Splice cables?
Splice cables?
Old 09-21-23, 02:54 PM
  #51
Eric F
Habitual User
Eric F's Avatar
Quoted: 4687 Post(s)
Liked 7,578 Times in 3,585 Posts
Originally Posted by juntjoo
Thanks. Yeah, I'm not doing anything very dangerous on my bikes. I get the danger in compromising the brake cables. So this is why I'm asking l fishing for ideas.
If broken cables is a serious problem (I'm betting it's a maintenance/use issue), and breaking one will leave you totally stranded, the best bet is to carry an extra brake cable and an extra derailleur cable with you. Learn how to install it and adjust it in the field. In reality, unless you're riding in extreme conditions, in remote parts of the world, it's most likely that you can ride to a place of safety/repair without the use of one brake and/or one derailleur.
Eric F is offline
Old 09-21-23, 04:40 PM
  #52
FBinNY
Quoted: 5628 Post(s)
Liked 2,249 Times in 1,262 Posts
FWIW electrical connectors are not suited to load bearing applications.
They're only capable of supporting the weight of the wires, plus a reserve for vibration. ANY meaningful tension will pull the wire free.
There are load capable connectors. They usually have visible means of distorting the wire, ie. a raised bump with matching hollow, to make a bend that resists slipping.
If you're going to carry something for emergencies, carry a spare cable. Or buy a staight pull spoke and cut a 2" segment. In a pinch this can be used in the RD to select a single middle gear, and trim with the barrel. Now you have a 2s to get home with. In a pinch, you can reset the spoke to select a lower gear gor a tough climb.
FBinNY is offline
Old 09-21-23, 04:49 PM
  #53
choddo
Quoted: 563 Post(s)
Liked 368 Times in 280 Posts
Could this fraying be related to the apparent infrequent maintenance evident in certain photos?
I mean, Iíve had a couple of cables go from fraying - but only inside the shifter (and I suspect that was partly down to twisting them during installation while the nugget on the end was trapped) But never had a brake cable go that way. Or any way come to think of it.
I totally relate to the economic challenges though. Not right now thankfully but back in the dayÖ basically every job on my bike as a kid had better be fixable with an adjustable wrench, a drill or a hammer. That was my entire toolkit.
choddo is offline
Old 09-23-23, 10:03 AM
  #54
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 797 Post(s)
Liked 1,184 Times in 624 Posts
Originally Posted by 79pmooney
98% of the sailboats out there have masts held up with steel cables and cable ends that are in effect half of a splice. My two small sailboats used cables with a breaking strength of 2000 lbs. Ends were made with standard telephone linesman nicro presses. Done right, there is absolutely no reason spices cannot be done on brake cables. But - that done right bit is important, even life-saving critical.
you're talking about a hydraulic crimping tool with forged dies that compresses a steel sleeve, and you're right, those are very strong. Like aircraft control cables.
but the OP was referring to those color coded wire crimp connectors that you buy off the rack at a hardware store and those are definitely not safe for use as brake cables. A cable "spliced" that way will pull apart at the worst. Possible. Time.
Don't do this, people.
/markp
mpetry912 is offline
Likes For mpetry912:
Old 09-24-23, 11:31 AM
  #55
grumpus
grumpus's Avatar
Quoted: 386 Post(s)
Liked 353 Times in 273 Posts
https://a.co/d/dB1GXQ0
These are more what I had in mind.
"Tin plated brass" so you'll not get a lot of clamping force before it threatens to strip - copper or aluminium cables deform which helps grip when they're clamped, steel not so much. Also you'd need to fold the cables several times or find some other way to fill that big gap.
grumpus is offline
Likes For grumpus:
Old 09-24-23, 04:21 PM
  #56
grumpus
grumpus's Avatar
Quoted: 386 Post(s)
I'm poor. and I seem to fray cables somehow and I like figuring things out even if there's nothing to figure out. I'm curious
Things you can do to save money on cables: buy in bulk, you can get ten cables for under a tenner, which is way cheaper than ordering individual cables and you'll have a spare as soon as you need it. Buy universal cables, the ones with a different nipple on each end - if you're lucky you can get two front cables from one universal, but you need both a road bike and MTB to make use of them. Re-use a rear cable on the front when it's all chewed up by the clamp but the rest of the cable is fine. Make/repair your own - not really relevant here, but if you have the equipment and inclination you can make nipples from steel or brass and solder on - repair a cable the nipple broke off, or use an offcut to make a straddle wire.
Grease: if you grease a cable when you fit it, it will work better for longer.
Fraying: fit a crimp or solder the end to stop it fraying, then you stand a chance of refitting it after cleaning and greasing. Don't overtighten pinch bolts to the point that they cut cable strands - if you get cut strands check for sharp edges and soften them with a small file.
Casing length: the casing will be long enough that it doesn't kink at any point in its movement, and short enough that it doesn't introduce unnecessary slack into the system (or just wave in the air and look stupid/get caught on something). Curves should be smooth, S-bends minimal (if the cable bends one way then the other, consider if one of the bends can be reduced or removed by shortening the housing). Good routing will allow cables to work better for longer.
grumpus is offline
Likes For grumpus:
