Is this Schwalbe tire worn out? or is it my corroded spokes? Not for faint-hearted!😁
Old 12-12-22, 11:31 AM
djb
Quoted: 2564 Post(s)
Liked 832 Times in 693 Posts
Wow, that's serious life out of that tire, no wonder it's looking that wonky.
Quite impressive actually.
djb is offline
Old 12-13-22, 07:07 PM
NYCDahon
Quoted: 14 Post(s)
Originally Posted by djb
sorry, not only do I have no experience with smaller tires, I am going on close to a 100lbs lighter than you, so not the right person to ask.
Marathons in general are pretty tough tires, perfect for commuting and such.
There are lots of flavours, yours are probably the regular version, as I now see that the stuff showing is the green stuff. Its teh Plus versions that have the blue anti flat protection layer.
I checked again - it is the green type - I ordered a backup from Amazon. I also increased my tire pressure to 80 psi. Thanks all!
NYCDahon is offline
Likes For NYCDahon:
Old 12-15-22, 05:10 AM
Hondo6
Bikes: Yes
Quoted: 471 Post(s)
Liked 548 Times in 388 Posts
Originally Posted by NYCDahon
I weigh over 220lbs and it is only a 20" wheel - undoublty on some days I road it with under inflated tires. Any advice on the best tire pressure to use? Since I live in NYC - I need it to be a 20" folding bike for a few reasons - but I would love a full size bike. 😁
This link might be helpful. It's SRAM's recommended tire pressure calculator.
https://axs.sram.com/guides/tire/pressure
Might want to check with SRAM to see if it's valid for eBikes first, though.
Disregard above, please. Did some further checking and SRAM's calculator doesn't seem to include any 20" tires.
Hondo6 is offline
Old 12-15-22, 06:30 AM
FBinNY
Quoted: 4998 Post(s)
Liked 1,110 Times in 648 Posts
At your weight, riding 20" wheels on NYC's potholed streets, go to the max tire pressure. This will afford maximum protection against denting a rim
In your specific situation all other considerations are secondary.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Likes For FBinNY:
Old 12-15-22, 06:31 AM
djb
I would think that contacting companies likes dahon or Brompton would be the best for pressure recommendations for smaller tires, for a given tire width and rider weight.
Or a Brompton dahon forum, I'm sure there are these in the UK where so many people use folders on a daily basis, and you'd be able to get some experienced advice.
djb is offline
Likes For djb:
Old 12-15-22, 03:21 PM
Yan
Yan's Avatar
Quoted: 1118 Post(s)
Liked 306 Times in 203 Posts
That tire has plenty of life left. Keep riding the tire until the rubber is completely gone and the fabric carcass becomes exposed. You will start to get more frequent punctures near the end. Replace when this becomes too annoying.
Yan is offline
Old 12-17-22, 08:19 PM
NYCDahon
Quoted: 14 Post(s)
i like your attitude!😁
NYCDahon is offline
Old 12-18-22, 08:19 PM
NYCDahon
Quoted: 14 Post(s)
i agree - $31 from Amazon - I bought a backup
NYCDahon is offline
Old 12-19-22, 03:56 PM
ARider2
Quoted: 84 Post(s)
Liked 116 Times in 85 Posts
Yes that tire is worn out and should be replaced. The blue you see is the layer below the tread. Any time you see the layer appear below the outer tread you can be sure your tire is worn out.
ARider2 is offline
Old 12-22-22, 08:22 PM
xiaoman1
xiaoman1's Avatar
Bikes: A few too many
Quoted: 1301 Post(s)
Liked 1,934 Times in 1,072 Posts
Originally Posted by squirtdad
OP must corner a lot and fast
Or only ride in circles.....
Looks like you got your monies worth from it, I would replace the tire as soon as you can afford to.....Braking and cornering may soon become an issue.
Ben
Voltaire
xiaoman1 is offline
Old 12-25-22, 07:46 PM
NYCDahon
Quoted: 14 Post(s)
I switched to a 30 spoke rim a while back - I had used 59psi but now I do 90psi. Rolls nicer! Have new tire now! Thanks all for advice
NYCDahon is offline
