The most elusive Park Tool has surfaced. Bent headtubes, take note.
#51
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
The second machine came for a visit late tonight:
Data Point #2:
Frame: Said to be a Torpado, but no markings to correlate this.
Tubing: Assumed to be Columbus. SP? SL?
Wrinkling: Some below lower head lug, minor behind upper lug.
General damage category: Low-moderate
Crash history:
Rider caught front wheel with toe clip + shoe while maneuvering and endo'ed at low speed. Was used as a fixed conversion; might explain why the toe clip jammed the front wheel that violently - pedal might have been on a downstroke?
Headtube ended up bending to 75/76 degrees. Tube sat at around 72 degrees originally (small frame = slacker head geometry).
Before and after Park HTS-1:
The worst wrinkled areas were situated below each headlug, immidiately behind the lug spear. Lower lug fared the worst with a significant wrinkle. Top tube much more moderate. No headtube damage or warping.
I was quite surprised to see that the worst of the wrinkling - below the lower headlug - nearly disappeared after straightening the headtube. All that remains is a paint split (visible in the photo). The top tube remains slightly warped (barely visible, though one can feel it), though no serious creases remain afterwards.
Photos:
BEFORE:
AFTER:
Conclusion:
A smashing (pun not intended) success. The results are very good, and the tool worked as intended.
-Kurt
Data Point #2:
Crash history:
Photos:
BEFORE:
AFTER:
Conclusion:
-Kurt
#52
Quoted: 7348 Post(s)
Liked 2,465 Times
I would ride that Torpado now.
I really like your writeups as well as your work.
#53
Liked 4,395 Times
#54
Liked 2,465 Times
Got any plans for it? I'd fit it.
#55
Liked 4,395 Times
#56
Quoted: 1372 Post(s)
Liked 1,751 Times
Next time...
As soon as I run across a bent frame set, I will have a go at straightening it and take good, step by step, pictures.
When I repaired the bent PX10, I used the tool being discussed, however; I also tried to focus pressures where the bends occurred. I am not sure that I can explain how I did this without pictures, but it amounted to putting pressure on the top tube, attempting to push it in the direction I wanted it to go.
As I applied pressure, I watched very closely for any signs of distortion. Remember, I have been working with metal for a long time. Also, it took me several tries to get it to move even a little.
Don't get is a hurry. Repeat, measure and repeat, until you get the results you seek or screw it up so bad that you will take up TV instead of bike riding.
#57
Quoted: 413 Post(s)
Liked 109 Times
I think the Torpado damage is at the extreme end of what the tool can safely straightene. Anything more than that would have serious rippling and possibly kinking of the tubes.
#58
Quoted: 90 Post(s)
Liked 137 Times
Hmm. I'm really not sure if it would straighten an EF frame. So far, I've got an SL frame, a 1020 Windsor, and the 753 frame lined up; I might be able to dig up an EF to see if it does anything.
That said though, if I do buy the tool, I'm not willing to ship it out. I wouldn't have anything against doing the frame here though, and considering the tool's size and the weight, the shipping for either would probably be about the same.
Same here.
-Kurt
Same here.
-Kurt
That is one tool I would like to own,I just thought of a guy that might have one close by I will go see him soon.
#59
Location: Sweden, Västragötaland, Herrljunga, Hudene, Stenunga, Hulegården :D
Bikes: Peugott Fixed (almost rideable) Mustang three-speed, Crescent 707 sport, Crescent Fashionline - BSO - Diana one-speed from -40th, Mustang
How do you know when the tube is straight? A good ruler, messurement or just your eyes?
#60
Quoted: 413 Post(s)
Liked 109 Times
A more challenging aspect of this repair is removing 'twist' from the main triangle. Unless the impact was dead head on odds are the head tube is no longer in the same plane as the seat tube. Eyeing that up can be done but in my opinion it's very difficult to get a head tube in the same plane as the seat tube.
#61
Liked 4,395 Times
That said, the headtube isn't the only thing to move when resetting it. Both the top tube and downtube work their way down a couple of degrees, offsetting the kinks behind the lugs.
