Need help/advice about a Peugeot Chorus
Likes For DaCox:
#52
Quoted: 971 Post(s)
Liked 871 Times
A Claris 2000 groupset would work. But speaking for myself, I do not like seeing any modern black parts on classic bikes. A used Shimano 600 6400 or Dura Ace 7400 groupset would look much better on this frame. It's not 'period correct' but at least it's period 'close enough'. They come with brifters and dual pivot brakes, so they will perform every bit as good as the Claris R2000.
Alternatively, if you want to stick with that existing hub and wheel, you can put a 7 speed freewheel on there, and move some locknut washers to the left and then re-center the wheel. You can either use a Shimano RSX 7 speed brifter to shift with that freewheel, or a Campy 8 speed Ergo brifter drivetrain would work too. I do not recommend running that 8 speed freewheel on that 126mm hub- too much axle overhang and too easy to bend the axle.
Likes For icemilkcoffee:
#53
Quoted: 1464 Post(s)
Liked 593 Times
Kudos to you for taking on such a challenge to get this Peugeot back to life!
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
#54
Bikes: Roberts SLX, Mercian 531, Torpado SLX, Peugeot PSV-10, Charlie Roberts full touring
Quoted: 59 Post(s)
Liked 92 Times
If the campag hubs are good, and the bottom bracket smooth, why not overhaul and reuse them. Good to see your progress.
