Wheels - lighter weight vs aero
Old 02-13-23, 11:01 PM
  #151
elcruxio
elcruxio's Avatar
Bikes: 2011 Specialized crux comp, 2013 Specialized Rockhopper Pro
Quoted: 748 Post(s)
Liked 257 Times in 175 Posts
Originally Posted by venturi95
My whole argument was about climbing on a 7% grade being faster on aero wheels. The work in the link is referring to a climb with a 16.8 mph average speed, and 1/100th of a watt? Probably beyond the resolution of the instrumentation.
Almost everybody knows this. Merckx was furious, he had never lost a time trial to Moser:
The lenticular carbon-fibre disc wheels weighed 4.6kg between them and were intended to work like flywheels, allowing Moser to maintain a constant pace once up to speed. The total weight of Moser’s bike was 9.6kg — nearly twice the 5.75kg of Merckx’s machine.
Good luck on a real climb with these wheels, you would be hating life.
And here's me with a fatbike that has a combined wheel and tire weight of 5.7kg
It climbs fine. I have a really hard time imagining wheel inertia makes that big of a difference as then I'd have real trouble making those explosive accelerations on 7% climbs you'd need to hop a fallen tree etc. And those sorts of things don't really pose a challenge, mainly because the added weight on the wheel compared to my overall weight is so small.
The only place wheel inertia begins to maje itself known is at 50kph+ speeds where you need to start thinking steering a little bit differently.
elcruxio is offline
Old 02-14-23, 09:44 AM
  #152
RChung
Perceptual Dullard
Quoted: 814 Post(s)
Liked 961 Times in 414 Posts
I disagree. You are assuming the rider's output is a mathematically perfect model. In reality there is a pulsating nature of power output, twice each crank revolution, from beginning to end of the climb. With a cadence of 80 rpm, 160 times a minute the rider is trying to accelerate upwards. "Micro accelerations" do not simply cancel each other out.
Take two identical riders and bikes. Have the first climb a steep 3 mile hill at 6 mph (30 minutes). Have the second climb the same hill in 30 minutes, but have him coast (no brakes) to a stop every 100 feet. Your argument says they do the same energy expenditure, perhaps mathematically they do, but we all know that's just not how cycling uphill works.
Oh, FFS, do you not see the guy slowing at the bottom of his pedal stroke? You are the one inventing here, HUMANS DO NOT PEDAL PERFECTLY 360 degrees, more so when stressed a bit climbing.
Most of this thread is about the demand for power imposed by different wheels. That's a physics problem. You've introduced something about the supply of power, which is a physiology problem. The physics problem describes the minimum amount of power one would need to make, and includes both static mass, and rotating wheel mass. However, there are lots of different ways for a rider to produce that power; some of which are "harder" and others "easier": for example, speeding up past your threshold and then coasting to a near stop, then speed up past threshold again. That's a physiological issue, not about the wheels. That is, if you're speeding up past threshold and then coasting, that's not something that is dependent on the wheels. You can be that hard-headed whether you're using light or aero wheels.
RChung is offline
Old 02-14-23, 11:14 AM
  #153
Fredo76
The Wheezing Geezer
Fredo76's Avatar
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 333 Post(s)
Liked 723 Times in 350 Posts
Originally Posted by terrymorse
I've given this a fair amount of thought, and I suspect there may be a feature of climbing where wheel inertia matters.
Let's call it "micro decelerations-accelerations". Whenever the grade goes up even slightly, the speed drops quickly, and the rider must put extra force on the pedals to get back to speed. These very short bursts of acceleration add up, and if the wheels have more inertia, that effort requires more peak pedal force and total power.
One might reply that the heavier wheels also decelerate less quickly. Sure, but they require more power (and force) to bring back up to speed, and that's the part that causes leg fatigue.
I've climbed with light wheels and heavy wheels, and the heavy wheels definitely were more fatiguing.
Just a thought.
I agree 100%. And don't forget the micro-accelerations required to stay with someone going faster. In racing, that happens a lot.
