For the love of English 3 speeds...
Thank good I thought I was crazy not sure how Harris didn’t show up first but I found that silly price here:
https://www.amazon.com/Schwalbe-Delt.../dp/B009P3LDMM
Bikes: 1973 Raleigh Sports, 1964 Raleigh Sports (Canadian?), 1969 Triumph Ladies, 70's Columbia Sports III, 07 Diamondback Venom
Quoted: 83 Post(s)
Hahah how I missed that I don’t know. So the wife was like cream tires will look **** after a while, go with the panaracers lol
These will be on both my sports of which the 73 will be getting customized while the 64 will be renovated.
Can I use oxalic acid on wheels with tires? I assume so since it says use rubber gloves but not all rubber is the same.
Bikes: Raleigh Sports
Quoted: 202 Post(s)
You just need a cable and a stop.
Do you have the dual shifters attached.
These throttle shifters are cool but somewhat rare
Attachment 582514
Attachment 582514
So are those shifters the what would be originally equipped on the 67'-68' Dunelt 5-speed model?
Does that shifter set mount on the handlebar neck?
Do they need there own specific cables?
I did see that same shifter set on ebay for $35 today that is a reachable price.
I heard they may be troublesome but original equip. would be my preference. The bike has no other aftermarket with the exception of the brake cables. I am told/suggested the SA 3-speed standard trigger shifter will work just fine for left shift function on the.
I still need to deal with a bellcrank cable that appears a larger threaded thumb adjuster barrel than the 3-speed side of the hub.
Does anyone know off hand the thread spec for the bellcrank cable/lever?
I also stumbled across a bellcrank on ebay and it was $88....Thats a lot.
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
Google Mark Stonich, his business is called Bikesmith - he can sort you out with a much cheaper bellcrank for an S5
Quoted: 202 Post(s)
I hadn't made this 5-speed purchase I planned for an hour or so later.
He informed me I was lucky he didn't see this Dunelt 5-spd on Craigslist or he would have beat me to it.
I sat on this ad for 4 weeks I think it was never renewed.
So I know about him now, Very nice people. I have noticed this planter in front of his shop 100's of times.
Quoted: 149 Post(s)
Liked 30 Times
Great story! It would be cool to see his collection & I'm sure he'll be able to help with your S5 set-up. Mark and his website were very helpful when I first started working with the older 3 and 5 speed SA hubs. When I ordered from him I forgot to ask him for a push rod, so I made one from a nail of the right diameter I'm fairly sure that's what Mark does too.
That reminds me, rmh what was wrong with that 5 speed diagram?
Quoted: 1299 Post(s)
Liked 103 Times
Thanks for showing me those shifters there Kinda cool, they would be noticeable "bling" that I am not familiar with on these English 3-speed type bikes.
Attachment 582673
Attachment 582673
Inflate Hard
Inflate Hard
Quoted: 79 Post(s)
Yeah you don't want the Oxalic acid near aluminium or galvanised (think spokes) or nickel plate for very long. Same goes for phosphoric acid and the rust converter type treatments. I had some paint loss from steel, and some deep etching into a cast zinc part using phosphoric acid. But for chrome and rusted steel - go for it. Soak times will vary depending on the temperature and the depth of the rust. The paint loss didn't bother me on those particular parts as I intended to repaint them - just something to be aware of. I think (?) oxalic is safe with paint but it would be better if someone else weighed in on this.
Also consider straight up vinegar - you may have to soak it for longer but it is much safer for you and your lungs. I soaked some rusty parts in vinegar for 2 days, but this was in winter, so in summer it would work faster. You still could probably leave it soaking all day without worrying about your parts too much. My dad did all his de-rusting with lemon juice because the neighbors had an overhanging lemon tree I haven't seen naval jelly here in Australia but I believe it's a good product for de-rusting?
Liked 103 Times
Thanks for the input. I spent my 1 week R&R from Viet Nam in Perth. Nice country nice people. I will only use the OA for chrome parts then. Small steel parts I will wire wheel off the heavy rust and soak in Vinagar (never tried that) and all the painted parts will be stripped. I see on the web that the 49 chain wheel is zinc so the buffing wheel is all that will get. I'll have to look closely at the tool pouch that came on the 52 to see if the clasp is chrome or plated. I don't think OA would be good for plated. Richard
Inflate Hard
Inflate Hard
Quoted: 79 Post(s)
Another option you have for a Raleigh this old is gun barrel bluing. A lot of the small parts like cable guide wheels, cable clips and small nuts and bolts were finished this way on the older bikes. Sometime in the 50s, they changed to that dull gray finish. Not sure what that is. Parkerizing maybe.
