ISO and for trade thread part 5
Old 08-29-22, 06:13 AM
  #5151
oneclick
Quoted: 1105 Post(s)
Liked 1,311 Times in 775 Posts
Originally Posted by ehcoplex
Looking for a 140mm OLD tandem hub, threaded for a drum brake, cassette (but freewheel could work, too). thx
I have an Atom Drum/FW hub complete, don't know the OLD but I can measure, if that will suit. How many holes?
oneclick is offline
Old 08-29-22, 06:32 AM
  #5152
ericlowney
Quoted: 76 Post(s)
Liked 41 Times in 22 Posts
Looking for wheels, wheelset, or wheel components to have a set of 700c, clincher, 7 speed freehub, 126mm rear/100mm front. Ideally FH-1055 or 600 FH-6401 so they would be compatible with both uniglide and hyperglide, but open to being locked in to only hyperglide. It seems as though the only way to get these would be to find a vintage set, or I have to have the wheels custom built (or learn to build wheels myself). I'm trying to go the vintage route first if possible
ericlowney is offline
Old 08-29-22, 06:44 AM
  #5153
mountaindave
tantum vehi
mountaindave's Avatar
Quoted: 1166 Post(s)
Liked 966 Times in 483 Posts
If the threaded drum brake isn’t needed by ehcoplex, I would be interested in it. I might be able to convince my wife to go downhill on the tandem…
mountaindave is offline
Likes For mountaindave:
Old 08-29-22, 08:36 AM
  #5154
ehcoplex
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 756 Post(s)
Liked 1,535 Times in 745 Posts
I’ve actually already got an Atom drum hub (in need of restoration). I want to build up a wheel with the option of adding an Arai drum down the line if we decide we really need it. But much appreciated.
ehcoplex is offline
Old 09-01-22, 07:32 AM
  #5155
L134
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 170 Times in 105 Posts
I have a 48h Sansin sealed bearing freewheel hub threaded for the Arai drum laced to a 27" rim. The whole thing is available or I could remove the hub. Bearings feel decent.
L134 is offline
Old 09-01-22, 08:46 PM
  #5156
RustyJames
Quoted: 559 Post(s)
Liked 1,032 Times in 534 Posts
ISO Suntour Thumb shifter
ISO - the mate/sibling/partner/whatever for this lonely Suntour shifter. I have $$ or random stuff in bins so ask and thou may (or may not) receive.
If you have a set of said shifters I might be a player for that too.
RustyJames is offline
Old 09-02-22, 01:13 AM
  #5157
Insidious C.
Quoted: 457 Post(s)
Liked 329 Times in 207 Posts
I have a set, and I am in Beaverton too. I will dig them out tomorrow.
I.C.
Insidious C. is offline
Old 09-02-22, 04:41 AM
  #5158
jdawginsc
Edumacator
Quoted: 2385 Post(s)
Liked 2,931 Times in 1,862 Posts
Best thumb shifters ever.
jdawginsc is offline
Old 09-02-22, 06:27 AM
  #5159
ehcoplex
Quoted: 756 Post(s)
Let me take some measurements- the bike has 700c and cantilevers so I'm not sure if a 27" wheel would work. What's the OLD on the hub?
ehcoplex is offline
Old 09-02-22, 07:05 AM
  #5160
L134
Quoted: 345 Post(s)
Probably 140. The old Kuwahara frame it was mounted in measures 142.
L134 is offline
Old 09-02-22, 02:39 PM
  #5161
oneclick
Campy locknut service life: 50 yrs.
Was just snugging up the bearing on a Campy Tipo rear hub and this happened:
So I need another - would take more than one, a lot of hubs don't have one locking the FW side cone.
oneclick is offline
Old 09-02-22, 07:22 PM
  #5162
Hondo6
Bikes: Yes
Quoted: 541 Post(s)
Liked 656 Times in 456 Posts
I recently picked up a lot of mixed chainrings. The lot included a disc rotor.
I have no need for 2 of the chainrings or the disc rotor. If you need or want them, they're yours for cost of postage.
First, the disc rotor.
Disc rotor appears to be a Formula 180mm 6-bolt rotor; It's marked "FORMULA", "FD-50697-00", and "180mm". It's also marked "MIN TH1.75mm". Cheap digital caliper says it's 2.0mm thick in the wear track (6 measurements, each taken in the pad wear track near where curved spoke meets disc showed apparent wear track thickness of 2.0mm - I had one reading of 1.9mm but could not repeat it on re-measuring the same spot repeatedly; re-measurements all showed 2.0mm.) Rotor appears serviceable to me. Disclaimer: I have zero experience with bike disc brakes, so I could be out to lunch on that point.
First chainring.
This chainring is a Shimano Hyperdrive. It's 48T, steel, and appears to be symmetric 4-hole 104mm BCD. It's marked "HG Z-48" on what seems to be the inside of the chainring (opposite side from the "Hyperdrive" label).
Second chainring.
Second chainring is a Shimano Hyperdrive C. It's 42T, also steel, and appears to be 5-hole 94mm BCD (adjacent bolt holes are a touch over 55mm apart). It's marked "I-42" on what appears to be the inside of the chainring (again, opposite side from the label).
PM me if interested. Photos provided on request.
Edited to add: yeah, I know these parts may not really be C&V. But some folks here might be able to use them, and I don't really want to put serviceable parts in a recycle barrel.
