SRAM Force eTap AXS FD chain drop
#76
Update on my issue - no chain drop in the last 300kms.
Lesson learned: Don't rely on the marks' possible tolerance; adjust everything as tight as possible (FD height = cage as close as possible to the big ring, FD rotational angle angle = perfectly parallel to the big ring, low and high limit screws = adjusted to no more than 0.5mm of gap between the cage and the chain).
Likes For DaveSSS:
#77
Quoted: 8 Post(s)
From sram rider support
Levi (SRAM (Tickets))
Jun 22, 2023, 16:39 CDT
Hi Jonathan,
Thanks for getting back to me. It does seem strange that the issue is solved for a while and then pops back up. Based on that, I would apply a fresh thin coat of Blue Loctite 242 to the mounting bolt as well as the limit screws, as it could be that we have adjusted enough times that the factory Loctite is worn away.
As far as troubleshooting a chain drop to the inside, here are some instructions for that:
If the chain drops inboard when shifting to the small chainring: With the front derailleur in the inboard position, rotate the low limit screw clockwise 1/8 turn. Repeat until the chain no longer drops from the chainring.
As far as downshifting at a high cadence, it is possible, depending on timing and pressure here, that this could cause a shift failure. I recommend that when you are shifting any front derailleur system, it is best to keep an average cadence, keep even pressure, then actuate the shift and allow the chain to move fully to the other chainring for a full crank rotation, then proceed from there to whatever power and cadence you would like to be at. If you have any other questions or concerns, don't hesitate to reach out!
Warm regards,
LeviSRAM Rider Support
Hi Jonathan,
Warm regards,
#78
Bikes: SL8 Pro, TCR beater
Quoted: 804 Post(s)
Liked 475 Times
You can't screw it indefinitely though. At some point, you'll be out of specs. My low limit screw sets the FD cage under 0.5mm for sure - my chain rubs on it just a little when on the small ring / big cog, but it's not dropping anymore since I did this. I did 1/8 turn adjustments each time and rode it until I no longer had chain drop when going from the big to the small ring. It took 3-4 times.
This is bullcrap at this price tag. If you ask my opinion, it's the kind of answer a company gives to its clients when it has an engineering issue with a product that they're not able to fix. I've had 2 bikes equipped with Ultegra DI2 and 2 other bikes with 105 before my current one equipped with Force AXS and never did I have a chain drop under load. I beat them up pretty good during their life (used it like it's meant to be used) and I've never had a chain drop, under hard load or not. It clearly doesn't like to be shifted under hard load and it lets you know, but the chain does not drop.
Likes For eduskator:
#79
Quoted: 3529 Post(s)
Liked 3,819 Times
But it probably does explain why some riders suffer more chain drops than others. Whether that’s a SRAM thing or not. I’ve had about the same number of rare drops on both SRAM and Shimano. My Shimano 105 R7000 will occasionally drop on a front downshift if the cadence is very high and the road is bumpy. My SRAM Force has dropped occasionally when upshifting. Nothing different to what I’ve experienced with older setups through the ages. Chains drop occasionally as we see in the pro peloton.
Likes For PeteHski:
#80
Hi Jonathan,
Warm regards,
Hi Jonathan,
Warm regards,
The high limit screw is left hand threaded and works such that turning the screw CW moves the cage inward. In the big ring and smallest sprocket, turn it CW until you get some chain rub, then go CCW 1/4 turn. Never turn the high limit screw unless the FD is in the big ring position. I never shift under a heavy load, but you have to keep the crank moving, or you could create a chain drop.
Likes For DaveSSS:
#81
Quoted: 989 Post(s)
Liked 1,010 Times
i read on another forum someone suggested that road vibration may move or loosen the upper and lower limit screws and this may result in a chain drop. They suggested using some low grade loctight or some other product to make sure the screws don’t move
does this sound possible or reasonable?
Likes For Camilo:
#82
Quoted: 989 Post(s)
Liked 1,010 Times
Likes For Camilo:
#83
Quoted: 8 Post(s)
fair enough
#84
Quoted: 8 Post(s)
Are your bikes force or red ?
Likes For Camilo:
