Need Kickstand for Carbon Fiber Touring Bike
Old 06-09-22, 08:39 PM
tombc
Quoted: 25 Post(s)
Liked 31 Times in 13 Posts
normally wouldn't bike with this but you could maybe just toss it in the trailer and not notice
tombc is offline
Old 06-09-22, 10:40 PM
elcruxio
elcruxio's Avatar
Bikes: 2011 Specialized crux comp, 2013 Specialized Rockhopper Pro
Quoted: 560 Post(s)
Liked 135 Times in 98 Posts
The issue with a carbon frame for touring is the thing which makes it a great material. Ie. you can design it to very specific tasks so that you stiffen up one axis whilst leaving another less stiff (not that I think that makes a lick of difference in a diamond frame but that's another discussion).
But on that point you also have to design a carbon frame for the intended use case ir the stresses caused could cause failure, especially with a lightweight design. That is of course true with all materials but the design element of carbon kinda emphasizes the point.
For example i read somewhere that certain manufacturers forbid the use of trailers on their carbon bikes because the chainstays aren't designed to take the directional stress a trailer arm could cause. Makes sense since a single carbon fiber filament is only strong in one direction and if haven't strengthened certain directions in pursuit of weight and because the use case doesn't require it, then those directions are going to be surprisingly weak.
So essentially a carbon frame would be excellent for heavy loaded touring if designed for it. If not, then it's basically up to luck if the design allows for it. But cheaper carbon frames tend to use more material = heavier = probably more durable in general.
elcruxio is offline
Old 06-11-22, 08:48 AM
tcs
Palmer
tcs's Avatar
Bikes: Mike Melton custom, 1982 Stumpjumper, Alex Moulton AM, 2010 Dawes Briercliffe, 2017 Dahon Curl i8, 2021 Motobecane Turino 1x12
Quoted: 1218 Post(s)
Liked 999 Times in 611 Posts
How about a Wellgo C238 pedal stand?
https://en-wellgopedal-com.translate...n&_x_tr_pto=sc
A Topeak Flashstand, perhaps?
https://www.topeak.com/global/en/pro...SHSTAND-SLIM-X
tcs is offline
Old 06-11-22, 08:59 AM
djb
Quoted: 2490 Post(s)
Liked 778 Times in 648 Posts
Read the welgo blurb, it says handy for parking your car.
djb is offline
Old 06-11-22, 09:43 AM
Tourist in MSN
Quoted: 2898 Post(s)
Liked 1,040 Times in 838 Posts
Thanks for posting, I was not aware of those.
Tourist in MSN is offline
Old 06-11-22, 11:29 AM
tcs
Palmer
tcs's Avatar
Welcome to the global village, Monsieur Provincial. That's a computer translation. Several Asian languages use the same base/root logogram for automobile and bicycle.
tcs is offline
Old 06-11-22, 11:42 AM
djb
not sure to laugh or be offended, mostly laugh though.
Well, while on my bike, I'd prefer to be hit by a base/root bicycle than a car any day of the week!
Ya, I knew it was a translation thing, still funny to read though
djb is offline
