Poor Man's Parts Cleaner
Quoted: 3808 Post(s)
Liked 6,682 Times
Here’s mine. Big enough to fit most bike items.
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,215 Times
The chain will come out of the bath clean enough for hot waxing. The wax itself is a solvent so any traces of factory lubricant would end up in the wax which probably wouldn’t be a bad thing.
Disposal is a bit more elaborate because it is classified as a hazardous waste but most municipalities have a household waste collection system.
Now compare that to detergent cleaning. First a cup of detergent isn’t enough to clean all the factory lubricant off a single chain. A quart of detergent probably isn’t enough. And it’s going to take a lot longer than 30 seconds, even with an ultrasonic cleaner. After cleaning, the oil is still in the water and really shouldn’t be just flushed down the drain. Most people will but sewage treatment plants don’t handle petroleum products well. But the cleaning process isn’t finished there. The chain needs to be rinsed…more contaminated water…and the water needs to be removed. Simply letting it air dry is likely to cause rusting so a solvent to chase the water off is needed…another source of waste. And this is for each and every chain cleaning!
My method of chain cleaning can make a cup of mineral spirits last for years per bike (3000 miles x 12) and gets the chain just as clean with a whole lot less waste and no need for any more agitation than what I can add with my arm. Even for people who don’t wax and do much more frequent chain cleanings that I do would use less cleaning solvents than water based methods.
My (overly belabored) point is that ultrasonic cleaning isn’t necessary if you use the proper solvent.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 6,682 Times
Fwiw, I practice the black arts of chain waxing and clean my chains (brand new from the factory or used) in mineral spirits. I tried the ultrasonic, but it just didn't get it as clean as a vigorous shake in a jar of mineral spirits. I also just decant the used spirits with a coffee filter and a strainer and re-use.
Quoted: 1639 Post(s)
Liked 829 Times
I've been tempted to get an ultrasonic cleaner to service my components, but decided that my method, of cleaning by doing a full disassembly of the component, cleaning it with a toothbrush while dipped in a pan mineral spirits, polishing the parts if needed and reassembly, applying any lubrication while doing so. This way I really give the part a full extensive service and adjustment, instead of just giving it a quick ultrasonic bath...... Doing it the way I do, also helps me find out if any of the parts on the component might need attention or replacement.
I also get a lot of satisfaction from the "zen" putting in all the work into cleaning, adjusting and polishing the component......
BTW, can't help asking,......wasn't that "ignition system coming fan" shown in the video being cleaned, was really a turbo impeller??
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
WGB
Bikes: Panasonic PT-4500
Quoted: 1799 Post(s)
Liked 2,334 Times
Just park you bike in this one and go grocery shipping (And, yes, I know it wouldn't do the BB/headset/hubs any good)
https://www.facebook.com/marketplace...6-f550c5911e85
Ultrasonic Cleaner
$600
Listed 5 days ago in Westerville, OH
Ultrasonic Cleaner
$600
- Condition
Used - Good
Likes For WGB:
Bikes: 48 Alleluia, 52 Blondin, 57 Cattaneo, 68 CNC, 55 Dujay, 46 Herse, 76 Singer, 48 LeGreves, 55 Metropole, 62 Holdsworth Cyclone, 49 Carpenter, 55 Condor, 65 Masi Special, 81 Sequoia, 76 Eisentraut, 72 Proteus, 60 Paramount, 77 Trek TX700, 82 Ross
Quoted: 79 Post(s)
Liked 137 Times
Chain cleaning
I agree that mineral spirits is an excellent cleaner for grease, but I'm sick of using it. Based on what I learned from Oz Cycle and Josh Poertner (Silca) youtube videos, I'm surprised that your cleaning method would get the chain clean enough for hot waxing. But if it works for you, then who am I to doubt it? I essentially use Poertner's approach. While it does take some time, the chain gets super clean and it only needs to be done once per chain..
Liked 4,215 Times
Second, there is no need to use a water based degreaser. The “petroleum” step is all that is needed. Adding water to the procedure…even with a detergent in the liquid…just overly complicates the process and adds unnecessary and unproductive steps. Third, the “methylated spirits” is just to remove the water from a step that is totally unnecessary because you don’t need the water in the first place.
There are other things he gets wrong in that video. The “black stuff” isn’t “Teflon”. You can grind Teflon down to a very fine powder…in fact he uses very finely ground teflon in his wax…and it will never go black. The “black stuff” is steel from wear. It may also have some finely divided dirt in it but it is not Teflon.
I haven’t found anything by Josh Poertner on cleaning but have run across something from someone else talking about the need for a “sterile” chain. The chain doesn’t have to be that clean. The wax itself is a solvent…it’s basically solid mineral spirits with a longer molecular chain. Wax is not incompatible with the factory lube, which, again, is a wax itself. It will melt into the wax without issues and without causing problems. Oil would do the same.
Finally, I don’t see how a ultrasonic bath bath would be useful past the initial cleaning. Waxing chains is about having a clean chain that doesn’t need the constant cleaning that oil based lubricants require. After the initial cleaning, hot dipping the chain should be provide more than enough cleaning. And I don’t think it is necessary nor efficient for that initial cleaning if you use an efficient solvent.
Stuart Black
Stuart Black
I use gasoline and a paintbrush. I also eat eggs, red meat, and cut the tags off my pillows.
Liked 4,215 Times
Just don’t be surprised when a big red truck with flashing lights shows up in front of your house. And don’t be surprised when your insurance company finds this post and tells you that you are just out of luck on that house fire claim.
