Retro roadies- old frames with STI's or Ergos
#1176
Good luck, and pictures would really help. Whatever you do, save the piggy-back shifters and assembly. They are often ratcheting Suntours and have many fans who will take them off of your hands, maybe even trade you for the parts you need.[/QUOTE]
I don't think they're "piggy back" if I understand that correctly. The shifters are shimano 600 bolted side by side to a bracket which is on top of the down tube. I hope the pics turn out - the second shows the cable routing.
Thanks for the input.
#1178
Bikes: Poseidon X Ambition
85 Centurion Accordo with 7s RSX
Centurion Accordo by Mr. Embrey, on Flickr
88/89 Bianchi Strada LX with 9s Tiagra. I can't remember if I posted this one already.
88/89 Bianchi Strada LX by Mr. Embrey, on Flickr
#1179
Bikes: Cannondale T700s and a few others
Top mount/ piggy back like a Suntour Symmetric. Is it clamp on (band all the way around the tube) or is it bolted to a Brazon?
What you will need is something like this:
https://www.retrobicyclesupply.com/su...sing-stop.html
It should be close enough to the top of the tube to work with the cable guides on the BB.
If it is a clamp on that you have then it will blend right in and look like it came that way.
If you have the Braze on style then you will have that exposed and they are usually prone of the tube about 1/4 inch. I'm still trying to figure out how to hide it on my Lotus.
#1180
There is no band; the bracket is bolted to the top tube. Could I bolt cable stops to the sides of the existing bracket where the shifters connect? I think an exposed braze-on would look sloppy if I used a band.
Grim, if you figure out how to mount yours, could you let me know? Thanks for the input.
#1182
#1183
The down tube cable stops will work, but you'd need the flat-back models. You may need a thick washer or two to make sure the stop clears the downtube. That would be the simplest option. Fairly bulky, but in line with the cable's intended path. The Suntour option listed for 14.99 would work just fine, as would the newer models I mentioned.
Can't wait to see it done.
#1184
That $14.99 is high for that part. I posted that just so you know what you are looking for if you go with that option. If you have a CoOp you could probably pick that up for less then $5 used. Last one I got for free at a place that does a lot of single speed/fixed gear conversion. I also got a set of Suntour bar end shifters for $10 at the same time.
RobbieTunes solution may be the better option since you have the Brazeon. Most bike stores worth going to are likely to have the part he listed in stock.
Just a FYI, that's a relatively rare mount you have. Id keep the parts in case you ever want to sell it or restore it.
I also look forward to some completed pictures. I'm still hunting for a nice Miyata in my size. Flipped a couple that were too small and really like them.
#1186
As part of show and tell this is an International I don't think I have posted. It currently is 8 speed Shimano 600 Ultegra with a Stronglight compact crank but may be changed to Chorus this winter depending on other projects. It is a great ride! I have an original International and yes now I know the decal is in the wrong place.
#1187
Here's my mostly-complete 1985 Peugeot PH501 I built up for my wife. It was the model of my first racebike in high school, found a frame in great shape and built it up with Campy Mirage speed. Need to find a vintage saddle and a better seatpost, but other than that I'm happy with how it turned out!
#1188
bear
Bikes: '06 Scott S20, '04 Trek 3700, '88 Schwinn Tempo, '86 Schwinn Tempo, '85 Centurion Le Mans RS, '84 Univega Gran Tourismo
#1189
#1192
Bikes: Bertoni Corsa Mondiale, Bridgestone T-700, Miyata 700 GT, Trek 600, Trek 560 Professional Series, Chrome Panasonic DX 2000, Peugeot PH12, Peugeot PX10, Schwinn World Voyageur, Schwinn Circuit, and Schwinn Voyageur
Liked 5 Times
The bike is a Giant Cadex 980c. After my first short ride, I'm looking forward the the Spring and seeing what it can do. It presently weighs 21 lbs (at 250 lbs, bike weight is less of a consideration for me). However, I am concerned that I might be too heavy for the bike. Maybe the bike will be good incentive to lose weight.
#1193
Bikes: '92 22" Cannondale M2000, '92 Cannondale R1000 Tandem, another modern Canndondale tandem, Two Holy Grail '86 Cannondale ST800s 27" (68.5cm) Touring bike w/Superbe Pro components and Phil Wood hubs. A bunch of other 27" ST frames & bikes.
#1195
bear
I have never seen one in the wild. I've been looking for a couple of years without any luck. There have been a couple of leads and alleged sightings, but they never panned out.
#1197
sɹɐʇsɟoןןnɟsʇıbɟɯo
Bikes: fixed gear recumbent trike
i might have one, let me check my parts bin
#1198
sɹɐʇsɟoןןnɟsʇıbɟɯo
nope, what i was thinking of is this:
#1200
