Butyl reinforced rim tape - for a high tensioned durable 36h wheel
#51
Friendship is Magic
Bikes: old ones
Quoted: 24412 Post(s)
Liked 8,178 Times
...after the third beer this will all make sense.
Likes For 3alarmer:
#52
Disco Infiltrator
Quoted: 2961 Post(s)
Liked 1,864 Times
The ghosts are the key here, I think
Likes For trailangel:
#55
Half way there
Quoted: 945 Post(s)
Liked 802 Times
More imaginings with no basis in reality. None of these is true of a seated and pressurized tire:
- there is no movement between tire and rim or tube and rim
- at no time do gaps form between the tire and rim to let in debris
- a tire does not wander around on the rim after it is pressurized
I'm going for a ride now ... hope my head stops spinning.
Likes For Moe Zhoost:
#56
Bikes: Paramount, Faggin, Ochsner, Ciocc, Ugly Bill
Quoted: 912 Post(s)
Liked 1,055 Times
So we find in post #47 that the real problem is the electric bike issue. 250 mm spokes of the largest diameter will result in higher spoke tensions due to the diameter size. And the over-sized hub only increases the torque applied to the rim and bead seat for the tyre. It isn't the "Ghosts" but the twisting effect from the torque applied to the wheel when using the E-bike function. These bikes are like mopeds in the way they work the tires and wheels. Rapid acceleration will allow a bead to slip and the tube can be twisted inside the casing causing failure. Especially when under-inflated. Just correct me folks but is a 622 rim a 29-er or a 700c rim? As ya know I don't know much about this stuff, but would love to be enlightened. Still drinking as per the recommendation of Three Alarmer, and it is starting to make sense.... Smiles, MH
#57
Friendship is Magic
Bikes: old ones
Liked 8,178 Times
...it's both. I can build a decent wheel, but my real expertise continues to be drinking.
#59
www.theheadbadge.com
Quoted: 2024 Post(s)
Liked 3,091 Times
Step #1 : Velox tape. In the right size for the rim channel. As if that hasn't been recommended enough in nauseating detail.
Step #2 : Proper tube inflation once tire and tube are re-mounted.
Step #3 : If punctures continue, try a thorn-proof tube. Hey, you've got e-assist, tell that hub that the weight weenie party is over, and it better get a Bafangin move on. Combined with the Velox tape, this really ought to be the end-all solution for all phantom punctures.
Step #4 : Be nice to others. Not everyone is as all-knowing as you are, even though you can't seem to figure out this problem.
Step #5 : If you can't be nice to others, fill the inside of the rim with roof sealant so it's nice and smooth and all the spoke nipples are covered. Then get the biggest knurling tool you can and knurl the rim bead seat so the tire can't slip. Once those two solutions don't work, hit the rim strategically with a 12 pound sledgehammer.
-Kurt
-Kurt
#60
-Kurt
-Kurt
2. i had the 2" tire inflated to more than 40 psi when the last mishap occurred.
3. i had no tubes other than normal ones available to me unless i had to wait for delivery and pay for it.
4. and 5. if you can't be nice to me and understand why i was upset and nervous to have ridicule spamming here then i might invite you as well to try tasting your own medicine. do you choose to have me guilty of protesting when people are lynching me? some went on to claim i invented problems, that i am delusional etc. but here you are telling me "as all-knowing as you are". so... which one is it? i certainly had the tube punctured at the rim tape, more than once in less than a month.
be nice to others even when they abuse you, right?
even when they claim you can't have problems they don't have, right?
i asked for objective advice for this setup (1st post) and was not interested in alternatives unless the setup cannot work. it does and had proven so later on. if i knew this from the beginning i would have not started the thread and had not bothered all these folks with a new thread that had been given such a name so that folks could avoid it if they knew nothing about high tension or about extra layers of tape. i never intended to catch people up in a new thread with the intention to mess up with them.
in the end i explained why tubes chaff against the tape. if you got the thing that the hub i use could be significantly increase (+40Nm more exactly) the torque from pedaling - not bafang - then why don't others get it and stop posting mean and ridiculing comments? am i in the wrong to be upset by other people being ignorant and wanting to prove me wrong when i'm not?
