Fed Up with Flats
Quoted: 219 Post(s)
Liked 302 Times
500 miles in several years suggests you do not ride often. If that is true, tubeless might NOT be your best choice becasue the sealant will dry out and if you're not riding and checking the sealant regularly, it will likely be useless when you do need it. I'd go with tire liners, heavy-duty tubes and Slime or similar tube sealant. If that doesn't work for you, then I'd go with the foam inserts, tubes and sealant. Heck, maybe even tire liners still. On an ebike, there's little reason to be concerned with extra weight or added rolling resistance.
Regardless of what approach you take, check the tires after/before every ride to remove any thorns or similar. The idea is to pull things out that might not yet have worked their way through the tire.
The fact that you have had a bad stretch of flats, could also just be down to bad luck. Could be as simple as a box of roofing nails dropped from a truck and you're passing through them in the same place on your regular route.
Also, carry a handful of CO2 cartridges and filler valve. These can be quick to fill a tire and a lot less work than using a pump. If the leak is slow enough, you can complete your ride and deal with the leak at home, rather than the side of the road.
Clark W. Griswold
Quoted: 4346 Post(s)
Liked 3,983 Times
Actually, the tires are Schwalbe Super Moto X, and I'm not sure where you got the idea that I want to be "cheap". I'm just not sure which of the many solutions out there is right for where I ride and what is causing my flats. I ride on a full width paved shoulder, and the flats appear to be the result of hitting nails, brads, screws, etc. Usually, I see nothing, but hear the air go out quickly, and find a single puncture, but I never find the thing that caused the hole! And, I air the tires up to 55 PSI before every ride - that's the maximum rated pressure for my tires.
Also most actual highways don't allow for pedestrians and mopeds so not sure where you are riding on major highways that allow for that? Also not sure why you would want to ride on a highway anyway, that doesn't sound like a pleasant ride. There is a ton of flat causing stuff on highways and it is loud and fast and nasty. You do you but I would rather find some different roads to ride on unless I was commuting and had to take a small section and it was legal and even then I would try and find alternatives.
Bikes: 2014 Giant Defy 1 Endurance Road
Quoted: 7 Post(s)
You made allusions to it things like too expensive that will actually be functional and "not wanting to break the bank" that is usually a decent sign. Would be curious what is causing the flats because you haven't seen anything causing the puncture. You might run a slightly lower pressure as maybe the max pressure is more than you need.
Clark W. Griswold
Liked 3,983 Times
I don't know where you live but I cannot imagine it is all just highways and no regular city or country roads or places nearby to ride. Maybe that is the case but it just seems odd. I mean are there paved trails anywhere nearby assuming of course you would be on a bicycle and not a moped or at least not using the moped function?
Quoted: 1559 Post(s)
Liked 1,733 Times
There is no reason to run the tires at max pressure unless you are very heavy. Look up the proper inflation pressure for your weight. It's likely to be much lower than you imagined.
Too high a pressure could cause more punctures.
Likes For icemilkcoffee:
Quoted: 7 Post(s)
Oh, okay. I weigh 195 to 200, dressed to ride, and the bike weighs 75 with the stuff I have loaded on it. I'll look it up!
Quoted: 6191 Post(s)
Liked 4,806 Times
Looking at the heat maps around you it seems that some are happy cycling on many of the 2 lane country roads around you. Local bike shops and clubs should be a wealth of information about where others ride their bikes. And being near Lexington KY, I'd think there'd be plenty of LBS's and clubs.
Shoulders of 4 lane highways are probably full of tire hazards as are ours down here. 55 mph traffic of any sort tends to blow all the bad stuff from the traffic lanes into the shoulder.
Likes For Iride01:
Quoted: 7 Post(s)
Liked 4,806 Times
I'd be more leery of the 4 lane highways shoulder or no shoulder. I've seen the amount of traffic on them up there.
Likes For Iride01:
Quoted: 7 Post(s)
Well there must be a lot of people getting run over on their bicycles there as someone sure is doing a lot of cycling on them. But I don't see any heat maps showing people riding on the four lane roads there.
Liked 4,806 Times
However when I decided to quit riding the streets in the neighborhoods a long time ago, I was a little unsure how safe I'd be on the country roads outside the city where I live. Turned out they weren't a problem at all.
IMO, You'll stand a better chance encountering that crazy driver on a busy road. You'll be surprised how often people swerve into the shoulder just from inattention.
And generally, I feel that the safer routes to ride are the routes that other cyclists ride. And the heat maps show where that is.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
I cleaned up the thread. Let’s avoid the arguments please.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
+1 on letting a little air out of your tires. Believe it or not, I'd be trying 35 psi in front and 45 psi in the rear as a starting point. When the tires are softer and spreading out the load over a wider area, they can shrug off sharp things a lot easier.