Hondo6 is offline
Old 09-03-22, 02:35 PM
  #5163
raleigh76
Quoted: 11 Post(s)
Liked 23 Times in 9 Posts
Looking for a chain guard seat stay clamp for a Raleigh Sports. Thanks!
raleigh76 is offline
Old 09-03-22, 04:51 PM
  #5164
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2287 Post(s)
Liked 2,031 Times in 1,245 Posts
I've got a pair for you, ~73, happy to return a favour. PM your address and they'll be in the mail Monday.
72 and 74 actually.
clubman is offline
Old 09-10-22, 06:18 PM
  #5165
Hondo6
Bikes: Yes
Quoted: 541 Post(s)
It wasn't on this thread, but somewhere on the C&V Forum I seem to remember a BF member saying that they were seeking a 19T cog for a Regina freewheel. Unfortunately I can no longer remember the member's username or find the thread in question.
This eBay source seems to have quite a selection of Regina freewheel cogs. If you're looking for one, that could be a potential source if your usual sources don't pan out.
Disclaimer: I neither know the seller nor have I done business with him (he does have good ratings, though, and seems to have been around for a while). Posted here in case it might help someone.
Hondo6 is offline
Old 09-11-22, 03:33 PM
  #5166
Slowride79
Bikes: 50s, 60s, 70s Nottingham/Worksop bikes, becanes, Gitane, Bertin, Lion of Sochaux
Quoted: 145 Post(s)
Liked 120 Times in 75 Posts
https://www.ebay.com/itm/22446362387...mis&media=COPY
@raleigh76
Raleigh sports chain guard clamp
Slowride79 is offline
Likes For Slowride79:
Old 09-11-22, 08:30 PM
  #5167
dukeofearl
Quoted: 62 Post(s)
Liked 87 Times in 40 Posts
ISO: front 27" wheel with concave weinmann rims (to match a rear one with maillard helicomatic hub - but hub doesn't necessarily need to match) for an 80s motobecane grand touring
i have a 700c front wheel with weinmann concave rims and joytech hub if anyone wants to trade. i'd use it but the brakes don't reach.
also, if anyone wants to lend me a helicomatic freewheel removal tool, or sell for cheap, i'd like to remove the broken plastic freewheel guard thingy
**I'm in Philly
dukeofearl is offline
Old 09-11-22, 09:14 PM
  #5168
madpogue
Quoted: 2350 Post(s)
Liked 1,728 Times in 1,180 Posts
If you're REAL careful, you can GENTLY put a channel-lock pliers around that lock ring; it's not (well, it SHOULD not be) tightened down very tight.
What's your (general) location? Shipping wheels isn't cheap; members may prefer to meet / deliver.
madpogue is offline
Old 09-11-22, 09:57 PM
  #5169
mountaindave
tantum vehi
You need longer brakes... A rat tail file can elongate the ones you have if it's only a millimeter. Sooooo many more tire options in 700c and you get the bonus of fitting bigger tires!
Old 09-12-22, 04:57 AM
  #5170
mrv
buy my bikes
mrv's Avatar
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 518 Post(s)
Liked 424 Times in 247 Posts
ISO:
Hi Duke o' Fearl!
I got a bottle opener / freewheel removal tool plus a functional retainer ring plus a freewheel. You can see everything here: https://www.bikeforums.net/bicycle-m...ad-repair.html
I have the hub shell & parts as well, but I am / have decommissioned it due to the issue laid out in the post. It's still laced to the wheel. I was going to post the freewheel for sale soon - for cheap, as it is use. I got no idea how many more miles you could get out of it.
cheers!
mrv is offline
Old 09-12-22, 05:05 AM
  #5171
VintageSteelEU
VintageSteelEU's Avatar
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 206 Post(s)
Liked 395 Times in 234 Posts
Got two Weinmann rims, concave, eyeletted (whichever model that was), but 700c. Also, whilst cosmetically they are fine, they would require some extra work on making them rounder.
As someone advised above, you could try brakes with longer reach. It's going to be something like 4-5x cheaper than replacing the wheels. Unless, of course, someone has the right wheels to trade on the forums.
VintageSteelEU is offline
Old 09-12-22, 05:20 AM
  #5172
dukeofearl
Quoted: 62 Post(s)
will give that a try - gently! i'm in philly, post updated thanks
it's all original and in nice shape, so i was hoping to keep it that way, plus there's tons of room on this bike for larger tires, though i know there aren't a ton of options in 27. maybe i should make a separate thread for this bike
Originally Posted by mrv
Hi Duke o' Fearl!
cheers!
i might wanna buy that removal tool, if you're selling it separately. going to try the pliers first but don't want to damage anything. otherwise the freewheel is in good shape, just that dang plastic thing
Old 09-12-22, 07:46 AM
  #5173
madpogue
Option - if you're not interested in preserving it, and especially if it's brittle, you could poke at the dork disc from the other side until it cracks into two or more pieces through the hole, then just yank the pieces off from behind. I've done that with other dork discs when I didn't have the right freewheel tool handy.
madpogue is offline
Old 09-12-22, 08:23 AM
  #5174
dukeofearl
Quoted: 62 Post(s)
will try that! pliers did not work
Old 09-12-22, 09:16 AM
  #5175
smontanaro
Bikes: many
Quoted: 1434 Post(s)
Liked 1,363 Times in 747 Posts
Most are full plastic, but some (Huret, in particular) have a metal center. Poking might not be sufficient...
Monti Special
smontanaro is offline
