Anyone else keeping their rim brake frames ?
#651
Quoted: 4388 Post(s)
Liked 4,828 Times
Sigh.. the advantage of tubulars is not the tires but the rims. Repeat: the rims. Tubular tires are held onto the rim with a few grams of high-strength glue, unlike clinchers (tubeless - same) which require 2 protrusions or hooks on the periphery of the rim to hold on the tire. These hooks are fragile, cause pinch flats, and add weight at the worst place on a bike.
Check your stats - tubular rims are always lighter than comparable clincher or tubeless rims. And due to the extra forces placed on disc-equipped wheels, disc wheels are always heavier than rim brake wheels, - and then you have to add rotors.
If you really want light, then Lightweight Meilensteins come in at 935 grams. Yes, for a pair of wheels. Due to the inherent design disadvantages of clinchers, this is not possible in tubeless or clinchers.
#652
Liked 4,828 Times
But... You have to glue to tire in place. And it's not a simple slap on glue, slap on tire -type of maneuver either. It is a genuine hassle that makes bleeding brakes and seating tubeless tires seem like kindergarten play. And both things combined will take a fraction of the time.
What do you do if you get a flat mid ride? You'll need to carry a whole tire? Glue? Brush? Heat gun maybe? How good will a roadside repair really be?
If you have a support car then maybe tubulars still have their place (however judging from the pro peloton, probably not much longer) but for a regular joe? Just stupid. Almost like drillium.
As to disc wheels always being heavier (than rim), are they though? I mean you need to add stuff to the hub sure but you can take stuff away from the rim area. And some manufacturers already do. I wouldn't be so certain that disc is automatically heavier. And even if there is a weight difference, the added weight is where it matters less.
#653
Quoted: 8265 Post(s)
Liked 9,000 Times
Disc wheels on this article are lighter than comparable rim brake wheels, when available.
6 of the Absolute Lightest Carbon Wheelsets for Road Bikes - Cycling Road
#654
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,861 Times
It’s been a long time since I’ve ridden tubular tires. Please remind me how you “field fix” a flat. I seem to recall a need to haul around a complete tire. I’m happy to not have to do that any more.
Do you know what’s slower than a heavy tire? A flat one. If tubeless tires significantly reduce the amount of puncture flats, that means more winning opportunities not lost for racers, fewer group rides brought to an irritating halt, and I get home sooner (or get to ride longer) because I’m not wasting time on the side of the road, that sounds like a very good thing to me.
But, yeah, he also carried a spare, pre-glued tire.
Likes For genejockey:
#655
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
Likes For mstateglfr:
#656
Sunshine
Liked 7,474 Times
And its cool that weight is not only the priority for you, but the sole determiner for technology. Every one of us rides for some reason and we all have varying priorities.
Thing is, I took time to respond to your claims about weight and debunked many of them. You not only havent adjusted your rhetoric, you didnt even acknowledge it and counter. That, to me, is pretty sad. It shows you are dug in on a topic regardless of reality.
If you only consider weight, then your setup is often ideal. In reality, weight is simply one part of an overall formula for determining speed or enjoyment. You have chosen to value weight over anything else, but others value it differently. They arent wrong, and actual data can show as much. Its unfortunate you are to much of a fundamentalist to see this.
#657
Liked 4,828 Times
I guess you mean chain guides on Enduro and DH rigs then? I’ve never actually dropped a chain since running 1x mtb drivetrains and that’s about 8 years. I don’t run a chain guide on my current full-suss trail bike.
#658
Liked 4,828 Times
Once more, you exist in a tangential world where weight is the only thing that matters. Aero doesnt matter, comfort doesnt matter, convenience doesnt matter, etc. Only weight matters to you.
#659
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2617 Post(s)
Liked 3,131 Times
My race (road) bike and TT bike 11 sp rim brake. I also have another franken bike equipped with 11sp 105 that is a trainer only bike. Gonna keep those three rolling as long as possible.
I recently built up a new daily driver/training/high QOL road bike from a 2022 TCR Pro frameset up. I thought about going 11 and rim brake, but after some consideration, I realized that never swap wheels between my bikes, so why not go modern? I went with hydraulic disc and 12 speed Ultegra Di2. I must say that I do not regret my decision despite compatibility limitations with my other bikes. It is a very, very nice bike to ride.
"Your beauty is an aeroplane;
#660
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 666 Post(s)
Liked 964 Times
-breakage or serious damage in case of a serious pothole
-when a serious flat occurs you waste time glueing a new tubular
-fragility anf lack of robustness of some tubular over the years
-the last two years tdf stages have been won with clincher
The hook on clincher rims are not fragile, I have a pair of 1997 Mavic Cosmic Expert with which I have never had a single flat that still work well and they are clincher models
#661
Steel is real
Quoted: 666 Post(s)
Liked 964 Times
No everybody is into1*11 or1*12 mtb drivetrains. All is matter of purpose and needs, I don't run a chain guide on my MTBs as well.I ride only MTBs with10*3 mtbs drivetrains.
#662
Quoted: 1247 Post(s)
Liked 1,322 Times
#663
Quoted: 2480 Post(s)
Liked 2,948 Times
#664
Again, I'm referring to performance road bikes here. Not commuter bikes, third world pavement bikes, or cruiser bikes, milk crate bikes for picking up cans on the side of the road etc. The topic is speed bikes for good pavement.
Tubular wheels will always feature less rotational inertia because they don't need the two hooks circled in the pics following. This saves weight and prevents pinch flats.
So when you racing with the fast boys with clinchers or tubeless, you'll always have in the back of your mind whether your gear is good enough. The top serious athletes will have made the commitment to tubulars, and the associated gluing and the cost. Or let their sponsors and mechanic deal with it. But on those punchy little climbs or fast accelerations that leave you struggling at the back, you have to ask yourself whether you just want 'comfort' or 'convenience' which are just codewords for second best effort. Or are you really committed to performance?
#665
Quoted: 3498 Post(s)
Liked 2,911 Times
“I ride my Veloflex clinchers on Mavic Open Pro rims at 140 psi with a contact patch about a square centimeter per tire, and I’m expected to believe that a 38 mm tire at 70 psi and a contact patch of 20 square centimeters per tire and attendant loss of energy due to the “squish” factor has less rolling resistance.”
#666
Quoted: 3943 Post(s)
Liked 7,286 Times
#667
Liked 2,911 Times
#668
Liked 7,286 Times
#669
Liked 9,000 Times
Anecdotal, I know, but that is one of the advantages of single front rings.
Likes For big john:
#670
Liked 9,000 Times
Another benefit I found is when riding in mud. Mud can cause havoc in the front derailleur, chain suck, locking up, etc. Never an issue with a 1 by..
Mountain bike design changed dramatically starting in about 2017. Old mountain bikes are fine for trail riding and some people can go fast on hardtails but modern mountain bikes can handle technical terrain far better than bikes of decades past.
#671
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
You’re right, this is physics; the equations for rotational inertia are known; rolling resistance is a thing that can be measured. Please, outline your experimental conditions, and provide some results that support your position. We’ll wait.
#672
Liked 7,286 Times
”Prove me Wrong “ is a lazy tactic. You can state your opinion, and punctuate it with “FACTS!!” If you want, but if you want to claim something makes a point, bring the math.
#673
Liked 9,000 Times
Someone has made a claim that the hooks on a clincher rim increase the moment of inertia of a wheel, and this has a detrimental effect on acceleration. It’s legitimate to ask how big this effect is. In no way is it a “prove me wrong” situation — it’s a “ support your claim” situation.
It's hookless clinchers that don't have the hooks
Tubulars are box section, no hooks because no raised brake track.
#674
Liked 7,286 Times
We're talking about go-fast bikes, in which weight, especially rotational weight is the key differentiator of performance. Performance being measured as the ability to not be dropped off the back out of the corners or on hills. Or, even better the ability to shed stragglers off of the back through accelerations.
#675
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
When pressed for evidence, their response is either “No true cyclist” anecdotes, or to “do our own math”