Originally Posted by PeteHski
Only on BF do people regularly dispute basic physics. I knew this would happen, it always does.
Again with the physics! Our argument is not with the physics, but with the simplifying assumptions in the model.
"Because...PHYSICS!!" is every bit as lame as "Because...COMPUTERS!!"
I'm not ignoring the laws of inertia at all. I'm just saying that you can ignore wheel inertia when there is little or no acceleration involved e.g. steady state climb. For changes in inertia to matter, you need to be measuring significant accelerations. Any "micro-accelerations" during your pedal stroke are by definition "micro" i.e. approx. zero. And for every one of these micro-accelerations, there will be a micro-deceleration where the energy is recovered. It's one of the fallacies that persists in this type of discussion. I've heard it before and no doubt someone will mention it again next time. But the amount of power you need to climb a hill at an average speed can be predicted accurately from total mass, rolling resistance and aerodynamic drag. You don't need to know wheel inertia and it will make zero difference to the prediction, except maybe a tiny fraction of time while you initially accelerate from 0-15 kph or whatever on the climb.
Much more accurate. If you're not accelerating, rotating weight has no more effect than static weight.
Originally Posted by asgelle
Kraig Willett actually did the experiment and his measurements show adding 1000 gm to each rim is equivalent to adding anywhere from 2000.2 and 2002 gms of static weight. Huge.
My read of the Kraig Willet article was that he didn't do any measurements, but rather just plugged various scenarios into a model that has a known flaw with regard to wheel-weight arguments. I could be wrong about that, but I don't see it. BTW, I don't see any of the referenced appendices, either...
Why don't you just admit that you were wrong, learn a little and move on? I'm a professional mechanical engineer, so I get paid to know this kind of stuff and I see a lot of people get confused about the importance of all these various parameters. I probably would if I did something else for a living. There is only shame in denial.
Now we're getting insulting. You scolded me for that earlier.
Can we all agree that the physics does say that the effect on acceleration of rotating weight at the radius is twice that of static weight, but only when accelerating? That is my understanding of the model.
Fredo76 is offline
Old 02-14-23, 11:38 AM
  #154
tomato coupe
Quoted: 3573 Post(s)
Liked 6,508 Times in 2,629 Posts
If wheel A weighs more than wheel B, the extra mass is almost certainly not located at the full radius of the tire, which would be required for a doubling of the effect on acceleration. A more realistic distribution of the extra mass, and the radius-squared factor in rotational inertia, means the effect on acceleration will be much less than a doubling.
tomato coupe is offline
Old 02-14-23, 11:45 AM
  #155
Maelochs
Maelochs's Avatar
Quoted: 7452 Post(s)
Liked 3,138 Times in 1,677 Posts
I think that what people are saying here is that things like the slight differences in power through a pedal stroke and the slight differences in rotating mass when doing the slight accelerations (because no one climbs at a perfectly steady pace, and no road is a perfectly smooth, steady grade) are Not Significant.
There was a thread many years back about bike weight, where people were arguing some nonsense about removing the weight of a molecule made a real, measurable difference in performance ... mathematically. People were really arguing such stuff!! It was hilarious.
If people can show real, experimentally derived figures illustrating exactly how many watts a rider loses while climbing with lighter wheels versus heavier wheels, balanced against similarly experimentally-derived numbers showing the gains and loses made to aerodynamics ... please do.
Perhaps in racing situations, there are more significant accelerations as riders attack on hills .... so show the numbers there. Wouldn't the aero benefit go up as speed went up, though?
So, the experiments would have to measure watts lost to aero and watts lost moving weight at a variety of speed and grades, steady-state and under different degrees of acceleration (not Micro-acceleration ... I think it seems obvious that the 2.5 pulses per second of a rider climbing with a cadence of 80 are too tiny to be deemed "significant"---there is neither enough time to lose much speed nor to gain much. Even at a cadence of 40, where you can much more feel the power pulses, the actual time spent accelerating vs. decelerating ... 1.2 pulses per second so peak accelerations for less than half a second? Go ahead and measure the watts lost and gained based on wheel weight, if you can.)
This is like the scraped-paint debate. If two identical riders on two identical bikes set off, but just before starting one scratches off a thumbnail's worth of paint from the frame, he has the advantage. Mathematically, sure ... but we don't ride mathematical models. Show Significant gains or losses ..... if the measurable losses and gains are not greater than the noise, the margins of measuring error, then they are not real.
Show me the numbers on how much is gained and lost due to cadence on a bike with lighter, less aero wheels versus heavier, more aero wheels.
Theoretically, the rotation of distant galaxies affect us all the time, but because the effects are so tiny as to be only calculable, not measurable ......
Maelochs is offline
Old 02-14-23, 11:59 AM
  #156
PeteHski
PeteHski's Avatar
Quoted: 3608 Post(s)
Liked 3,890 Times in 2,465 Posts
At this point I’m pretty sure they will continue to believe in the importance of wheel rotational inertia regardless of any data or mathematical modelling.
What they won’te able to do is quantify it or explain it to anyone with a basic understanding of the physics. It is classic BF pseudo-science.
Kudos to RChung for being so polite, but I expect he’s been through this pointless exercise so many times that he realised long ago that some people won’t listen to any explanation that isn’t in line with their original view of the world.
PeteHski is offline
Likes For PeteHski:
Old 02-14-23, 12:00 PM
  #157
Jughed
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 387 Post(s)
Liked 531 Times in 266 Posts
My head hurts... and I still don't know what wheels to buy.
Jughed is offline
Likes For Jughed:
Old 02-14-23, 12:07 PM
  #158
PeteHski
PeteHski's Avatar
Mate, just buy some reasonably light 35-50 mm deep aero wheels with 20+ mm internal rims within your budget and ride with the knowledge that a few hundred grams isn’t going to make any major difference.
PeteHski is offline
Likes For PeteHski:
Old 02-14-23, 12:09 PM
  #159
Jughed
Quoted: 387 Post(s)
Gotcha - that post wasn't serious.
Jughed is offline
Likes For Jughed:
  #160
RChung
Perceptual Dullard
Quoted: 814 Post(s)
Um, I 've done that.
RChung is offline
Old 02-14-23, 12:30 PM
  #161
Maelochs
Maelochs's Avatar
I was not arguing with you, sir. I have seen you here long enough, and gotten lost enough in your various postings .... You imprss me as being a very real and practical engineer who does the work, the experimentation and the calculation, and you know your stuff .... IMO.
Sorry I did not make it clear. I was talking about the people who do not accept your science.
The only question I had about your explanation was the issue of acceleration, which you explained to me (and explaining math and physics to me is a tough row to hoe, I know.)
I was addressing the people who did Not do the work you did and did not produce actual numbers as you did, and still argued againsnt the actual ... well, science.
Sorry I was not clear.
Maelochs is offline
Old 02-14-23, 12:35 PM
  #162
tomato coupe
You impress me as being a very real and practical engineer ...
There's no reason to insult him.
Old 02-14-23, 12:46 PM
  #163
RChung
Perceptual Dullard
Quoted: 814 Post(s)
My brother was trained as an engineer. He once declared, "The difference between engineers and physicists is that engineers think an equation is an approximation of reality and physicists think reality is the approximation of an equation." I was trained as a mathematician so he waited two beats while I was pondering that before he finished, "mathematicians haven't yet realized there's any connection."
RChung is offline
Old 02-14-23, 12:54 PM
  #164
asgelle
Quoted: 1000 Post(s)
Liked 426 Times in 251 Posts
I don't know if this is sloppy wording or truly a lack of understanding, but there are no simplifying assumptions in the Martin model with regard to acceleration. If the model results you've looked at haven't treated accelerations (micro or otherwise) to your liking, that isn't the fault of the model but how those people have chosen to apply it. If you're that interested, it would be straightforward to solve the equation with a time-varying input power to see the impact of micro accelerations, wheel weight, moments of inertia, or whatever parameter(s) you choose.
asgelle is offline
Old 02-14-23, 12:58 PM
  #165
tomato coupe
I have degrees in all three, so I know the jokes from all sides.
