Shimano Introduces "Warp Resistant" Road Disc Rotors
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 388 Post(s)
Liked 324 Times
This is the common complaint with Shimano (and perhaps other brands) and has been my experience as well. Where I live, it seems to be cool to put a stop sign at the very bottom of a hill. As a result, I'm on my brakes really hard to come to a complete stop and when I start moving again, one or both rotors start rubbing for a while which eventually goes away. It's my understanding that the new 12 speed Shimano group brakes have a very slight increase in pad gap distance to reduce the rubbing noise caused by the tight pad clearance.
Likes For PoorInRichfield:
Where can you get these mythical $2 rotors?
Shimano rotors tend to be a complex construction of a alloy spider, rivets and and a sandwich brake rotor. All with different temperature expansion coefficients. Im sure a simple 6 bolt, single piece, stainless rotor would be less prone to warping.
Quoted: 1397 Post(s)
Liked 1,876 Times
Shimano claims the three layer rotors (aluminum core between steel plates) with aluminum carrier manage heat more efficiently
because aluminum dissipates heat better than steel - I'm going to side with the Shimano engineers
Liked 1,876 Times
https://en.wikipedia.org/wiki/Bimetallic_strip
Quoted: 1248 Post(s)
Liked 1,323 Times
Thats fine, however bonding metals with different coefficient of thermal expansion is very much likely to produce warping in the presence of heat. The principle is used in a long variety of mechanical and electrical contraptions exactly for that reason. Shimano may be able to out engineer the effect, but reducing warping sure is a lot easier in a single piece brake disc.
Quoted: 800 Post(s)
Liked 512 Times
I don't know. I am no engineer but I think the engineering Shimano has done behind the Ice-tech rotors is pretty damn amazing.
Likes For NoWhammies:
Your internet sleuthing missed a key point, BiMetal does not have the corresponding material on the other side of this the warping. Given the design I would state that the trimetal design is actually more stable than a solid disk. Much like a sheet of plywood is more stable than a single plank.
Liked 1,323 Times
Then again, If the design was inherently balanced and warp resistant, then why would Shimano have to redesign and market an improved, warp resistant design that is "Designed to significantly reduce heat deformation during long, steep descents". Shimano discs was always a triple sandwich, that clearly isn't inherently warp resistant. Quite the contrary. Warping/pinging and delamination are common complaints, that are likely to originate in the sandwich of dissimilar metals.
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
I think what some people interpret to be transient rotor warping is instead failure of a piston to fully retract, which can usually be resolved by one or two additional short sharp squeezes on the brake lever.