Stuart Black
Stuart Black
Quoted: 753 Post(s)
Liked 737 Times
Well... as some one who keeps every household flammable in Justrite cabinets, and has a fire proof trash can, fire extinguishers, smoke detectors and removes all rags immediately to burn in a fire pit, I don't use gasoline to clean stuff. But I'm not going to suggest that if someone does use gasoline outside away from any ignition source that there will be a tear in the time space continuum...
Not too worried. I also have a few working brain cells. As did generations before me that barely survived such dangerous practices.
Likes For sdn40:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 981 Post(s)
Liked 631 Times
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 79 Post(s)
Liked 137 Times
Chain cleaning for hot wax
I've heard from several people who do hot wax, that if the chain is not clean enough, the wax will not last nearly as long. You could say this is just anecdotal, and maybe there are other factors. But I believe Poertner says this too, and he's pretty systematic and scientific. I don't go along with some of Oz Cycle's methods or explanations, but he does get excellent results.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
I hope none of you take that Ichiban dude seriously. His videos are pure mechanic schtick. Watch some of his other videos if you missed the wink in his presentation here. Good fun.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3883 Post(s)
Liked 6,476 Times
Likes For SurferRosa:
Liked 4,215 Times
I happen to have several working brain cells that I used to get a degree in chemistry along with 40 years of experience working with chemicals. Years of safety training seminars have taught me that lots of people didn’t survive such dangerous practices.
Stuart Black
Stuart Black
Liked 6,682 Times
https://www.outsideonline.com/outdoo...ur-bike-chain/
For rewaxing, I cover the chain in boiling water for a couple of rounds. You can do a cycle of mineral spirits and denatured alcohol if you really want to make sure the chain is antiseptic, but I don’t think it’s necessary.
And for 50 years automobile gas tanks vented directly into enclosed garages. Look - I get it - flammable liquids need to be used with care. If you want to used distilled water and ivory soap and a 12 stage filter and a toothbrush and have 2 hours to burn cleaning a derailleur, all the more power to ya. I use a metal pan, 3 tablespoons of gas, a paintbrush, outside on my deck and 20 seconds later my derailleur is clean. 10 minutes later everything is evaporated. I'm pretty sure I'll live. Riding my bike around the block is a million times more dangerous.
Likes For sdn40:
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,194 Times
Come on (certain) folks, let's keep this thread on topic and stop wasting bandwidth. If you don't care for ultrasonic cleaners or a DIY Power Sander Cleaner (which IMO is quite clever), move along. I have negative opinions about other opinions expressed above--- but that's not the topic. I'd like to suggest that certain participants go back and delete their inflammatory off-topic opinions.
Bob
Bob
Likes For pastorbobnlnh:
Quoted: 753 Post(s)
Liked 737 Times
I was furiously searching for a video of some one brazing a filler port on a full gas tank.... but I think that may be an apocryphal problem solving tale that predates the internet.
Liked 4,215 Times
Mineral spirits has a flash point of 100°F. The same 3 tablespoons will do the same work but it won’t form the vapor cloud. It evaporates in about the same amount of time. A wise person uses a safer alternative if it does the same job without the risks.
Stuart Black
Stuart Black
Liked 4,215 Times
The same applies with chain cleaning. Why do several washes with mineral spirits followed by washes with something else? If you are using a water based solvent, those washes are probably needed because water based degreasers are very inefficient. The chaser with alcohol is certainly needed to remove rinse water from the inside of the chain. The amount of waste generated by a water based degreaser is enormous and the results are poor which is why I don’t use them.
High flash point petroleum solvents are far more efficient. One and done. I used to do multiple washes with mineral spirits then noticed that it didn’t make any difference to how clean the chain came out. I used to let the chain sit for hours and hours until I noticed that it didn’t make the chain cleaner. In other words, I tested the procedure and found a better procedure.
I fully agree that the chain doesn’t need to be antiseptic. That’s one reason why I don’t think an ultrasonic bath is necessary, especially with a new chain. Another reason is that ultrasonic baths use water and detergents which are, again, very inefficient when it comes to cleaning grease. I know I will probably eat these words but I don’t think anyone is ignorant enough to use an organic solvent in an ultrasonic bath.
To get back to the original post, did the guy with the sander try just hand agitating the part in a jar (plastic, please) before he got out the sander?
Stuart Black
Stuart Black
Quoted: 2333 Post(s)
Liked 2,097 Times
I use an ultrasonic but reading this thread makes me realize my bike is not so clean. The most I do with a rear derailleur is take the pulleys off and clean them by hand. The ball bearings never get fouled.
I am rethinking my new chain breakin process. Once I break a chain in, I rarely if ever clean it again. It goes right into the hold melt wax crockpot. The new chain gets ridden for about 100 miles. I have experimented with dawn, simple green, and water in the ultrasonic followed by alcohol and then mineral spirits. I have skipped the ultrasonic and tried Coleman Fuel (don't tell my mommy). What I have found is a lot of small metal shards in the solution. I would be concerned that a simple swish in Mineral Spirits would not remove these metal burrs or shards, whatever you want to call them. If the flash is 100F, maybe I can vigorously shake the chain inside the spirits to dislodge the metal pieces. One step would make it simple.
My ultrasonic cleaner might have been $60 at Walmart or Harbor Freight, I forget. It is also useful when cleaning the bolts on my funs.
Quoted: 981 Post(s)
Liked 631 Times
Well, it wouldn't have made the final cut of the YouTube video, for sure.
Liked 4,215 Times
Coleman fuel, by the way, is basically odored mineral spirits. We call it “white gas” but it isn’t gasoline. The flash point is a bit lower (0°F) which makes it a little more flammable then mineral spirits but not nearly as flammable as gasoline. It does have an elevated benzene content which makes it more hazardous to handle…please use gloves with any solvent…but it’s still less toxic than gasoline which has a much higher benzene content.
Stuart Black
Stuart Black
