Di2 Syncro with sub compact 46/30
Old 01-03-23, 10:48 AM
JamieDE
Quoted: 7 Post(s)
Originally Posted by Iride01
Maybe.
Kontact is correct that with a 11-30 cassette you'll be out of the max (total) capacity of 33 for your new crank. However Di2 won't shift to the last two small cogs on the rear when you are in the small front. So that'll probably be a 13 cog and that possibly makes you okay.
Not certain what Shimano says about figuring total capacity for Di2 and other setups where they said not to use those cogs when in the small.
Learn what the numbers mean and then you'll make better decisions about what to get.
I would never cross chain (ie 46/30 or 30/11) and pretty sure the synchro wouldn’t allow that anyway (like you said).
JamieDE is offline
Old 01-03-23, 11:04 AM
Iride01
post cholecystectomy
Iride01's Avatar
Quoted: 5277 Post(s)
Liked 3,797 Times in 2,640 Posts
Well you won't suddenly blow up and leave a crater big enough for a army tank to fall in if you do happen to. I use to cross chain all the time in the big/big.
However nothing here was about cross chaining. It was about finding the correct size rings that will work with your existing rear DR and whether you'd be able to size the chain properly and not have too much or not enough slack in it.
Iride01 is offline
Likes For Iride01:
Old 01-03-23, 01:02 PM
Kontact
Kontact's Avatar
Quoted: 3201 Post(s)
Liked 660 Times in 439 Posts
You can non-syncro shift into the big/big. If the chain is short because you're over capacity it can destroy a carbon frame.
Kontact is offline
Likes For Kontact:
