Rx cycling glasses
Hey guys, getting back into cycling after many years off the bike. Problem is I’ve developed dry eye syndrome over the last few years. I can’t wear contacts anymore and I’m blind as a bat without my glasses, so I need to get some rx eyewear for cycling.
I tried to get rx lenses made for my oakleys that I had been using, but they can’t get the prescription right with the curvature of the lens, so I need to find some athletic glasses that use a straight lens. My eye doctor doesn’t have anything like that.
Does anyone use anything like that or point me in the right direction?
Thanks.
Thanks.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,531 Times
Quoted: 10236 Post(s)
Liked 5,183 Times
Glasses look nice but I think the last time I tried to add RX it was still around 500.00.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
I have regular glasses I use for everything.
Likes For Homebrew01:
Quoted: 3948 Post(s)
Liked 7,291 Times
Quoted: 5 Post(s)
if you’re in the US or Canada you might try zenni.com zenni.ca
they've got something that looks like the sort of wraparound sunnies the cool kidz wear but with your prescription dropped into a flat section in behind. here’s an example plus a non-mirrored version so you can see how they do it. and yes, that price includes the prescription lens. I get all my prescription glasses from zenni
If they don’t work out, oh well. Worth spending 50 bucks to try to avoid paying $500.
If you have dry eyes with your contacts part of the problem is the eyeglasses you wear when riding. Most eyeglasses allow too much air to come up from below the lenses or to come in from the sides. I have found many cheap safety glasses to keep the air and dust out of my eyes. If when riding you can feel air coming up under your sunglasses then buy a new pair.
I recently bought a pair of Tifosi sunglasses as they have a relatively straight across profile and so my Specchio bike mirror works much better to show me what is behind me.
Might be better to not waste the $50.
I wear progressive lens bifocals and the simplest, least expensive option has been using a helmet with a detachable magnetic shield on the front. If my prescription changes, I just get new regular glasses and the helmet continues to do it's job, eliminating the need for an expensive pair of prescription sports glasses. There are several on the market. This is an example of what I am talking about.
Likes For TennBent:
WileyX
Thanks.
Thanks.
I'm eager to try a set of their Rx sunglasses, but like the guy below this mentions...they're not cheap. I priced a set out of ~350ish, which is a bit much to do on an impulse buy. Perhaps if I have some FSA money left over at the end of the year.
I've always had great results with Zenni sunglasses. I think I have around 5 pairs.
Recently I bought a pair of these on Amazon and had some single vision lenses made for the myopia insert.
All said and done the cost was $110. They're pretty much a knock off 100% Speedcrafts but I'm okay with that for the price.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4382 Post(s)
Liked 3,015 Times
Not sure what you mean by regular glasses? As in, not sunglasses?
I use to ride with my regular glasses. But after a while, spending so much time riding in the sun, I thought, "If I don't get sunglasses, eventually I'll get cataracts".
I invested in Rudy Project sunglasses with prescription inserts. They're not cheap, but they work very well and I'm quite happy with them.
Super Moderator
Liked 927 Times
I should get prescription sunglasses, or "transitions" that darken in sunlight.
Thanks.
Thanks.
You can get the single vision prescription done straight from Rudy Project. If you add a bifocal/progressive then you'll have to go through your local eye doctor. I'd hate to cycle with a flat lens. The wind turbulence around the edges with not be good for your eyes. The RP Rydon was specifically designed for cycling and other windy applications to protect your eyes.
I have never felt any "wind turbulence" on or near my eyes when cycling,wearing my current Maui Jim Red Sands or my Randolf engineering Navigators both are flat frames. The glasses sported by most cyclist that are the full face goggle BS, is all because some Pro rider at one time probably thought it would be cool and now everybody has got to go that style. The Rudy Project Rydon RX docks , look great have a base curve #6 but because the insert is a bit larger than the lens looks like wraps like base curve #8 it affords it a slight shield. But by know means discount "flat frames" because of wind turbulence.
Like I stated in a few treads above, most wrap sunglasses are a base curve #8 and if trying to fill a progressive prescription with that base curve you are going to have problems (distortion in peripheral). Most sunglasses you are referring to as flat,are a base curve #6 or occasionally a #4. But I can tell you, from my own personal experience, your analogy is wrong.
as always in this, it’s a very personal thing (which you should know). And it’s a simple fact of aerodynamics that a flat surface in a wind stream will create more turbulence behind the plane than will a typically curved surface. Whether that bothers your particular eyes or not is going to depend on a lot of things.
my point in this is that there are curved lenses that work very well, it can be done effectively and correctly and, in point of fact, is for great numbers of people. I offered one possible solution that’s worth investigating.
anyhow, good luck to you - preconceptions aside.