Tuesday I was searching for cotters due to a crank alignment issue on a Raleigh and googled & visited the Bikesmith sight amongst others saw what I needed to know. Mark's shop is 5 blocks down the street from me. I guess I'v seen the Bikesmith out there offering items & services but had no clue he was working out of Minneapolis. I e-mailed he called right back-it was less than five minutes to peddle over to his place with my dog.
(runs away fast)
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Liked 103 Times
Well, here's the official finished" photo of the green 73 Sports. Man, this bike had quite a few bugs. No wonder the guy just wanted to be rid of it. On top of the misaligned brake hole in the fork, it also needed some cold setting. I'm not even sure where, but with the front wheel axle bottomed out in the dropouts, it was tipped off to the left. I suppose I could have milled the dropout slot a little higher on the left leg, but all the bugs in the fork inspired me to go onto ebay and sure enough, there was a tall, green Raleigh fork for a total of 27 bucks. I took a chance on it and it worked out. Perfectly good fork and even a pretty good color match. So now, the bike rides perfectly, the hub runs quietly and shifts smoothly. I installed regular brake levers with new cables, Kool Stops and a mid 60s trigger shifter, new chain, all new bearings and a 20T cog. The only bug left is from when whoever laced up the CR-18 started in the wrong place and left spokes crossed over the air valve. I'm not going to bother with fixing it. So, it wasn't a good deal money wise, but there's another good green 23" Sports on the road.
73 sports800 by Billy Bones, on Flickr
73 sports02 by Billy Bones, on Flickr
Inflate Hard
Inflate Hard
Really? Hmm good to know? lol
I have to admit i am a bit terrified to take this bike (the 64) apart because I've never fully tore down a old bike, just newer MTB and BMX but i was also young and wasn't paying for it out of pocket...lol
I know to keep a eye on the bearings and all that also i want to open the BB cause there seems to be a slight amount of play. So that's gonna be fun.
Anyone near western mass wanna come down and check her out? PM me if so im near the CT northern border also and can travel
Quoted: 83 Post(s)
Lube jobs aren't that tough. Cotterpins might be the only hiccup. Headsets are straightforward.grease all the races after cleaning. Mine had 24 bearings each cup. Put them in the fork race, then load up the top race. Put the fork into the headtube and screw down the top cup. Adjust and set.
I was gonna get the Phil's grease and oil, but is there a grease i can use that i can get locally? I have CRC synthetic grease i use for my Subaru caliper slides would that work?
Calamari Marionette Ph.D
Very nice! I've seen this somewhere before...ratrodbikes.com?
Is that a Gimondi crankset? I've got one waiting to go on a Dyno cruiser. It's patiently waiting for me to finish the DL-1 before it gets some resto-rat-love.
edited to say: Just looked at your other bikes, cool Schwinns! That tomato red really suits the cruiser.
Lowes is local to most places so I went there. I use this. I'm not saying it's the best...lord know I would not want to start another grease war, but I use this.
kVp & m*s
Bikes: Schwinn Paramount... someday
Quoted: 101 Post(s)
It's already been said but I have to say it again... Beautiful bike Looks very much like the almond Linus.
The phony fillet brazing and spindly tubing of the Varsity and Continental is actually quite beautiful when given a chance. And they are amazing frames for casual cruising.
When I first got into vintage bikes a few years these were my favorite to find and fix. That's almost funny to admit now.
The answer is here. A good read too.
https://www.sheldonbrown.com/varsity.html
I disagree with the lump of rock description. Both of mine roll nicely, absorb bumps and vibration well, handle and steer well, no creaks, and tip the scale at ~26.5 lbs. A quality saddle and tires makes a big difference, but the frames themselves are straight, strong, and reliable.
Here is the brown bike's industrial cousin, a Jumbo '77 Varsity in black 'n blue.
Apologies for clogging a British 3-speed thread with American single speed photos. But it's really all about the comfy upright ride, right?
Quoted: 202 Post(s)
Miller72-In reference to; # 13879 I Did pay the asking price $100. Didn't bother with a haggle effort . My Pc screwed & wouldn't support the forum up for days & I thought I responded to you.
Quoted: 83 Post(s)
Now onto lubricant, i know a lot swear by Phil's but again is there a suitable alternative that is trust worthy?
You mean to lube a chain? I use dry lube. Or do you mean, lube a hub? I use 3 in 1 machine oil, blue bottle. It's important not to use anything with vegetable oil in it.
Quoted: 83 Post(s)
Yeah i have dry lube, i meant for the hub. Ill grab a bottle tomorrow then im gonna take the 73 hub apart and figure out why its making noise when i coast
Check the bearings on the non drive side first. They might need grease. Hubs sometime need oil doses and miles before they start behaving right when they have sat for awhile. Check the grease, load with oil and ride it for awhile.