Likes For tomato coupe:
Old 02-14-23, 12:59 PM
  #166
RChung
Perceptual Dullard
Quoted: 814 Post(s)
My condolences to all your family and friends.
RChung is offline
Old 02-14-23, 01:00 PM
  #167
asgelle
One of the benefits of a well validated model (and the Martin model certainly qualifies) is that one can use it to answer such questions without the significantly greater time and effort of doing such experiments.
(by the way, no experiment can produce an exact result.)
asgelle is offline
  #168
Eric F
Habitual User
Eric F's Avatar
Quoted: 4246 Post(s)
Liked 6,857 Times in 3,239 Posts
You are a marketing department's nightmare - LOL.
Eric F is offline
Old 02-14-23, 01:02 PM
  #169
tomato coupe
They all think I'm a rancher, so I slip by unnoticed.
Old 02-14-23, 01:15 PM
  #170
PeteHski
PeteHski's Avatar
So does anyone with a degree in engineering, physics or mathematics agree with the importance of "micro accelerations" during the pedal stroke or believe that wheel mass is equivalent to approx double static mass when climbing?
PeteHski is offline
Old 02-14-23, 01:25 PM
  #171
tomato coupe
Three nopes here ...
Old 02-14-23, 01:36 PM
  #172
Calsun
Quoted: 559 Post(s)
Liked 346 Times in 263 Posts
The value of aerodynamics is a function of speed and it is completely different for a pro time trial where rides are averaging over 30 mph for this distance as compared to a pro hill climb at lesser speeds. One does not see effort to make bike wheels more aerodynamic on the non time trial stages of the various pro tour races.
On climbs what is important is how much power from the rider is effectively transferred to forward motion of the bike and that primarily affects frame geometry and to a lesser degree the gears available. All things being equal a lighter bike provides some advantage although how much is real and how much is psychological is another matter.
A friend who used to go on long rides with me had insisted that his bike was faster on the downhill sections than mine. At the top of one steep grade we switched bike and coasted to the bottom. He was faster on my bike and it was due to his extra 20 lbs of body weight. He was at a disadvantage going up the grades but compensated to some degree on the downhill sections. After I changed out my large chainring for a 60-tooth one he lost his advantage on the downhills as I could continue to pedal.
Calsun is offline
Old 02-14-23, 02:06 PM
  #173
Koyote
Quoted: 6569 Post(s)
Liked 10,301 Times in 4,413 Posts
This is how they treat the engineer on TV. (Although to be fair, this is more of a knock on the Master's degree.)
Koyote is offline
Old 02-14-23, 02:18 PM
  #174
Maelochs
Maelochs's Avatar
As is mentioned here, (https://www.cyclist.co.uk/in-depth/w...tweight-wheels) even on climbs except at walking pace aero generally saves more watts than lighter weight. if you are riding multiple high-degree switchbacks and accelerating out of the corners, at low speeds, light wheels are marginally better. if you are doing anything steadily ten mph or more (they claim,) you save a tiny bit more with aero.
I think this is all in the Sky Racing "Marginal Gains" category ... the 0.1 percent advantage which only matters if you have a bunch of such advantages .... or if you just like one or the other .....
Ultimately everyone is just going to pick a position, buy a product, and consider it the best for that person's use. And no one is going to do a bunch of measurements to see if that person is right or wrong. it only matters as much as it matters to each individual .... no one else much cares.
A mathematician, a physicist, and an engineer went to a bike race ......
Maelochs is offline
Old 02-14-23, 02:28 PM
  #175
himespau
himespau's Avatar
Quoted: 4067 Post(s)
Liked 2,805 Times in 1,700 Posts
Honestly, I think the psychology of it (and "knowing" your way is right and that you are on the "best" possible setup for your situation) provides more benefit than the very marginal gain provided by lightweight or aero wheels as long as the wheels are appropriate to the frame, are (mostly) true and don't rub anywhere.
himespau is offline
Likes For himespau:
