Centurion Serial Number Database
#2401
Well.....................
I don't see any lugs. Looks like a butt welded steel frame to me. The chrome steel wheels with little dimples in the rim is a trademark of inexpensive bikes built in the late 70's early 80's.
The Simplex shifters & Weinmann brakes are way out place on a bike with a Centurion label. The Centurions from that era usually had SunTour or Shimano components on them.
I've bought, sold, traded and refurbished at least a dozen Centurion bikes over the last twenty years. Never seen nothing like this before. Just guessing. This bike must have been built for the European market & not sold in the US.
Maybe someone in the know can chime in on how much if any exporting Centurion (WSI) did to Europe and if they possibly used other fabricators than those they used for imports to the states.
#2402
1988 Ironman Carbon - Serial 88C0182
#2403
Serial numbers and details of a couple more Centurions.
First, a 1987 Centurion 'Team Pursuit', which seems to be an Australian-only model, serial no: M7D00320
Attachment 507253
The following seems to be original equipment:
Suntour Alpha 5000 rear and front derailers
6x2 speed Suntour indexed/(or friction) shifting with Suntour Alpha 13-15-17-19-21-24 freewheel.
Sakae SA 170mm crankset with 52/42 teeth and 110mm P.C.D. There's barely any wear on either the chainrings or the cogs.
Alpha 5000 Dia Compe brake calipers.
Suntour dropouts at the rear. The front dropouts don't have any writing on them but they have holes with threads for guards.
The wheels have 36 spoke Araya 700c rims, Suzue hubs. And 28mm tyres which are probably not 29yrs old but could well be.
The headset is Tange Seiki with what looks to read: TG235
BB is some kind of unsealed lock-ring one which i should have noted when i overhauled it.
The frame is 'Tange 2' tubing, 58cm c of bb to bottom of seattube scallop and a 57cm top tube c-c. It has a 'Quality from Japan,
Designed in USA' decal. Only has bottle cage bosses on the downtube. The Suntour downtube shifters are the clamp-around-the-downtube
type, no downtube bosses, but i noticed there's an integrated small sheet of metal brazed on the underside of the downtube under the
paint for the downtube shifter clamp to lock around.
A grey plastic Suntour dork disc that has an art deco-ish type line pattern.
I have no idea what stem or handlebars or brake levers it might have had, or seatpost (i put that one on), but it also came with MKS
AR-8 pedals. They may or may not be original.
Attachment 507257
Attachment 507258
Attachment 507253
Attachment 507257
Attachment 507258
#2404
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Liked 208 Times
$15 sounds like a good deal. Was the serial number M7D00344?
I think that the Team Pursuit was only from the year 1987. This model was only in Australia.
The Centurion brand name was owned by different companies in different parts of the world and these companies ordered bicycles to their own specifications. I suspect there will not be much information about your Centurion outside of Australia.
#2405
Hello and welcome to the forum.
Yep, that's the number!
#2408
Liked 208 Times
Looks like a Super Elite model.
Here is a link to a thread by frenchbikefan
frenchbike fan Centurion Super Elite
