Bibshorts for regular washing programs
#51
Quoted: 4393 Post(s)
Liked 4,837 Times
Stop to think about what your bike shorts go through on every ride. They aren’t “delicate”. Your shorts rub against the saddle 5400 times per hour (90 rpm over 60 minutes). Nothing in the washer is going to abrade them as much as that. Denim probably won’t stand up to that kind of abuse. Bicycle shorts (and other bicycle clothing) are made of tough, rugged material that doesn’t need to be handled like lingerie..
Nothing delicate about quality bike gear. Lightweight, soft on skin, but tough as nails. Those are the qualities that make the best gear stand out.
Likes For PeteHski:
#52
Quoted: 1109 Post(s)
Liked 1,200 Times
I just toss my cycling clothes in with everything else. We have a washing machine without a conventional agitator.
The three keys to washing cycling clothing:
- use cool or cold water
- wash everything in mesh laundry bags to protect the delicate fabrics from abrasion
- hang dry your cycling clothes
Do those three things and your clothes will last a very long time.
I agree. Not an issue.
Life is too short for that. I used to hand dry my bicycle clothes but decided to just dry them in a dryer. Been doing that for more than 2 decades and I have bicycle clothing that is dragging 30 years pretty hard. How much longer do you think I want my bicycle clothes to last?
I do agree wholeheartedly that cycling clothes are not delicate and don't require any special care except maybe don't dry any synthetic at high heat because it simply doesn't need it. But especially shorts. I think heat of a dryer, even at low, will reduce the life span of stretch. Or at least don't let them bake in the dryer any longer than necessary. They dry over night hanging from the door knob in our laundry room plus just use another pair if they don't.
#53
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
I wash with darks, regular cycle with warm water.
I never use the dryer. Plastic and elastic fibers don't last very long when you subject them to high heat of the dryer cycle. The stuff is synthetic, wicking, fast-drying material, so air drying is fast. Faster if you do the "roll in a dry towel and sit on them" routine before hanging out. Really no need to dry if you either have more than one kid and/or plan ahead.
I've had shorts last 20 and 30 years. If you don't crash, you can get decades out of your cycling wear. And with today's pricing, it's great when you can get years and years out of cycling apparel.
#54
Liked 4,837 Times
1. Low temp wash (30 degC)
2. Air dry. No tumble drying
3. No fabric softeners
Doesn't need any more thought than that. I just chuck all my cycling gear in the wash together. Our machine has a dedicated "sports wear" cycle which takes care of it. It dries in a couple of hours when hung up. Quick drying is another feature of quality gear.
#55
Mad bike riding scientist
Quoted: 6217 Post(s)
Liked 4,214 Times
Additionally, heat can cause the polyurethane elastomers to regain stretch. Heat causes the elastomer chain to
As to care, this is what Dupont says
CARE:
Since LYCRA® is usually the minority component in a given fabric, let the other fibers guide your care instructions. If other fibers or the trim or binding of a garment require hand washing, dry cleaning, or low-temperature washing and drying, their needs will determine the care instructions. Lycra will easily withstand repeated cleanings of all these types. When in doubt, wash or dry clean according to the primary fiber in the blend.
Finally, socks and ordinary underwear (not fancy stuff that really isn’t meant to be worn for long) typically have lycra in them to provide stretch. The days of rubber cuffs on socks and waist bands are long gone. Do you hang dry your socks and underwear to increase the lifespan of the stretch?
Stuart Black
Stuart Black
#56
Liked 4,214 Times
3 simple rules that most of the care labels clearly state anyway:-
I wash and machine dry my bicycle clothing because I don’t have enough time nor room to handwash and line dry this quantity of clothing
2015-01-24 10.24.52 by Stuart Black, on Flickr
That’s 2 days of winter clothing.