Frankly, I doubt any other frame tools could have improved the results of Test #1 or Test #2. As one cranks the headtube, the top and down tubes naturally return to their original positions.
-Kurt
#62
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I would be interested in hearing anecdotal ride reports, comparing how a bike rode before it was damaged versus how it rode after this repair.
I have one such anecdote. In 1980 I worked at a shop where we had this tool, and used it to straighten a Miyata tha had collided with a car. It was a classic example of the kind of damage this tool can fix. The owner really loved that bike, and was glad to be able to ride it again; and the repaired bike looked as good as new. Well, almost; there were subtle ripples in the paint right where you'd expect them. Anyway, the owner was thrilled to get it back in ridable condition; but after riding it, he didn't love it any more. It didn't feel the same.
Of course, one can always ask... was that real, or all in his head? Does it matter? (What's in my head is real; everything else is imaginary).
#64
Liked 4,395 Times
#66
Quoted: 413 Post(s)
Liked 109 Times
#67
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 19 Post(s)
Liked 5 Times
https://cgi.ebay.com/ws/eBayISAPI.dll...E:B:SS:US:1123
I was watching it earlier this week until I realized "What the hell am I gonna do with a Paramount with crash damage"
#68
Liked 4,395 Times
#69
Quoted: 19 Post(s)
Liked 5 Times
My feelings exactly
it was $0.99 when i started watching and around 20 bux when I took it off my watch list. I really didn't even expect to see one bid.
#70
Restore, ride, repeat...
Liked 4,395 Times
Here is frame #3 . Like the Windsor, a complete write off, but I nevertheless wished to experience what would happen with Reynolds 753 first-hand.
Data Point #3 :
Frame: 1987 (?) Raleigh Team Professional, Jan Legrand SDBU build
Tubing: Reynolds 753R
Wrinkling: Major crumpling on downtube, very slight downwards bend to top tube. Headtube warped under top head lug.
General damage category: Extreme+
Crash history:
Little known about crash, except that it was a high-speed impact.
This frame was obviously a failed cause before I ever put it in the HTS-1. Downtube had collapsed behind shifter levers, with noticeable creases. The top tube had only the slightest of a downward curve; the headtube took the rest of the force that would have otherwise taken out the top tube - note the warp under the upper head lug.
Nevertheless, I proceeded to pull the downtube straight. Though the previous two frames had experienced reverse bowing of the top tube under pressure (and sprung back after the tool was loosened), the 753 frame bowed significantly. So much so that the top tube remained noticeably bowed after the tool was removed.
The downtube never did straighten out entirely - the top and bottom halves are about two degrees off. The sharp creases began to crack open in the process; the tool was de-tensioned after snapping sounds were heard from this area. Two visible gaps formed from the crease locations.
Photos:
BEFORE:
UNDER TENSION:
AFTER:
Conclusion:
Failure all around. I knew that beforehand, but I wasn't expecting the tool to add additional damage to the top tube.
Before I dismiss this tool entirely, I want to see if I can dig up a frame with a bowed - but not warped - headtube, much like Randy's PX-10. Unless it can pass the non-wrinkled frame test, I'm not going to buy it; it'll be a waste of money on a worthless novelty. If it does work on a slightly curved frame w/o any kinks (Randy's frame has technically proven it already, though I'd like to try it out too), then I'd see the point in it.
-Kurt
Data Point #3 :
Crash history:
Photos:
BEFORE:
UNDER TENSION:
AFTER:
Conclusion:
-Kurt
#72
Liked 4,395 Times
#73
Liked 1,751 Times
#74
Iconoclast
Bikes: Colnago Super, Fuji Opus III, Specialized Rockhopper, Specialized Sirrus (road)
That Raleigh was utterly tragic, Kurt.
#75
Liked 4,395 Times
Needless to say, I cannot comment on another bicycle, but this is the before and after story for my PX10. You will see that all was not necessarily well - at first.
If I could find a few more frames bent in the same manner as your PX10, perhaps I'd view the tool in better light.
All it needs is a new front triangle. Any framebuilder can take care of that. Since its silver soldered, that makes it even easier.
-Kurt
