Tubeless road experiences
Old 04-21-22, 09:28 PM
  #76
yaw
should be more popular
Bikes: 22 Emonda
Quoted: 200 Post(s)
Liked 162 Times in 84 Posts
I asked a lot of riders and shop people whether they ride their road bikes tubeless and I have not yet come across anyone who thought it was a worthwhile idea for normal riding conditions and needs.
It became clear that it was far less prevalent, at least here, than the online community crowd or sponsored content providers with the job to sell bike parts would have you believe. These were no retrogrouches either.
yaw is offline
Old 04-22-22, 08:12 AM
  #77
Chandne
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 459 Post(s)
Liked 178 Times in 115 Posts
Our roads are clean so you don't have to run tubeless (though I do my front tire) but I do not ever go on gravel with my road bike. If I did, definitely all tubeless. I think practice is important if you want to run tubeless- make sure you can take the tire off and back on with a tube, just in case. Use the new plugs too. Obviously it would be rather daft to run tubes on my mountain bikes and gravel bike here in Colorado.
Chandne is offline
Old 04-24-22, 04:19 AM
  #78
The_woo
Quoted: 17 Post(s)
Liked 5 Times in 4 Posts
Isn’t the main benefit of tubeless (for road anyway) meant to be a lower rolling resistance? That’s certainly the reason for pro teams to start using it at Paris-Roubaix etc.
Puncture sealing certainly isn’t a factor as they very clearly don’t even use sealant.
I feel strongly that consumers are being missold something intended to give high performance benefits as something that prevents punctures, but I’ve never seen it work for road tyres satisfactorily.
Imo the same sealant tech works perfectly fine inside an inner tube and gives even more benefits in that regard, plus less mess, if you feel the need.
If anything, I’ve seen my club mates with tubeless setups have more incurable issues of cuts in tyre sidewalls and certainly way more mess than I’ve seen previously in years of tubed riding.
The final claimed benefit of tubeless is that you can run lower pressures… Using the SRAM tyre pressure calculator which lets you specify tubes vs tubeless, the difference is about 3 PSI in what it recommends. And anyway, I can happily run 30 PSI lower in my tubes tyres if I want without getting snakebites, it’s just very obviously slower.
The_woo is offline
Old 04-24-22, 11:00 AM
  #79
robbyville
robbyville's Avatar
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 245 Times in 156 Posts
I don’t think (for most) that the main selling feature is lower rolling resistance, although certainly a feature that is often marketed rightly or wrongly. I’m surprised to hear that the pro teams don’t use sealant though.
main selling feature that I’ve seen is flat resistance and comfort and my experience is exactly the opposite of yours. I do group rides 3-4 days per week and I’ve lived in two states since moving to tubeless and all I can say (anecdotally, no scientific stats), is that on at least every other ride I’m a part of there is at least one flat. In almost 7 years I’ve had exactly 2 and although I carry an extra tube with me they are more often than not donated to someone who needs it. There are only a few of us that use tubeless here and same situation for them.
robbyville is offline
Old 04-24-22, 12:08 PM
  #80
PeteHski
PeteHski's Avatar
Quoted: 3582 Post(s)
Liked 3,871 Times in 2,451 Posts
Originally Posted by Atlas Shrugged
"Just when I thought I was out, they pull me back in!"
Your logic continues to be flawed because a vast majority of those who ride tubeless have switched over from regular tubed tires and thus can be objective regarding which they prefer. For some they preferred tubed and went back for a varity of reasons however a vast majority stayed with tubeless because they thought it was preferable. The more recent the convert the more likely a positive experience because of the rapidly evolving technology.
Exactly. Pretty much everyone who runs tubeless has extensive experience of tubes too. It's the same with disc brakes. It's a lot easier to be objective if you've tried both options. None of us are paid to ride tubeless tyres and it's not exactly difficult to change your mind if it doesn't work out. So there's no real incentive to show any confirmation bias in this particular case (unless you are reluctant to trying them). If I thought tubeless tyres were crap I would certainly say so.
