SRAM Force eTap AXS FD chain drop
#51
FWIW, my frames all have relatively steep 74.5 degree STAs. I honestly don't care what the problem might be for others.
#52
Quoted: 3572 Post(s)
Liked 6,507 Times
This is truly one of the strangest responses I've ever read -- what did I misconstrue about your statement?
Where the heck did I claim the problem was due to seat tube angle? You have a serious problem with reading comprehension.
It just seems obvious to me that there are either many incompetent mechanics or some other issue ... The idea of incompetent mechanics was thoroghly thrashed on another site...
Originally Posted by Tomato Coupe
Your claim that most mechanics are incompetent is nonsense, and was rightfully trashed.
Originally Posted by DaveSSS
You have a interesting ability to misconstrue just about anything written. I never made any such claim.
Others report such problems- no one can make their bike work. So now you're postulating that STA is the problem? No one has ever mentioned that suspicion, but you. Just add that to all of the other impossible to prove theories.
#53
What other part of frame geometry might affect FD operation, other than STA?
#54
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 2778 Post(s)
Liked 1,581 Times
Insofar as these claimed FD issues are even issues— which I don’t think they are; I think this largely something akin to a mass hysteria springing from the old SRAM Yaw deraillers— it is possible that people are using the wrong FD for their frame and crankset. I have no idea how many people having “issues” aftermarket installed their Force AXS, and very few with complaints ever indicated FD model, or even the frame model, so it’s all just a hot mess of inaccuracies and incomplete information which, when considered in light of how many Force AXS FDs are out there spec’d as OE, just doesn’t add up to something credible by my reckoning.
#55
FWIW, I used a grx wide crank with my force FD before correcting the chainline with spacing washers to a normal road chainline. It worked, but the big ring limit screw was within 1/2 turn of being maxed out. I now have 3 grx 46/30 cranks in use with the corrected chainline. Interesting that 7 cranks, 6 frames and a dozen easy FD setups isn't considered significant experience. Somehow I've fumbled through many builds without a single problem. This issue gets repeated about once per week on the sram axs owners web page on Facebook. Most complaints are from those who just got their new bike from a local shop that can't fix the problem.
#56
Thread Killer
Liked 1,581 Times
#57
Quoted: 8 Post(s)
Originally Posted by tomato coupe;[url=tel:22919062
22919062[/url]]Your claim that most mechanics are incompetent is nonsense, and was rightfully trashed. And, since you've always worked on essentially the same frame geometry, your experience is actually rather limited.
#58
Quoted: 8 Post(s)
Originally Posted by chaadster;[url=tel:22919435
22919435[/url]]No, I’m with you, man. And call me old school, but when I see noobs like Jonob sign up to BF this month and only make posts insisting they have “significant problems” with their FD and condemning SRAM without presenting any evidence they know what they’re talking about, what kind of bike they’re dealing with, or that they even have a Force FD, all sorts of red flags pop up for me. Oh, and don’t forget the move “a bunch of my buddies have problems too and work with different shops…”. Yeah, okay, the outlandish claims aren’t sus at all; do they really think they’re the only ones who know folks with AXS?? Where I’m from, randos blathering doesn’t amount to anything serious; it’s just peanut gallery crap.
That is an unhelpful post. I came on here looking for a solution or at least some help not for someone to suggest that I don’t know what I’m talking about. I never suggested I know what I’m talking about. I bought a focus izalco max with sram force AXS D1 in 2020.
I have dropped the chain countless times.
I have never worked on my bike. Three different mechanics have and I have continued to have chain drop issues.
you gave exactly zero solutions
#59
Thread Killer
Liked 1,581 Times
I’ve had significant trouble with sram force axs chain drop. It happens randomly. I have had it set up by three different mechanics. We have shorted the chain, set the limits very tight and I have a chain catcher. The only solution seems to be to upgrade the force front chain ring to a red front chain ring ( interestingly the new sram force front chain ring is one piece of metal just like the red front chain ring) seems like there is too much flex in the original force chainring and it sometimes throws the chain off
That might have been excused as a first day newbie mistake, but your response was not to take the hit, understand the situation, and make it right, it was to attack a 14 year veteran member with thousands of posts, trying to hold me accountable to be more helpful to you, a random nobody, rather than to the community. That’s more proof that you’re probably just a bad actor who came here with an axe to grind.
#60
Overall, this thread is ridiculous because of one poster trying to derail nearly every comment while adding nothing of value.
A link to SRAM's latest video has been posted. That video is as thorough as any, but I disagree with trying to hold the FD in position while final tightening of the clamp bolt is done. If the FD rotates out of alignment, it should be set crooked to start with so the alignment becomes correct when tightening is complete. The plastic tool is really only good for setting height. The plastic tool wasn't even made when I bought my first two Force groups.
One thing I've never read of anyone trying is to simply buy another FD to see if it works differently. The cheapest rival model has markings that may be easier to align and shifts just as well. I've also never read of anyone trying a Shimano or Campy crank as a solution. That's all I've ever used and had zero problems.
The frame geometry comment went nowhere. Sram makes a wide FD for gravel bikes with a +2.5mm chainline. Road bikes don't need it. If someone suspects a frame geometry issue, they should include what the potential problem might be. Otherwise they make no contribution to this discussion.
If you're using sequential or compensating modes, turn those off. I just set a two sprocket limit for multi-shifts and use that for compensation. If you're shifting while pedaling with a high torque on a climb, let up for a second during the shift.
I've never used SRAM cranks due to their limited range. The other brands both make cranks with a 16T difference and they work. Sram says that 13T difference shifts better.
Likes For DaveSSS:
#61
I see nothing unusual about the geometry of the Izalco max. If you zoom in on the picture, the FD looks to be set too high, but the curvature of the cage aligns with the chain ring teeth better than it does on my bikes with 74.5 degree STAs.
https://www.focus-bikes.com/int/1069...or_combo=97278
#62
Quoted: 8 Post(s)
#63
Bikes: SL8 Pro, TCR beater
Quoted: 810 Post(s)
Liked 475 Times
1) Low limit screw is set so that the chain is rubbing the cage just a little when on the big / small combo (it's less than 0.5mm for sure). I will leave it like that since chain is no longer dropping between the frame and the small ring. I guess I could try 1/4 or 1/8 of a turn to push the derailleur a little further towards the frame, but I am comfortable with where it currently is.
2) High limit screw is set so that the chain is almost touching the cage (also less than 0.5mm) when on the small / big combo.
3) FD height is set to the lowest possible (top of the line)
4) FD rotational angle is as parallel as possible to the big ring
My wild guess is that low limit screw was making the chain drop when shifting from big to small ring and that the derailleur height was making the chain drop when shifting from the small to the big ring.
Likes For eduskator:
#64
Quoted: 3604 Post(s)
Liked 3,884 Times
It works for now. Everything was within specs when I left the LBS with the bike, but I adjusted everything ''more tightly'' and it seems to have worked.
#65
Liked 6,507 Times
#66
Here's something never mentioned. Cranks with two separate rings must be properly aligned. There's usually some mark that must be aligned with the crank arm. I have read of one person having rings attached out of alignment. It won't shift well.
#67
Quoted: 8 Post(s)
Originally Posted by DaveSSS;[url=tel:22921283
22921283[/url]]Here's something never mentioned. Cranks with two separate rings must be properly aligned. There's usually some mark that must be aligned with the crank arm. I have read of one person having rings attached out of alignment. It won't shift well.
#68
One piece rings aren't likely to fix anything. You just have to be smart enough to put two rings on the crank arm properly.
#69
Quoted: 8 Post(s)
does this sound possible or reasonable?
#70
Quoted: 810 Post(s)
Liked 475 Times
L and H limit screw loosening up on a 3k$ groupset?
Gotta love Shimano.
They will both cause chain drop or rub for sure if not adjusted properly. Can't tell if there is known instances of them loosening up though.
#71
Liked 3,884 Times
i read on another forum someone suggested that road vibration may move or loosen the upper and lower limit screws and this may result in a chain drop. They suggested using some low grade loctight or some other product to make sure the screws don’t move
#72
Thread Killer
Liked 1,581 Times
I heard its caused by Russian hackers using mini-EMP generators when meddling in USA elections. Is it possible our FDs are collateral damage?
Likes For chaadster:
#73
Quoted: 8 Post(s)
Likes For tankist:
#75
Quoted: 810 Post(s)
Liked 475 Times
Update on my issue - no chain drop in the last 300kms.
Lesson learned: Don't rely on the marks' possible tolerance; adjust everything as tight as possible (FD height = cage as close as possible to the big ring, FD rotational angle angle = perfectly parallel to the big ring, low and high limit screws = adjusted to no more than 0.5mm of gap between the cage and the chain).