i received ridicule even when i am right to say that tires can have considerable dynamic movement when rim tape is not thick enough to hold the tire and that a symptom is having a tire that ignores your rim's lateral true which in my case is less than 0.1mm total runout.
all i asked in the 1st post was for people "in the know" - not amateur mechanics - to give me information like "this thing will not work for these reasons" or "this thing of yours will work because of these reasons" or "this thing i know to work with tubeless ghetto" etc.
sorry for being more rational than the people who claimed i invent problems that do not exist and therefore being guilty of the ad hominem thing by calling me crazy, they certainly weren't nice. in the meantime i figured out things, explained my judgment but still.. people accuse me of being a troll when i made no fun of anybody, just tried to stop crap - later ignore it - from ignorant folks and ad hominem remarks.
and i am nice to people, just not to everyone. i don't like ridicule thrown at me from ignorant people and i don't need to be given alternatives that are not available to me. and i had not asked for alternatives, i only asked if and why this would work. crap does go inside the wheel, especially in wet/winter; tubes do happen to get nasty punctures by split at the rim tape. and not everyone has my setup and ease in getting the rear wheel off etc.
the most important thing i had to figure out and would had been nice to receive as advise was the amount of extra width (climb) the butyl layer could or should have.
so i'll just say this in the end. this thread can be ignored by people reading it or posting in it - unless they are interested in this butyl extra layer setup. i can now say only this: this thread/topic can very well be closed.
#61
Liked 3,091 Times
1. velox is not available. not here, not now, not the exact width. and i wanted a fix that would be ready, with no more delay than just working the size to be cut with scissors etc. someone told me (i remember it being a PM) that i do not need to "sacrifice" an inner tube... it was already useless. anyone could be having a useless 26" tube in their homes, either cut or patched. mine was dunlop so it was really useless.
4. and 5. if you can't be nice to me and...
- If not Velox, how about Zefal? Or any sort of weaved cotton tape? Disagreements in tech aside, perhaps we've all made the mistake of assuming your location and accessibility (especially as I haven't heard of Dunlop being used for bike tires since the 1960's in North America/Europe either). Where are you?
- 40psi is very low for a 26x2" balloon tire on an e-bike. Though I've had less opportunity to service e-bikes than I'd like and can't speak from experience, Mad Honk's theory of a slipping tire case and tube sounds very probably at that tire pressure. I'd take them up to 60-65psi, at minimum.
- Are you servicing this bike for a customer? If not, don't you think it's worth it to invest in the thornproof tube to save you all the trouble? You're going to spend the cost of the tube and delivery eventually if you continue to puncture other tubes. This reasoning also applies to the Velox tape.
Reap what you sow.
FYI, this is what Velox (or any cotton rim tape - in this case, it's Zefal) looks like when installed properly on a single-wall rim. The tube doesn't care about the uneven surface, and so long as the tire seating area is clear, everything is fine. It's not quite perfectly seated, but the pressure from the tube will help everything find its place. Granted, I would hope that the e-bike has double-wall, but from your description, it doesn't sound so.
-Kurt
Likes For cudak888:
#62
Half way there
Quoted: 945 Post(s)
Liked 802 Times
@adipe - You've certainly had a rough time with this post. I'm glad you have figured things out and are now back riding. Good luck to you, mate.
#64
Quoted: 912 Post(s)
Liked 1,055 Times
Alright Velopigy,
I'll take ownership of the victim role cause I really don't understand the differences of the 29-er thing. Around here we have wheel sizes that are actually 29" and wheel sizes of 700c, and wheels sizes of 27". So I wonder about what the differences of these wheels are and the way folks describe them. I remember folks calling 700c rims as 28 inch wheels, which clearly is incorrect. So yer right I am a knowledge victim here. Help a poor brother out here, Smiles, MH
#65
Expired Member
Quoted: 3031 Post(s)
Liked 3,998 Times
#66
working on my sandal tan
Quoted: 3682 Post(s)
Liked 2,156 Times
Alright Velopigy,
28" was the original designation for what we now call 700C, so I wouldn't call it incorrect, archaic at worst. The only difference with 29er is that you're mounting a big (generally 2" or more) tire on the rim, and the rim is often wider to match.
#67
Version 3.0
Bikes: Too Many
Quoted: 1123 Post(s)
Liked 1,778 Times
This thread is closed.
