Thoughts/Experience with Handsome Cycles XOXO an X0-1 homage All-Rounder
Old 12-10-22, 09:01 AM
  #301
jadmt
jadmt's Avatar
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 899 Post(s)
Liked 1,821 Times in 822 Posts
Originally Posted by streetsurfer
Sorry, pictures are difficult to show the actual angles or distances, but I’m glad to help. I hope the pics help some. I show the right stay to brake surface as .980”
I show left stay to brake surface as .880”
There is a one-hundred thousandths difference.
If this helps any, my chain line seems
straightest between fourth gear and fifth gear. There is a slight cant to the right at the rear in four
A sight left cant in fifth.
4th
5th
While the wheel shows a bit of left offset by stay to rim measurements where you indicated, I don’t know that it’s not proper, in order to account for the gear cluster and wheel dish or tire to chain clearance. On mine it doesn’t seem to mess with the actual tread being centered.
Eyeing this up now, I wonder if the wider rtp might rub chain in 11.I haven’t looked down at chain alignment while riding yet. I’ll get this on the stand after a follow up and doctors approval to be more active.
These rear alignment issues, and wheel building aren’t areas that I have had to delve into before, but I am eager and willing.
Judging by the tire alone, the center of tread still seems to align with the center of the seat post, the bolt in the chain stay brace, the center of the bolt in the seat stay cross brace/brake hanger, the brake cable housing stop/hanger and the center of roller hanger on the straddle cable.
How large of a difference have you noticed? Iirc you had one set of wheels redone? Do you still have a greater offset than the .100” I’m seeing, or thereabouts?
Seems centered to frame center.
I’m using a tamper marker for two reasons: To show what I’ve gone over so far To monitor for any loosening or shifting.
When more mobile, I’ll check the seat stay distances to rim. What I may be picking up is .050” difference in the cross sections/widths of the two chain stays…the chain sode being seemingly a touch flatter inboard. So take that into account as part of the 1/10” diff here, perhaps.
no the chain will not rub on the RTP tire in 11th or at least on mine it is not close enough that if the rim were moved the 2 or 3 mm to the chain side. most people probably don't care or be bothered by a wheel not dished exactly but seems like a professionally built wheel should have proper dish.
jadmt is offline
Likes For jadmt:
Old 12-10-22, 09:10 AM
  #302
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
scored a deal on a couple of Naches pass tires...2 for the price of 1 could not pass them up. also probably going to look dorky but picked up some BTP bar tape in orange and white. The tape it came with is starting to look a bit long in the tooth. I am on the look out for a different stem so probably wait until I find one before re-tapeing the bars. looking for a 90° or 100° maybe up to 110° stem. would love to find an xo1 ritchey stem or nitto cr-52
jadmt is offline
Likes For jadmt:
Old 12-11-22, 06:45 PM
  #303
heytchap
Quoted: 48 Post(s)
Liked 22 Times in 16 Posts
how’d you manage to land those so cheaply?
heytchap is offline
Likes For heytchap:
Old 12-11-22, 08:12 PM
  #304
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
just happen to check the want ads on another forum right when they were posted.
jadmt is offline
Old 12-23-22, 10:36 PM
  #305
streetsurfer
Quoted: 85 Post(s)
Liked 257 Times in 135 Posts
Good score
on the Naches.
Did you get your bars taped? I rewrapped mine, moving the levers outboard a little.
streetsurfer is offline
Likes For streetsurfer:
Old 12-24-22, 08:47 AM
  #306
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
I have not. I have been looking for a different stem. I will probably move mine a little closer together when I retape. I know Grant Peterson recommended 12-13cm apart at the tips so I will probably try that. I picked up some of the dummy diacompe levers so will try those as well. I am having a hard time finding the stem I want.
jadmt is offline
Old 12-25-22, 06:02 PM
  #307
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
I think the RH naches pass are the right size for these bikes.
jadmt is offline
Likes For jadmt:
Old 12-26-22, 07:27 AM
  #308
IAmSam
Quoted: 399 Post(s)
Liked 261 Times in 130 Posts
I am glad this thread popped back up - love those XOs
If there's any XO riders here who switched to a threadless stem and want a Nitto RM-016 Mustache handlebar in the hard-to-find 31.8mm
Not that I'm trying to sell one here but I might could point you in the direction of a new one at less than MSRP
Happy Holidays - ride safe...
IAmSam is offline
Old 12-27-22, 09:17 AM
  #309
dphilips
Quoted: 13 Post(s)
Liked 46 Times in 17 Posts
Yes! For a roadish setup 1.8s are great on the XOXO (and you can fit fenders too).
