Why do high(er)-end bicycles come with saddles?
#76
Liked 732 Times
I highly doubt any saddle with non-exotic materials takes a whole lot of money to make. Sure, it may sell on the retail market for $100, but provided it's fiberglass and some sort of steel rails, it probably doesn't cost the manufacturer more than $5 to source. Structurally, they just aren't going to be that different than the saddles that Wal-Mart sells for $30. Now, if the saddle has a carbon shell, or titanium rails, or some other lightweight magic in it...
#77
In the US, the CPSC requires the cheapie platform pedals, reflectors and a saddle if the bike is sold whole. Google CPSC bicycle requirements. Bikes are sold assuming they are in rideable condition and they specify tests to that effect. The most basic test is a 150lb rider must be able to ride the bike 5 miles off the showroom floor after inflating the tires.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
#78
Advocatus Diaboli
Liked 1,613 Times
I do believe there are of course agreements between bike makers and groupset makers (eg. Shimano) that ensures groupsets sold to the bike makers, end up on bikes and not sold as groupsets. This would seem to make it necessary to at least have stem/bars and wheels.
I've always wanted to see the large manufacturers to get creative on their bike configs. Sell framesets but options to choose groupset, cockpit and/or wheelset packages. Have the LBS do the assembly from the packages delivered from the distributor. To the original point, why should it be mandatory to get a $250 saddle you may not want. Other options... why can't Di2 be an option on the base alloy frameset, or if I get Di2 on a carbon model, the bike will inevitably have a few other things 'upgraded' that I don't need. If you want some deeper aero carbon wheels, you can't get them on a 105 equipped model? If you want flat aero carbon handlebars, the first complete bike offering those is over $7k? etc
#79
Is there any requirement though to sell a bike "whole" though? Obviously framesets are a thing. Does anything stop a manufacturer from selling any configuration between a frameset and the whole bike?
Getting to the level of detail of having a shop build up every half-nice frameset with any component you'd like would turn this from a 30-60 min process to a whole day affair, not to mention the supply chain/logistical nightmare that would bring.
"No, I don't want an Allez with 105, I want the base Allez frame with DuraAce Di2, the saddle off of a Stumpjumper, the flexy post off of a Roubaix, an 11-42 XT cassette, and Turbo Cottons on the Rovals off of a Venge."
"Sorry sir, we can't even run a DuraAce Di2 with an XT 11-42 cassette"
And that'll be the difficulty at that point. That's probably taking it to the extreme, but the industry has to have guardrails in place to keep things moving smoothly. There are far fewer customers who will grumble about the saddle being wrong or the gear ratios being off than customers who will get frustrated because they have to pick something aside from standover height, reach, price, and color. And for the few of us that are really picky, going the frameset route is always an option.
#80
#81
Advocatus Diaboli
Liked 1,613 Times
That's a level of configuration that no shop will want to deal with. My last experience working in bike shops was back in high school/college, but I can't imagine it's that different these days: A bike shows up at the shop nearly complete, and any shop hand can throw the wheels/bars/post on, tune the brakes/derailleurs, and check for major issues (wheel trueness, crank/headset assembly), and get the bike from box to floor in about an hour - often less for an experienced mechanic.
If a smaller outfit like Ribble can do it, it seems remarkable that the Trek/Spesh/Giant's can't figure something out.
#82
A glaringly obvious available market niche. Solution: swoop in and start your own company, with a trendily generic-sounding name. Since "Specialized" is already taken, how about "Entitled"?
#83
Advocatus Diaboli
Liked 1,613 Times
I like what AdrenalineBike and Wrench Science do, though because they're just building stuff, I'm not sure whether they get OEM pricing on the components.
I also like T-Labs simple but limited approach. Pick a bike frame model and then choose from one of 3-4 groupsets. No matter which group you choose, the rest of the bike componentry is the same but is basically 'free' since the frame+group market price is about the same as the complete.
#84
Likes For asgelle:
#85
Liked 203 Times
#86
I know some of remember the era when you bought a frame and hung on it everything you wanted. I found that it much cheaper to buy a complete bike and then just replace the parts you need to. The big companies buy in such high volume that that ‘expensive’ saddle for you, cost them nothing.
#87
Advocatus Diaboli
Liked 1,613 Times
One example, Domane SL7 goes for $2400 more than an SL6. You get some Di2 parts for electronic and a wheelset that has a $800 more expensive wheelset. That's a worse value proposition for the consumer.
#88
I went Project One on my Trek. There's a reasonable amount of customization and my bike started as an SLR 7 and ended up as an SLR 9, just with Ultegra instead of Di2. I even put 28mm tires on it, which means aside from the entry-level rim brake AL2 I have one of the only Domanes that came with 28mm tires.
#89
It all depends on what you can afford, and on how much time you spend in the saddle. For my part, I am lucky enough to have spare cash and the first thing I do with a new bike is to buy a Brooks B17 narrow. It makes all the difference in the world after an hour in the saddle.
#90
I like the one that came on my Trek Domane and still am using it after 39,000 km.
#92
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Liked 421 Times
Wisely or not, no high(er)-end bicycle these days comes with pedals (I'm not counting the cheapie flat pedals on there for test rides and such).
Yet these same bicycles come with decent saddles, presumably at a non-trivial cost adder. Why? Does anyone actually use the saddle that comes with a new bike? I can't remember the last time I did. I either take the saddle from a bike I'm replacing and put it on the new bike, or I order the same model saddle I'm presently using and install that one on the new bike so that I know it will fit me properly.
Likes For SpeedyBlueBiker:
#93
Liked 421 Times
That's funny, I went the other way. I rode the stock 11-30 for about two years and then switched to an 11-32. It was a good move although the jump from the 28 cog to the 32 cog is a bit of a leap.
#94
Observational Theorist
As an employee of a very busy, high volume shop, I can't begin to tell you how impractical and unfeasible this would be. Most people start with mostly stock and change and upgrade along the way.
Having to choose all components a la carte at the start would be dizzying and exhausting, not to mention extremely time consuming with current supply chain lag time and delays, and you'd be sitting with no bike in the meantime. While you could be out riding the bike, getting to know it and deciding what can stay and is just fine and what needs to go to make room for something better.
There should a display version of the bike, fully built. The rest should be ready to swap bars, stem, saddle, pedals, wheels or cassette. It always seemed pretty dumb to me when I was taping up the bars on a bike, when the owner hadn't even come along yet.
The stock tape could just be sold cheap, with the bike's new owner getting that much discount on the tape of their preference. Same with bars or whatever.
Likes For DocJames:
#95
Liked 732 Times
Obviously this approach wouldn't fly for a super busy shop, but you'd only do it for bikes costing a bomb, so I figure it'd make some sense here and there. I reckon it's the sort of thing that'd earn you some good word of mouth.
#96
In the last few weeks we've sold one bike costing around $10,000 and another for around $8900. If their buyers weren't trying to do a full custom build out. Not sure how to tell you, but the folk doing that represent a teeny fraction of bike buyers. And as mentioned by someone else, you can always buy a frame set to go this route.
#97
Method to My Madness
Liked 1,702 Times
Correct, it is a glaringly obvious niche.
#98
