Wheels - lighter weight vs aero
Old 02-16-23, 02:05 PM
  #251
himespau
himespau's Avatar
Quoted: 4065 Post(s)
Liked 2,805 Times in 1,700 Posts
Originally Posted by smd4
Which is why I prefer circular ones.
Octagonal (dodecahedral even better) ones wear down to round eventually.
himespau is offline
Old 02-16-23, 02:15 PM
  #252
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 2711 Post(s)
Liked 2,735 Times in 1,381 Posts
For giggles, here's the answer from ChatGPT, which must have been reading BF:
When it comes to choosing between light wheels and aero wheels for climbing on a bicycle, it depends on several factors such as the type of climbing, the rider's ability, and personal preference.
In general, lighter wheels will make the bike feel more responsive and easier to accelerate, which can be an advantage on steep climbs where a rider needs to repeatedly increase and decrease their cadence. However, for longer climbs, where sustained power output is required, aero wheels can offer an advantage by reducing wind resistance and helping a rider maintain a higher average speed over time.
That being said, aero wheels are typically heavier than traditional, shallow-rimmed wheels, so the added weight could offset some of the aerodynamic gains, especially on steeper gradients.
Ultimately, the choice between light wheels and aero wheels for climbing on a bicycle will depend on a rider's individual preferences and goals, as well as the specific demands of the terrain they are riding on. For most riders, a balance between lightness and aerodynamics will be the best choice.
Ride, Rest, Repeat
terrymorse is offline
Likes For terrymorse:
Old 02-16-23, 03:00 PM
  #253
Eric F
Habitual User
Eric F's Avatar
Quoted: 4227 Post(s)
Liked 6,826 Times in 3,219 Posts
Originally Posted by rydabent
So you are a know it all about ALL rims produced now. Sorry I dont believe that. If you are an engineering expert, tell us why wouldnt all 3 things I mentioned be true?
One does not need to know everything about all rims being produced, or be an engineering expert, to recognize current trends in how wheels are being built, and understand the reasons why. Also, just because something can be made a certain way, doesn't mean that's the way it's being done in the real world.
A triangular shape may be a stronger structure shape for some applications, but it is not the most aerodynamically efficient for the application of a bike wheel, and therefore not a shape that is predominantly used. This has been going on since rim brakes were still the standard for road bikes, and has trended further away from triangular over the years. A rim doesn't need to be as strong as it possibly can be, it just needs to be strong enough to serve the demands of how it's used. It turns out that strong enough, light weight, and improved aero properties are all achievable with modern carbon fiber technology.
Eric F is offline
Old 02-16-23, 03:11 PM
  #254
Maelochs
Maelochs's Avatar
Quoted: 7452 Post(s)
Liked 3,138 Times in 1,677 Posts
Or ... since you made the claim ... produce some examples.
Maelochs is offline
Old 02-16-23, 03:13 PM
  #255
Maelochs
Maelochs's Avatar
As far as profiles, I thought ogive cross-sections mated in width to the mounted, inflated tire had been shown to be the most aerodynamic?
Maelochs is offline
Old 02-16-23, 03:17 PM
  #256
Trakhak
Trakhak's Avatar
Quoted: 2058 Post(s)
Liked 2,377 Times in 1,354 Posts
I read rydabent's comments about triangular-section rims as referring to deep aero rims. They're certainly closer to being triangular in section than conventional box-section rims. Made sense to me.
Trakhak is offline
Old 02-16-23, 03:22 PM
  #257
Eric F
Habitual User
Eric F's Avatar
Hmmm...Maybe you're right. That said, some of Zipp's rims don't look very triangle-y...
Eric F is offline
Old 02-16-23, 03:25 PM
  #258
tomato coupe
Quoted: 3564 Post(s)
Liked 6,492 Times in 2,622 Posts
Nah, there was nothing about deep aero rims vs. box rims in his statement. It was all about disc brake wheels and brake tracks:
With out the brake area, the profile can be more triangular, and everyone knows a triangle is exceptionally strong.
tomato coupe is offline
Old 02-16-23, 03:27 PM
  #259
Eric F
Habitual User
Eric F's Avatar
Compared with tires that are significantly wider than the rim (ice cream cone profile), yes. Matching rim and tires width is more aero. This is a big part of the reason why there has been a trend for wider rim widths.
Eric F is offline
Old 02-16-23, 04:14 PM
  #260
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 9263 Post(s)
Liked 10,402 Times in 5,291 Posts
Imagine riding them....
*THUD...THUD...THUD...*
genejockey is offline
Old 02-16-23, 04:17 PM
  #261
genejockey
genejockey's Avatar
Artificial Equivocation.
Likes For genejockey:
Old 02-16-23, 04:24 PM
  #262
rydabent
rydabent's Avatar
Quoted: 3238 Post(s)
Liked 1,013 Times in 608 Posts
While not a perfect triangle, they are what I was talking about. And notice there is not much metal in the area of the rim hook where the tire bead latches on to the rim.
Then----------remember not all rim makers are up to speed on the fact that disc brakes are here to say. They will have to get in new machinery to make the new lighter aero rims.
rydabent is offline
Likes For rydabent:
Old 02-16-23, 04:30 PM
  #263
base2
Doesn't brain good.
base2's Avatar
Bikes: 5 good ones, and the occasional project.
Quoted: 1585 Post(s)
Liked 1,367 Times in 786 Posts
There isn't any metal in the area of the rim hook where the tire bead latches on to the rim.
These are the new lighter aero rims.
smh
Car dependency is a tax.
base2 is offline
Likes For base2:
Old 02-16-23, 04:36 PM
  #264
genejockey
genejockey's Avatar
Yes, an oval is not a perfect triangle.
Old 02-16-23, 04:39 PM
  #265
Eric F
Habitual User
Eric F's Avatar
There is zero metal in these rims.
Which rim makers are denying that disc brakes are here to stay? I'm genuinely curious. It seems to me that rim brake wheel options are getting thinner as time goes on, which reflects the types of bikes being sold.
Eric F is offline
Old 02-16-23, 05:31 PM
  #266
smd4
Quoted: 2898 Post(s)
Liked 2,455 Times in 1,478 Posts
All I can tell you is that it would be a real ***** to mount the tires.
smd4 is offline
Likes For smd4:
Old 02-16-23, 07:04 PM
  #267
rsbob
Grupetto Bob
rsbob's Avatar
Bikes: Bikey McBike Face
Quoted: 2176 Post(s)
Liked 4,594 Times in 2,436 Posts
I asked an AI bot about aerodynamic versus light weight wheels:
Q: When climbing long grades and then doing long flat roads, which bicycle wheels are more efficient, aerodynamic or light weight?A: When climbing long grades, lightweight wheels are more efficient than aerodynamic wheels, as the reduced weight makes it easier to climb uphill. However, when riding on flat roads, aerodynamic wheels can be more efficient, as the reduced drag can allow you to move faster with less effort. Therefore, depending on the terrain, both aerodynamic and lightweight wheels can be beneficial.
Then I rephrased the question omitting hill climbing.
Q: Which bicycle wheels are more efficient, Aerodynamic or light weight?
A: Generally speaking, aerodynamic wheels are more efficient than lightweight wheels. Aerodynamic wheels are designed to reduce drag and increase the speed at which a cyclist can ride. This is achieved by using a deep profile and a smooth surface that reduces air resistance. Lightweight wheels, on the other hand, reduce weight but do not improve aerodynamic performance as much. That said, the best wheels for cycling are those that are both lightweight and aerodynamic.
Conclusion: when riding on mixed terrain use one of each.
Road 🚴🏾‍♂️ & Mountain 🚵🏾‍♂️
”Your lips move but I can’t hear what your saying” DG
rsbob is offline
Likes For rsbob:
Old 02-16-23, 07:47 PM
  #268
PeteHski
PeteHski's Avatar
Quoted: 3582 Post(s)
Liked 3,871 Times in 2,451 Posts
At least the chat bots are not yet claiming that rotational mass is worth 10x static mass. Maybe they will when they’ve heard it stated enough times on BF.
PeteHski is online now
Likes For PeteHski:
Old 02-16-23, 08:19 PM
  #269
RChung
Perceptual Dullard
Quoted: 806 Post(s)
Liked 957 Times in 412 Posts
What if you ride a tricycle?
RChung is offline
Likes For RChung:
Old 02-16-23, 10:47 PM
  #270
Maelochs
Maelochs's Avatar
Perfection.
This is why we need not fear AI taking over the world.
Maelochs is offline
Old 02-17-23, 07:04 AM
  #271
GhostRider62
Quoted: 2332 Post(s)
Liked 2,091 Times in 1,310 Posts
Zipp has changed their profile a lot of the years, from pointy triangular-like to bulbous toroidal cross sections with more recent ones less so. All dictated on the marketing. Joking aside, selecting the shape and depth as well as fitting a proper width tire depends on wind conditions, rider weight, rider skill, and rider speed. I have some wheels where the stall characteristic is unpleasant and others where it is much less so.
The new 303 Firecrests are much pointier than obsolete diagrams several posts up. The attached is well worth the read as long as the marketing drivel is ignored. I am very surprised at the claimed Crr benefits for the new 303 Firecrests, I have a set and planned to compare the CdA and Crr to a more narrow 62 mm set of wheels but am awaiting kinder weather.
https://www.sram.com/globalassets/pu...explained2.pdf
GhostRider62 is offline
Old 02-17-23, 11:40 AM
  #272
PeteHski
PeteHski's Avatar
Interesting read on several counts.
The acceleration comparison was interesting to show the effect of wheel rotational inertia on power:-
Full bore sprint acceleration from 40 kph at 0.13G requires 1067W for the bike/rider + 9.2W for wheel rotational inertia. Reducing wheelset mass by 300g and wheel inertia by 23.5% gives a reduction in required power of 4W, of which only 0.6W is due to the reduction in rotational inertia. You get that whopping advantage for as long as you can accelerate at 0.13G i.e. a few seconds at most until your speed tops out.
Likes For PeteHski:
Old 02-17-23, 12:24 PM
  #273
rydabent
rydabent's Avatar
Well-----------------up hill-------------down hill------------------and on the flats.
rydabent is offline
Old 02-17-23, 12:30 PM
  #274
big john
big john's Avatar
Quoted: 7538 Post(s)
Liked 7,942 Times in 3,995 Posts
Trikes use tri-spoke wheels. Everyone knows that.
big john is online now
Likes For big john:
Old 02-17-23, 09:42 PM
  #275
chaadster
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 2774 Post(s)
Liked 1,573 Times in 963 Posts
Well it took a hell of a lot of chatter— 269 posts to be exact— to prove the veracity of the aphorism stated in post #3: aero trumps weight.
Thanks for carrying the torch, PeteHski.
chaadster is online now
Likes For chaadster:
