Thanks.
Cleave
#132
Idiot Emeritus
Ahhhh, another porn site! One a woman could love!
"Can you add a signature line please? The lack of words makes me think you are being held hostage and being told to be quiet"
#133
Idiot Emeritus
#135
I need speed
Bikes: Giant Propel, Cervelo P2
Here is the new frame, in race mode - ready to roll except for bar tape, and where it weighed in:
Here it is finished, in training mode, which adds only a few ounces:
#136
Idiot Emeritus
AzT, wow! I love the red accent that saddle gives the overall look. It's really light for such a large frame, too! Mega-kudos. And, I AM GLAD YOU'RE BACK!!!!
#138
I need speed
Frame is a bit lighter, but I have alloy bars now instead of CF, so it ended up the same as what I replaced. Gonna do the team group ride Saturday, which will be a good test of me on the bike. Still need to cut the steerer tube, and I think I can trim a little length off the RD cable.
A few irritating manufacturing defects, that just shouldn't be there on a top-of-the-line frame:
A. The cable stops were changed from last year, to be more aero for the aero frame. Last year they were held in only by tension on the outer cable. This year they have tiny screws that become flush with the plastic stop, under the outer cable ferrule. There are 4 of them. Two of the screws went in fine. The other two were blocked by something inside the frame tube... like some CF material at the back of the threaded hole. Since the screw was alloy, the hex head of first one that had the problem stripped. Didn't take much for that to happen. So I backed it out with vice-grips, cut off half the screw and managed to sort-of get it tightened. But it is loose, and clicks when moving the bars significantly. The second time it happened, I knew how easy it would strip, and cut the screw (even more) and that worked fine. Shouldn't have to do this kind of thing!
B. The squared off washer that clamps onto the cable for the rear brake needed to scrape some coating off the brake arm mount in order to clamp down. Tolerances didn't take the coating into account. Couple of square mm of bare metal (alloy) on a brake which is mounted under the BB, where it will see lots of grime. No big deal, but irritating.
C. The finish of the BB where the bearings press in should be much cleaner. For a race bike, any 'facing' required should be done prior to shipment but I have yet to see a manufacturer doing this.
#139
Idiot Emeritus
#140
I need speed
Sounds like QC issues, AzT. You're totally right, they shouldn't be there. Hey, I looked at a Madone yesterday, a 2013 model. I loved the way the front brake caliper fairs into the fork, and the "TT treatment" the rear brake got was totally trick. The down tube, with the flat back side was interesting, too. Is yours like that?
Madone has always been known as an all around bike with good predictable handling, comfortable for long rides, pretty light, and reasonably stiff so long as you get the model the pros are riding. Now it also leans toward the aero side, and IMO transmits a bit more of the road surface. It wasn't part of the last Velo test that included lab measurements of stiffness, as I don't think it was available then. It will be interesting to see how it stacks up in objective tests against the Scott, which won the last Velo 'shootout', FWIW.
#141
Version 7.0
Bikes: Too Many
Quoted: 1343 Post(s)
Liked 2,484 Times
AZT, I like the new bike and a great choice. All brands seem to have some peccadilloes.
What would be interesting is to have our gang become a set of testers of various bikes in a shootout. That would yield a great matrix of scores against a test protocol due to rider sizes, weight, preferences and skill.
#142
West Coast Weenie
#143
Version 7.0
Bikes: Too Many
Liked 2,484 Times
New track frame on the way. Racer Ex and I are copy cats. I am not sure which one of us copied the other. His frame is in the US and mine just left the UK headed for a bike shop in Irvine, CA and then on to the Stub Hub. And yes, it is stiff.
#145
Version 7.0
Bikes: Too Many
Liked 2,484 Times
Df3
#147
Version 7.0
Bikes: Too Many
Liked 2,484 Times
Yes. It is a medium so it may fit you. It is slightly small for me.
#148
Version 7.0
Bikes: Too Many
Liked 2,484 Times
My DF3 is out for delivery today. So, I should be able to race it on Sunday at LAVRA.
#149
Idiot Emeritus