Stuart Black
Stuart Black
#57
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I wear a lot of merino (polo’s, underwear, socks, and sweaters) so I just wash my cycling stuff with that 30c for 90 minutes
#58
Liked 1,200 Times
Lycra (and other polyurethane elastic materials) won’t be damaged by being stretched due to be tangled in other laundry. Lycra can stretch 5 to 8 times it’s normal length without damage. Most washing machines today are tumble type rather than agitator type but even an agitator machine probably can’t stretch the material that far. The nylon of the garment will probably be the limiting factor in stretch anyway.
I also put anything with velcro in a bag just because it sticks to other things and can damage them.
People make the mistake of thinking that polyurethane elastomers are “rubber”. It isn’t. It’s an entirely different material that isn’t delicate nor damaged by heat. The fabric itself is heated to somewhere around 200°C (about 400°F) during manufacturing to set the material. Even a commercial dryer set to high would have difficulty reaching that kind of temperature.
Bicycle shorts usually has a high content of nylon (about 70%), some polyester (around 15%) and lycra (around 15%). None of those fabrics are particularly unstable in heat. Nylon has a melt point of over 250°C (>500°F). Polyester has a similar melt point. Lycra (generically known as “elastase”) melts around 240°C. None of those temperatures can be reached by a home dryer and very few commercial dryers are going to get even half way to those temperatures. They top out at about 180°F.
Do you routinely dry your bibs in the dryer and if so, a "medium/normal" heat setting or extra low? And, you see no deterioration in the stretchiness in the long term? Genuine question.
I'm not afraid of the dryer at all. I dry all my other technical fabric light weight, synthetic garments - shirts, shorts, base layers, socks etc. etc. in the dryer, but use extra low just because it seemed prudent to me to use low heat, and that's all it takes to dry that stuff in a short time. I have put my bibs in there occasionally if for some reason (rarely) I need them dry right away. But since they have more stretch component than the other garments, are more expensive and harder to replace than socks, base layers, jerseys, etc., and they dry so quickly in the air, I have always thought it wise to just avoid the dryer for the bibs.
I'll have to admit, I don't often read the care instructions on stuff like this since I've been washing and drying it for so many years.
I also want to point out that I don't hand wash anything! Except maybe if I'm traveling and don't have ready access to a washing machine. I even put the pads from my helmet in a mesh bag and throw them in the washer from time to time.
#59
Quoted: 1743 Post(s)
Liked 1,281 Times
I think the issue is the dryer not the washing machine. All my bibs are Assos because that's what works for me. I hand wash and hang dry but that's just me.
#60
Liked 4,214 Times
Thanks for the clarification. I'll still use the bags because it's a tangled mess if I don't - which is why I started using them in the first place, and then thinking of them getting stretched out secondarily.
Interesting although I never thought this stuff was rubber. The only items I've ever been concerned (misdirected, evidently?) are the bibs because the other stuff (a) costs chump change compared to bibs and (b) are easier to replace. Some of my favorite bibs aren't necessarily available in the exact model and chamois when the old ones wear out.
Stuart Black
Stuart Black
Likes For cyccommute:
#61
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 911 Times
Pearl Izumi gear wants 'free' detergent and no fabric softener. Which is how I do my own regular clothes, so no biggie. An agitator machine doesn't seem a problem, nor does the dryer.
#62
Liked 1,200 Times
....I also have dried them in older dryers as well as commercial ones while out touring without the sport setting. In those I usually use the medium/normal setting. I have found that heat helps reset the stretch. When I have had to hand wash my clothes…it happens…I notice that the shorts seem to be looser fitting.
#63
Quoted: 2603 Post(s)
Liked 1,926 Times
My current dryer has a sport setting but I also have dried them in older dryers as well as commercial ones while out touring without the sport setting. In those I usually use the medium/normal setting. I have found that heat helps reset the stretch. When I have had to hand wash my clothes…it happens…I notice that the shorts seem to be looser fitting.
FWIW, I've lost two pairs of shorts, at two different times, that inadvertently went through the dryer. In those two cases, the shorts lost their elasticity in the dryer. What went in was tight, though not unpleasantly so. What came out was drooping, baggy shorts that I didn't wear again.
After the second time I figured I'd read and follow the directions on the label. Air dry.