I'm curious what the Naches Pass measure out to on those (Aeroheat?) rims?
dphilips is offline
Old 12-27-22, 10:33 AM
  #310
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
just barely under 42mm. velocity dyad so a 18.6mm inside width.
jadmt is offline
Likes For jadmt:
Old 12-29-22, 04:57 PM
  #311
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
comparison between rtp and naches
jadmt is offline
Likes For jadmt:
Old 12-29-22, 05:29 PM
  #312
streetsurfer
Quoted: 85 Post(s)
Looks good Jeff. Smart looking saddle, too.
Old 12-29-22, 06:21 PM
  #313
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
I really love the B17. I tried loving the C17 but could only muster up a like for it not a love. .. I am still looking for a stem but those are proving really hard to find what I am looking for.
jadmt is offline
Likes For jadmt:
Old 12-30-22, 12:13 AM
  #314
streetsurfer
Quoted: 85 Post(s)
I deleted the unused f/d cable adjuster on my 1x11, with a Problem Solver’s shifter boss cover
Old 12-30-22, 06:54 AM
  #315
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
Been looking for something to do that and love the blue lug brass boss covers but shipping is over $50 from japan for a $9 part. I will have to look at the problem solver one.
jadmt is offline
Likes For jadmt:
Old 12-30-22, 09:46 AM
  #316
GullyFoylesbike
*____*
Bikes: 1984 Gitane Grantour, 197X Serotta Club Special, Febru
Quoted: 27 Post(s)
Liked 62 Times in 28 Posts
Analog Cycles has them in stock rn
GullyFoylesbike is offline
Likes For GullyFoylesbike:
Old 12-30-22, 09:57 AM
  #317
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
Originally Posted by GullyFoylesbike
ordered...thanks
jadmt is offline
Old 01-05-23, 08:58 PM
  #318
streetsurfer
Quoted: 85 Post(s)
Fenders installed in my down time. I used Rene Herse “smoothed” hardware for fastening the stays to V/O fenders. RTP on the rear and NP front.
Not the best job as it was done one armed. Put a scratch in the rear fender at it’s crimp on bridge hanger, which I was hesitant to use. I didn’t have a long enough duramel for the front to work as desired, so used an L bracket there too, reluctantly.
Then put a dive strap along the chain stay for protection. Working on a more appealing fastening of it with perhaps waxed cord or ribbon/twill tape. Kamisori style. Not sure if chain slap will be a thing on this.
Old 01-06-23, 08:10 AM
  #319
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
looking good. I have close to 3000 miles on mine and i have never had chain slap even on washboard dirt roads regardless of clutch on or off. I think if i were going to run one rtp and one np i would have the rtp up front.
jadmt is offline
Likes For jadmt:
Old 01-06-23, 02:59 PM
  #320
dphilips
Quoted: 13 Post(s)
Looks great! I assume RTP fits in the back with fenders but the front doesn't clear hence the smaller tire in front - the fork crown design is the limiting factor on tire clearance there. Honestly, if you hadn't mentioned the tire sizes I probably wouldn't have noticed, though now that I know I can see it but it doesn't scream out at you.
Regarding chain slap, my 2012 has chips on the stays from riding off-road with older non-clutch derailleurs but your modern derailleur should have more tension. On another bike I recently used some 3/8" clear plastic tubing, slit lengthwise, around the top of the stay and held with twine at the ends (similar to what you've done on that strip). It's visually low profile and offers the desired protection and sound dampening.
dphilips is offline
Old 01-08-23, 10:26 AM
  #321
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
I screwed up should have went with the chrome, not sure what i was thinking lol. need to find a different screw too. the one they sent doesn't fit.
jadmt is offline
Old 01-08-23, 12:52 PM
  #322
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1922 Post(s)
Liked 3,418 Times in 1,580 Posts
Excellent paint!
52telecaster is offline
Likes For 52telecaster:
Old 01-09-23, 07:45 PM
  #323
jadmt
jadmt's Avatar
Quoted: 899 Post(s)
black screw or chrome screw?
jadmt is offline
Old 01-09-23, 08:10 PM
  #324
streetsurfer
Quoted: 85 Post(s)
It’d be chrome screw for me. I dont mind the brass.
Thanks each of you, for the info on lack of chain slack. Looking at it I can see the greater tension and take up. Will probably forego the strap then. I hadn't really looked into the drivetrain much, though I’d seen some vids on newer clutched derailleurs. last new bike was in 2014 or so.
Old 01-09-23, 08:13 PM
  #325
streetsurfer
Quoted: 85 Post(s)
The tires
The RTP would fit on the front fine under this fender. I should say I believe it would.
I had looks in mind (sort of supermoto/dirt bike oriented) along with wanting to see if the wider rear might be softer off-road and a narrower front providing quicker steering. I ordered one of each thinking I’d choose between which I thought I liked best, if I didn't like the staggered set up, then get the second one of choice.