PeteHski is online now
Old 04-24-22, 12:11 PM
  #81
PeteHski
PeteHski's Avatar
This is what I would call confirmation bias right here^
Old 04-24-22, 12:29 PM
  #82
WhyFi
WhyFi's Avatar
Quoted: 20791 Post(s)
Liked 9,430 Times in 4,662 Posts
Originally Posted by PeteHski
None of us are paid to ride tubeless tyres...
I'm still getting my monthly paychecks from Big Sealant - when did yours stop? I'd make a couple calls, if I were you.
WhyFi is offline
Likes For WhyFi:
Old 04-24-22, 12:40 PM
  #83
PeteHski
PeteHski's Avatar
shhhh! They might realise we are spreading tubeless propgaganda!
Old 04-24-22, 02:51 PM
  #84
MinnMan
MinnMan's Avatar
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 3868 Post(s)
Liked 2,785 Times in 1,698 Posts
I'm sure some of them were. I've had 1 flat in 3 years riding tubeless road so it doesn't matter. When I was riding with tubes I was getting flats every few weeks on our local roads. It's the main reason I prefer tubeless.
There's no need to convince yourself tubeless is inferior to your tubed setup. Just ride and don't worry about threads asking about tubeless experience when you clearly don't have any.
You have a good point.
MinnMan is online now
Old 04-29-22, 06:47 PM
  #85
Miles2go
Zen Master
Miles2go's Avatar
Bikes: Cervelo R5 - SuperSix
Quoted: 75 Post(s)
Liked 89 Times in 42 Posts
If you're primarily after a more supple ride and lower pressures, the first thing I'd do is lower your pressure - you're running a little high for 28s and your weight, IMO. Start there, then reassess.
As far tubeless, I think that it's a great solution if you get a fair number of flats. If I didn't need the benefit of flat protection, though, I don't think that I'd take on the extra maintenance just to lower pressure a handful of PSI.
I transitioned from a SuperSix to the Cervelo R5 and ride on rough Tucson roads. One of my favorite things about running tubeless (Campagnolo Bora WTO 45s) is the amazing level of comfort it has given me. I weigh 153lbs and run 60f/65r psi, and that low pressure doesn't keep me from age group KOMs and high overall placings on longer Strava segments.
Low pressure tubeless, fast and comfortable.
Miles, smiles & tailwinds!
Ron - Tucson, AZ
Miles2go is offline
Old 04-29-22, 08:19 PM
  #86
Chandne
Quoted: 459 Post(s)
Which tires have you guys found to be easy to install and take off?
Chandne is offline
Old 04-29-22, 08:54 PM
  #87
WhyFi
WhyFi's Avatar
At this point, it's probably easier to list the tires that are difficult rather than those that aren't. In general, newer tires are going to be easier than some of the older ones - it was more common for older tires to err on the side of being tight. The most notable "old" tire around is going to be the Conti GP5k TL, and they do have a reputation of being tight (never used them myself).
Everything else that I've used in the last two years (Schwalbe Pro One Evo, Michelin Power Road, Pirelli P-Zero) have been up to the latest spec and have gone on and off without trouble. Out of the three, I had to take the most care with getting the Michelin on to the rim; no tools were needed - I've never needed anything other than bare hands to get a tire on - but I did need to be more deliberate about getting the beads in to the middle and taking up slack before rolling the last bit over.
WhyFi is offline
Old 04-29-22, 09:01 PM
  #88
Chandne
Quoted: 459 Post(s)
My IRCs were a bit tight on the Easton R90 Sl rims so I was hoping to get something a bit easier. I have installed a ton of tight tires but tight road tires may be painful and frustrating on the side of the road, if a tube is ever needed. I may try the Pirellis.
