how to replace the bearings in your formula hub
Old 04-10-08, 02:41 PM
dirtyphotons
antisocialite
dirtyphotons's Avatar
ha. i tried it and the search had a hernia. thankfully there's google.
dirtyphotons is offline
Old 04-10-08, 03:52 PM
kemmer
*****es love tarck
kemmer's Avatar
Bikes: so many
Originally Posted by queerpunk
but...
i didn't pay for it.
i traded a wheel with a formula hub for it.
Then you should trade somebody a shoeshine for the bearing replacement.
kemmer is offline
Old 10-17-09, 08:37 PM
iamsomeguy
iamsomeguy's Avatar
external indexing does work better than the search
iamsomeguy is offline
Old 10-17-09, 09:26 PM
beeftech
beeftech's Avatar
Bikes: Bianchi San Jose, fixed
Except you end up bringing **** back from the dead.
beeftech is offline
Old 10-18-09, 01:04 AM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Liked 25 Times in 17 Posts
maybe, but it was an interesting read
hairnet is offline
Old 03-20-12, 07:30 PM
ATX 6Speed
Habitual (Bike) Tweaker
ATX 6Speed's Avatar
Bikes: 2011 Specialized Allez Comp E5
Sorry to bring this back from the dead, but I bought my PW bearings and also a 15mm and 17mm cone wrench and have two questions:
1. In addition to removing the 15mm cone nut do you also remove the 17mm locknut?
2. How much do you tighten the locknut and the cone on top of it after the bearings are pressed in? Since it is a sealed bearing I would assume you make it nice and tight (unlike loose ball).
ATX 6Speed is offline
Old 03-20-12, 08:07 PM
Spoonrobot
Spoonrobot's Avatar
Quoted: 1183 Post(s)
Liked 118 Times in 84 Posts
1. I believe this was answered in the original post. It appears they answer is yes.
most formulas use a 17mm locknut but i snapped both of mine years ago. so now it has locknuts off a nashbar hub, which use a 14mm wrench.
2. For the answer to this question we go to a slightly more detailed blog post, he does it a different way so either use his method completely or the one in the original post. But for the answer to this specific question we can just look at step 16.
https://projekto-b.blogspot.com/2008/...-bearings.html
The last step is to tighen the lock nuts into place...the inner lock nut should lock into place without moving the bearing.
Tightening the inner lock nut should NOT stop the bearing from turning smoothly on a hub that takes standard 6000 series bearings
16)The very last step is to put the outer lock nuts on, and tighten them in place. They don't have to be super tight, just snug. Thats it! Now get out for a ride and enjoy your newly serviced hub
This is a good necro-post.
ETA: Here's what Barnett's has to say:
Spoonrobot is offline
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
the cone won't really affect the bearing but you dont need to crank it down against the bearing.
hairnet is offline
Old 03-22-12, 06:09 AM
ATX 6Speed
ATX 6Speed's Avatar
Thanks for the help, guys! This turned out to be a pretty easy project and I saved 30 bucks in the process (and I have some swank cone wrenches for other projects now).
Old 01-11-14, 01:33 AM
dirtyphotons
antisocialite
Thanks for stepping in, all. This process is still applicable for a lot of newer track hubs. Don't feel bad about resurrecting a post that (might) help people still.
To answer the most recent questions:
1. Yes, you should remove all nuts for ease of bearing removal.
2. If you're reusing the axle that came with the hub, maybe 20ish lbs at the end of a 6" wrench.
Old 01-11-14, 09:06 AM
Pepper Grinder
Throw your new bearings in the freezer for a few minutes to make them smaller, easier to press-fit. You can also warm up the hub (gently!).
Pepper Grinder is offline
Old 10-15-16, 03:15 AM
mavimao
mavimao's Avatar
Bikes: Custom Mercier - Velo'v - Peugeot FG conversion
Sorry to ressurect an old thread but it seemed logical to group it all together in one thread.
So I'm trying to follow this guide except I can't get both inner lock nuts off. I'm able to get one off by tightly holding onto the inner lock nut on the other side, but that just tightens that one and therefore can't get THAT one off as a result. Does anyone have a tip?
EDIT: OK I feel a bit stupid for not having thought of this earlier but after a bit of thinking, I figured it out: if by chance you're in the same rut as I was, first screw in the inner nut on the side that is loose/off. Don't screw it in tight. Leave a little bit of space. Then put in the washer and outer lock nut on the loosened side and tighten the outer nut against the inner nut pretty tightly.
Then you will use that outer nut you just screwed on as leverage to take off the stubborn inner lock nut on the opposite side. So one wrench on the outer nut and the other on the inner nut on the opposite side.
Once that is off, you simply have to undo the inner and outer nuts as shown at the beginning of this thread and since the inner nut was already loosened, it's easier to come off.
mavimao is offline
iv4n
Bicycle Mechanics
6
09-13-16 05:35 PM
lazyocho
Bicycle Mechanics
2
11-27-14 11:20 AM
deacon mark
Bicycle Mechanics
4
02-08-14 08:44 PM
ValVal
Singlespeed & Fixed Gear
8
04-13-12 09:31 AM
wayback
Classic & Vintage
20
08-11-11 09:55 PM