Chandne is offline
Old 04-29-22, 11:35 PM
  #89
Miles2go
Zen Master
Miles2go's Avatar
Quoted: 75 Post(s)
The Conti 5000TL is impossible to mount to Campy Bora WTO wheels, by hand. Even with levers, you need to take a rest day after the first one. After getting them mounted though, they seated pretty easily, usually with my floor pump, and hold their seating extremely well. Getting them back off though, after over 1,000 miles, is another ordeal! (with my wheels) Pirelli P Zero Race TLRs nearly fall onto the rim and by comparison, and also seat easily.
Ron - Tucson, AZ
Miles2go is offline
Likes For Miles2go:
Old 04-30-22, 07:32 AM
  #90
Greatestalltime
Greatestalltime's Avatar
Bikes: Tcr advanced sl & Protos
Quoted: 116 Post(s)
Liked 60 Times in 33 Posts
Originally Posted by merlinextraligh
What you describe as sluggish, may not actually be slower.
For years people road tires that by today’s standards were way overinflated. A rock hard tire feels fast and responsive as it bounces over tiny imperfections. But that bouncing adds to rolling resistance and is actually slower.
It took me over a year and a day forgetting to air up to accept that fact.
Greatestalltime is offline
Old 04-30-22, 11:48 AM
  #91
NoWhammies
NoWhammies's Avatar
Quoted: 800 Post(s)
Liked 512 Times in 306 Posts
Good to know. My rear Schwalbe Pro One tyre just gave up the ghost and the Michelin is next to come off the shelf. Tyres in general seem to be a pain in the butt to mount on my Boyd rims. Sounds like the Michelin's won't be doing me any favours either.
NoWhammies is offline
Old 04-30-22, 02:29 PM
  #92
waters60
waters60's Avatar
Quoted: 199 Post(s)
Liked 105 Times in 60 Posts
Taking advice to play with pressure a bit more on my Bora tubular / Veloflex Vlaanderen wheels I seem to have found a good compromise. Fortunately this is putting notions of getting a new wheel set out of my mind, plus the drama over tubeless vs tubes convinced me of the simplicity of just gluing on a tire that will last for 2,000 miles….
waters60 is offline
Old 05-01-22, 08:10 AM
  #93
Voodoo76
Blast from the Past
Voodoo76's Avatar
Bikes: Felt FR1, Ridley Excal, CAAD10, Trek 5500, Cannondale Slice
Quoted: 222 Post(s)
Liked 66 Times in 43 Posts
That's not a function of the tubeless tire; its a choice of the operator
Hasn't been my experience if you do it correctly. Completely dislodge the bead on the opposite side, push it to the center channel, and its usually possible to get the tire back on, even without a tire iron.
Also, the way things are going, most new rims are made with the center channel design to be tubeless compatible, so any mounting difficulties are going to be similar whether you're actually running tubeless or not.
Mounting difficulties are one area that have me seriously considering tubeless. I had a small routine puncture yesterday leading to a slow leak in the front tire that I'm guessing would have easily sealed itself. Really a struggle breaking the tire off the rim. Running GP5000's on HED Jet Blacks (love these wheels). The rims are set up for tubeless which definitely fits tighter & makes it harder to get the tire off the rim for on the road repairs. Figured if I have to deal with the mounting struggles anyway might as well have some of the advantages.
I don't suffer a lot of flats, a couple per year, although I did have 3 in one ride last fall.
What are good sealants? Are there better tire options that I should consider?
Voodoo76 is offline
Old 05-01-22, 08:30 AM
  #94
GhostRider62
Quoted: 2332 Post(s)
Liked 2,091 Times in 1,310 Posts
I rode tubeless from late 2015 until July 3, 2016. Depending on one's riding conditions and style of riding, a good argument can be made for tubeless or latex tubed clinchers. I am back on tubeless but only have a little over 1,000 miles on GP5000 TR S. They are not faster by my testing nor do they leak less than latex tubed clinchers-both need aired every day. But, I should think they take rapid deflation flats out of the equation, which is why I am back. I used to average several flats per year or around 3-5,000 miles per on clinchers and even went a whole year without one and then had two in one week. I had flats constantly on Compass and Schwabe Pro one tubeless. Go figure.
GhostRider62 is offline
